Question about GE Kitchen Ranges
Timer for buzzer won't go off and i am getting a f-1 failure code on the oven display
Went to another website that didn't charge me for information that is already on the web. Found a list of fault codes which told me the oven sensor was bad.
Posted on Nov 16, 2008
How do i stop the buzzer on my neff oven. No timer is set but still dings.
Sometimes it is necessary to wiggle the time setting knob back and forth to get the buzzer to stop.
Jul 04, 2016 | Neff Ovens
H3CR 11 pin
1) When oven turns ON, Power flows between the timer and the oven.
http://waterheatertimer.org/How-to-wire-pin-timers.html
2) For example the oven might be connected to pins 8 and 1.
Connect a light bulb to terminals 8 and 1.
http://waterheatertimer.org/images/10-pin-wiring-350.jpg
3) Since the H3CR timer is rated max 16 amps, I suspect the timer controls a contactor and is not directly attached to heavy oven wires.
So if max amp load on timer is 16 amps, then it is safe to add light bulb wire without line fuse between timer and light.
http://waterheatertimer.org/Fuseholder.html
4) Add comment and say what you are doing.
Jan 21, 2013 | Hardware & Accessories
Cmos beep codes
do you know which bios your computer is running ?
AMI BIOS beep codes 1 beep - DRAM refresh failure
2 beeps - Parity Circuit Failure
3 beeps - Base 64K RAM failure
4 beeps - System Timer Failure
5 beeps - Processor Failure
6 beeps - Keyboard Controller / Gate A20 Failure
7 beeps - Virtual Mode Exception Error
8 beeps - Display Memory Read/Write Failure
9 beeps - ROM BIOS Checksum Failure
10 beeps - CMOS Shutdown Register Read/Write Error
Phoenix BIOS BEEP codes. 1-1-3 CMOS write/read failure.
1-1-4 BIOS ROM checksum error.
1-2-1 System timer failure. (Programmable Interval Timer PIT)
1-2-2 DMA (direct Memory Access) failure.
1-2-3 DMA page register failure.
1-3-1 RAM refresh failure.
1-3-3 64K RAM chip or data line failure.
1-3-4 64K RAM odd/even logic failure.
1-4-1 64K RAM address line failure.
1-4-2 64K RAM parity error.
2-?-? Any beep series starting with 2 beeps indicates a 64K RAM chip or data line error.
3-1-1 Master DMA register test.
3-1-2 Mslave DMA register failure.
3-1-3 Master interrupt mask register failure.
3-1-4 Slave interrupt mask register failure.
3-2-4 Keyboard controller failure.
3-3-4 Screen (video) memory failure.
3-4-1 Screen initialization failure.
3-4-2 Screen retrace failure.
4-2-1 Timer tick interrupt test failure.
4-2-2 Shutdown test failure.
4-2-4 Unexpected interrupt in protected mode.
4-3-1 RAM test failure above address 0FFFFh (64K +)
4-3-3 Interval timer channel 2 test failure.
4-3-4 Time of day clock failure.
4-4-1 Serial port test failure.
4-4-2 Parallel port test failure.
4-4-3 Math Co-processor failure.
BEEP codes may vary dependent upon the revision of BIOS. This list is for reference only
hope this helps
Oct 10, 2012 | Intel Mother Board S5520HCR (988889365963)...
AEG single oven - clock runs for 12 hrs , buzzes and goes back to 12 o'clock - if set timer and check time remaining, it buzzes and jumps to clock setting loosing time remaining. Buzzer sounds ''hoarse''.
you must setting the count down timer instead of time of day. to set time of day. press centre button 4 times lamp flashes in bottom righthand of display. use + and - to get correct time after 10 secs time will lock in. to check you have not set count down press centre button 3 times lamp flashes top right corner of display if not at 0000 use - button to get to 0000 leave 10 secs then should revert to time of day. also check you have not entered cooking time. press centre 1x this also should read 0000. hope this helps
Jul 17, 2010 | AEG B2100-4 Electric Single Oven
Volume control candy oven timer
Switch off the oven, leave for 5 seconds and switch it back on.
Candy Customer Services asked for over £100 to have an engineer sent to my house, which I refuse as I thought the oiven was good.
I had to switch off all the electricity in the kitchen but after this 'reset' the oven turned to the normal 'high' volume.
Jan 12, 2010 | Candy Ovens
Oven buzzer won't stop. F-1 is flashing.
http://www.applianceaid.com/fault_codes.html#f1test
May 15, 2009 | General Electric Stove/Oven/Range Chrome...
F1 Failure , need to know how to advance the clean timer to get unit to unlock
Hello welcome to fixya,
Below I pasted the fault codes for the two different years of this range.
To diagnose these difference you will need a hands on tech !
this is not an easy thing to determine
JENN AIR
Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad)
JENN-AIR
'Newer Style' Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Power to element relay energized during time of day display Wiring harness shorted or change power relay board (PRB)
Note: for double ovens, change second oven board
Dec 08, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Kenmore drop in range code F7
Oven control beeps and Electronic control as detected fault condition.
Press CLEAR to clear the display and stop displaysF1,F3, F7 ,or F9 beeping.
Program oven again.If fault recurs,record fault number.
Press CLEAR and contact your Sears authorized qualified service agency.
Oct 17, 2008 | Kenmore Kitchen Ranges
Whirlpool super capacity 465 timer won't beep
clock timer and motot for a black electric oven 220Volt. oven number on plate at bottom of door is these two RGE 1600 P 5.8 and MK 93877451 4.4
rge
Jan 12, 2008 | Whirlpool GBS307PR Electric Single Oven
GE digital Timer Oven
most of the time turning the breaker off for a few min will be a temp. solution but it it comes back then the ERC which is the clock itself needs to be replaced
Nov 22, 2007 | GE JKP27 Electric Double Oven
Kitchen Ranges Logo
79 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
