Question about PfaFF Sewing Machines
Serger 794 from pfaff--calanda type 794
2 needles fell out from inside my serger when material got stuck I need to put back. do you have an exploded view on this serger so my husband can put them back. thanks cdclau
  • PfaFF Master
  • 1,388 Answers
There are two holes running vertically inside the needle arm.........the needles are held firm by very small screws or hex allen keys.........they may have worked loose over time, if they have fallen out and been lost, it is a call to your  local Pfaff dealer for advice......be sure to quote model number.
Your User manual may have a diagram to assist.
Have you ever changed the needles since buying this machine ??
Needles ought to be changed every 6 - 8 hrs of sewing, and more often with heavy or abrasive fabric.
Posted on Nov 15, 2008
Hobylock 794 serger right looper needle position...I took it out to thread it and can't get it in the right position to sew correctly
I had the same problem. the last resort was go get a professional repair person. i had to replace the whole needle shaft. then the tension feeds were looked and i have never been more satisfied.
Nov 10, 2010 | PfaFF Hobby 4260
I can't find the way to change the left needle.
You can order a manual here - http://www.sewusa.com/Sewing_Machine_Manuals/Pfaff_Manuals/794_796_Hobbylock_Instruction_Manual.htm
In the meantime, contact your local Pfaff dealer. Ask if someone can help you if you bring the serger in.
Mar 18, 2010 | PfaFF Hobby 4260
Needle stuck in the material while sewing a straight stitch.
See if you can release the bobbin from the case.
Dec 30, 2009 | PfaFF Sewing Machines
Price of hobbylock 794 in todays market.
Price depends upon how much the machine has been used & what condition it is in. My hobbylock 794 has barely been touched since it was first made and they advised I just throw it out instead when I took it in for a little 'freshening up' at Quality sewing & vacuum in Washington! Everywhere else I've had great feedback that this is a good serger, so check out what similar machines are selling for on Ebay... you could get $100~$400 for your trusty serger {depending on supply & demand}.
Mar 27, 2009 | PfaFF Hobby 4260
How do you get the blades to cut on a hobbylock 794 serger
It should just cut. Don't know too much about this machine as I'm new owner, but from what I can gather, either you need a new blade, or the upper knife is disengaged. The metal knob inside the threading area should be turned downwards, engaging the upper knife. The upper knife doesn't usually need replacing unless damaged, apparently. Hope this helps somewhat.
Dec 04, 2008 | PfaFF Hobby 4260
Pfaff Hobbylock 776
The best I can say is to change all your threads to different colors and get light colored material. Start with tenstion for all set to N - normal and experiment from there. Change one thread's tension at a time, sew a long strip and check out both sides and adjust as needed. Remember to start with new serger needles and a oiled machine. I'm not an expert - I just have had a serger for 15 years.
Sep 21, 2008 | PfaFF Hobby 4260
Pfaff serger stuck
your needle bar has been pushed up and is out of adjustment. You need to take off the side cover, there should be a screw on the back of your machine holding it on. Remove this screw, and remove the cover.You may have to remove the light assembly to reach the screw on the needle bar. Once you can see the needle bar, rotate the handwheel until you can see the screw on the needle bar. Loosen this screw SLIGHTLY until you can turn the needle bar. Hold and rotate the needle bar back and forth as you push down slightly. This will lower the bar.Lower it about 1/4 inch. Adjust the needles by turning the bar so that they are straight across. Tighten the needle bar screw so that the bar doesn't move. Turn the handwheel to see if the threads will be picked up. If not, adjust until they are. Tighten the needle bar screw tightly,reinstall the side cover ,and tighten the screw. Change your needles.Rethead and sew.
sewman7
Jun 17, 2008 | Sewing Machines
Pfaff hobbylock 794
The needles are changed by inserted the hex wrench into what looks to be holes on the front and left side where the needles go into the machine.I'm not sure what size the hex wrench is but it's pretty small. From the manual,
"Removing Needle: Unplug the machine. Turn the handwheel counterclockwise to raise the needle bar to its highest position. Loosen the needle clamp with the allen wrench and pull the needle out." and
"Inserting needle: When the neddle bar is at the highest position, insert a new needle in the needle holder, making sure that the groove of the needle faces you. Push the needle as far up as it will go and tighten the needle clamp screw." "Removing Needle: Unplug the machine. Turn the handwheel counterclockwise to raise the needle bar to its highest position. Loosen the needle clamp with the allen wrench and pull the needle out."
The machine takes DB x 1, or 1738 needles, and a size 14 needle is recommended.
Hope this helps!
Mar 31, 2008 | PfaFF Hobby 4260
Sewing Machines Logo
532 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
