Question about Jenn-Air Grilling
Looking for the right Rotisserie kit for a Jenn-Air 720-0337
I am having a hard time finding the right Rotisserie kit for my Jenn-Air Model 720-0337 the one I brought home from Lowes was the wrong one too Short of a Rod
3 Suggested Answers
SOURCE: Looking for a part for my Jenn-Air electric motor
I broke the same part when trying to manually turn the shaft on a stuck motor. That part is made out of pot/white metal. Mine broke at the base where it slides onto the half round shaft on the motor. I was able to fix it by drilling a small hole in the half round shaft on the motor and the broken piece. Then I used a small finish nail as a pin to hold the two parts together. Next time I take it apart, I will use some JB Weld epoxy on it. I don't think you'll find that piece by itself. I might just tinker on my metal lathe and make one up, but looking on ebay is probably your best bet for the whole motor.
Posted on Jul 20, 2009
  • 4736 Answers
SOURCE: How do you replace burners on Jenn-air 720-0337
First, remove the grill grates, then the flame tamers to access the burners. As you face the grill, carefully lift up the end of the burner farthest from you (It may or may not have a cotter pin holding it in. If it does, remove the cotter pin with a pair of needle nose pliers). As you lift it up, it should pull away from the burner orifice (inside the control panel). And that's all there is to it.To reinstall the burner, do everything in reverse. But, there is no need to replace the cotter pin. It was there for shipping purposes.
Hope this helped you. Please let me know. Happy Grilling!!
Posted on Jun 12, 2011
Covert Jenn-Air 730-0171 grill from NG to LP (propane)
Yes you can buy a kit just google make and model then you should be able to find a kit.
Jan 23, 2016 | Jenn-Air Grilling
Jenn- Air rotisserie burner wont lite. Doesn't
Try removing the cover on the back of the grill hood and finding the orifice for the rear burner. Check to see if the orifice is plugged.
Jul 31, 2011 | Jenn-Air Grilling
Which is the right rotisserie for the Brinkman 8534 Gas Grill? Where can I purchase it and how much does it cost?
You can find and purchase the rotisserie on Brinkmann's website. Click on the Accessories tab and then enter the correct model number for you grill.
http://www.brinkmann.net/home.aspx
May 14, 2011 | Grilling
I have a Jenn Air model # JCD2295HES and I need a repalcement water filter. I'm having a really hard time finding a replacment on a discontinue model.
CHECK THE MANUAL BOOK THAT COME WITH THE UNIT IF YOU HAVE ONE. IF DO NOT HAVE ONE GO TO SEARSE ADWARD STORE THE FILTER THAT MADE FOR YOUR UNIT THERE WILL BE AN INSTUCTION PAPER ON OR INSIDE THE BOX THAT WOULD GUIDE YOU TO THE PROCESS. ANYWAY YOU CAN LOOK UNDER THE DOOR LELF OR RIGHT SIDE. OR OPEN THE DOOD LOOK ON THE TOP RIGHT CORNER IT MAY BE UNDER A SMALL COVER
Oct 24, 2010 | Jenn-Air JCD2295HES Side by Side...
Trying to install the rotissere on our Jenn-Air outdoor grill. Instructions lost and the installation seems impossible!! Help!
I have instructions for model# 720-0093 Jenn-Air rotisserie, pretty simple, 4 bolts total. Must admit, I had to go back to Lowes for help since I was trying to install brackets the wrong way. Will be glad to email these to you, let me know @ caycebugs@sc.rr.com
Aug 16, 2010 | Jenn-Air Grilling
Jul 15, 2009 | Jenn-Air Grilling
JDS8130 Cooktop Conversion Kit : Propane to Natural Gas Conversio
here is a site that has gas conversion kits
http://en.allexperts.com/q/Major-Appliances-3603/Jenn-Air-gas-range.htm
Jan 31, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Jenn Air 720-0061-LP Gas Grill Rotisserie Problem
Hi all ,
I just bought a jenn air 720-0336 gas grill from bj's . the rear rotisserie burner would stop working after a few minutes .
hear is the deal , the rear inferred burner gets to HOT . they did not put any insulation between the ceramic blocks and the metal bezel.My fix was to remove the unit , drill out the 8 rivets holding the bezel on , carfully remove the bezel and install a fire proof gasket , i was abile to find the proper stuff at my local coal / wood stove retailer.it comes in a white sheet about 1/8 inch thick .
use steel rivets to reassemble . good luck . this took a week of trial and error to figure out .
Aug 02, 2008 | Grilling
Rotisserie won't stay lit
With our Kenmore, you need to increase the gas flow another 1/4 turn once it's lit.
May 25, 2008 | Grilling
Jenn Air JMC7000ADW
I would consider the
JMC9158BAW this is a 1.5 cubic ft, yours is 1.6, yours is about 24 inches and this one 24 inch, this model is a built in/countertop
the closet model you are going to find
Kitchenaid has the KBMS1454SSS 24inches comes with 27 and 30 inch trim kit
and KBMS1454S same specs just different model
May 01, 2008 | Microwave Ovens
Grilling Logo
81 people viewed this question
Top Jenn-Air Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Jenn-Air Grilling Expert? Answer questions, earn points and help others
