Question about Philips 46PP9302 46" Rear Projection Television
Philips Projection TV Bulbs need changing
My father in law has an old philips projection tv and said there are 4 bulbs in the tv and the green bulb is out. He wants to change all bulbs at once. Is there a site where he can go first to get the bulbs and then to explain how to change them out. It's about a 2004 Philips prjection tv.
Any help would be great.
Wayne
  • bosdj66 Nov 16, 2008
    Thanks for your help. I think he will decide to get another tv.
Buy a new television. The "bulbs" are actually small picture tubes, also referred to as CRT's or guns. There are three of them, Red, Green and Blue. The cost for the tubes alone will probably exceed the original purchase price of the television. If the new tubes do not have the lens assembly attached, then you will need to transfer the old ones. This involves draining, cleaning, and refilling the coolant chambers. Once installed in the set, there is a series of mechanical and electrical adjustments required, to get the picture aligned or converged. This procedure is not recommended for the inexperienced. If cost and time are not an issue, then everything can probably be found on the Internet. Simply search the web for your model number. You will need the remainder of the model number first. There are at least eight models starting with 46PP9302. You are missing three additional characters.
Discouraged yet?
Posted on Nov 15, 2008
Problem with the Philips Projection Televisions I have a Phillips 60P8342A 60 in 2002 Projection By jenny_royalt on Feb 08, 2010 I have a Phillips 60P8342A 60 in 2003 Projection and the screen is...
sounds more like the fluid in the blue and green CRT's needs to be replaced. Check the fluid and see if it is cloudy. If so - that is your problem. This is common for this series of tv.
Mar 08, 2011 | Philips Televison & Video
My tv color is very red and orange but all 3 color bulbs are working it seems... the actual picture only comes through the red and green... help!!!
go to tvrepairkits.com and order the kit that replaces the fluid in the blue and green bulbs, will clear up your color issues no problem :) i just fixed mine, now it looks great.
May 10, 2010 | Philips 55PP9352 55" Projection Television
The tv will not turn on. I need to change the bulb in the tv
Snap-off lower front panel ( about 4" tall x width of TV.) Door behind there with philips screw. Philips screw for lamp itself.
May 02, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Replacement Lamps/Bulbs for Philips 50P8341 Rear Projection TV
These are both CRT type TV's(3 picture tubes drive the image) with different screen sizes and the CRT's are not interchangeable
Oct 24, 2009 | Philips 50P8341 50" Rear Projection...
My philips 50" projection tv screen looks green or light blue
the picture tubes are liquid cooled,coolant is contaminated and mist be changed.any questions just give us a call 410-388-9399
Sep 01, 2009 | Philips 60P8341 60" Rear Projection...
Picture went green. how do i change bulb??
you can get the red replacement CRT at the following link and they provide free instructions. Heres the link to the correct red for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/red-crt/cName/phillipsmagnavox-tv-parts
Apr 20, 2009 | Philips 55PP9701 55" Rear Projection...
Bulb Replacement
It might be the the socket board on this model not the crt tube. Closely look at each tube these tubes end up contaminated. They start looking like lemonade inside. Usually the blue and green, with the tv off see if the green and blue are as clear as the red with a flashlight. You might want to call a service center. Cheaper in the long run over the cost of a tube.
Apr 17, 2009 | Philips 60PP9753 60" Rear Projection...
Projector tv the red and green colors are not in sync
no its a convergence tube problem u shud change the green tube.
its the exausted one in this case.
Mar 15, 2009 | Philips 60PP9202 60" Rear Projection...
New bulb replacment for 51mp392h magnavox
you dont have bulbs you have crt's (picture tubes) red green blue. Tell me which one you need and I can post you a link, it's not hard but you do need the service manual for your tv to set it up right
Apr 25, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips 46PP9302 46" Rear Projection Television Logo
140 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
