Question about Kenmore 24032\24036 Top Load Washer
Kenmore washing machine
I have an 80 series kenmore washer the basket disconnected and swings freely how do i fix it? and how do i access it?
Yeah I threw the damn thing out and got a new one
Posted on Nov 18, 2008
Kenmore 80 series washer won't spin or agitate
check to make sure the belt hasn't come off. if it's direct drive make sure the shaft is working and moving freely. if all of these check out the motor that turns everything my be stuck, frozen up or just bad all together.
Jul 14, 2012 | Kenmore 24032\24036 Top Load Washer
My washer fills up with water and quits after that, it makes a buzzing noise when it should start its cycle. what can i do to fix this? it is a kenmore series 80
This could be a capacitor, which gives the motor the 'spark' to start, or the motor itself. If you try to move the empty machine's basket by hand, is it hard to move or does it spin freely?
Joe
Aug 29, 2011 | Kenmore Washing Machines
Kenmore 80 series top load washer. Will work on
if that arm is white and inside your clutch assy,that is the brake release arm that releases the brake to allow the basket to spin. it has 2 little fingers on it that lineup on the brake release cam, also check the bottom of yuor basket drive tube see if it has worn down or if the clip is there that holds that arm in place
Feb 21, 2010 | Kenmore Washing Machines
My kenmore 80 series inner tub is banging when it spins. It seems loose. Any suggestions?
There were a few of those where that would happen. The basket drive would come loose. Some had the drive block break. But either way you will need the spanner wrench to fix it.
Dec 30, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series model 110 after wash clothes are left soaking
when empty and off, open the lid and see if you can rotate the inner wash basket by hand. if you can easily, then the clutch is worn. This will prevent the basket from going into a high spin and wringing the clothes out. Replace the clutch by removing the top control panel, removing the clips that hold the cabinet, pull cabinet off, remove drain pump clips and pump, remove motor clips and motor, remove transmission (3 bolts). Now you will have access to the clutch, replace as needed, reverse dissasembly to complete. remember to unplug.
Jul 01, 2009 | Kenmore 22422 Top Load Washer
I have a kenmore washer 80 series that over flowes help please
I had the same problem with a 90 series and there is a small hose connected to the water level knob that had slipped off.
Jan 21, 2009 | Kenmore 24032\24036 Top Load Washer
Does not drain
Try cleaning out the exit filter which is usually under a swinging flap at the front of the machine. If it isn't there it will be somewhere easily accessible. This should be cleaned every 2 weeks. Also the outlet hose could be blocked with a build up of debris and soap that gets stuck over a period of time.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Loose basket
the block drive is worn..
Dec 27, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore series 80- spin cycle does not spin
possible bad bearings in basket support asm or bad basket drive asm both pretty big jobs
Dec 13, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
47 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
