Question about Whirlpool GS460 Gas Kitchen Range
Oven doesn't heat up properly
I have Whirlpool gas range. This summer the oven stopped working properly. Now when we set the temperature for the stove, it doesn't reach the desired temperature. It is usually lower than desired.
  • 3 more comments
  • Anonymous Nov 24, 2008
    my oven doesn't heat to the desired temperature.
  • campbjac Dec 06, 2008
    The oven temp is always lower than a separate thermometer indicates.
    We have to set the oven several degrees hotter than we need to get it to proper temp.
  • daveoffive Dec 10, 2008
    My problem turned out to be a bad thermostat.
  • campbjac May 11, 2010
    My oven does not have a knob, it is all electronically controlled.
  • 171 Answers
Ovens can be calibrate for the right temperature. the adjustment screw is locate inside the shaft of the thermostat. when you remove the oven knob.
Posted on Dec 09, 2008
How do you turn it on and set temp
Whirlpool Home AppliancesPress the number keypads to set a temperature other than 350°F (175°C) in 5° ...Timed Cooking allows the oven to be set to turn on at a certain time of day, ...
Oven Temperature Issue ' FAQ ' Sub-Zero and Wolf
Sub?ZeroOvens will heat up higher than the oven temperature set point and then turn off. ... If oven temperature is off on an R or GR Series Gas Range, ensure that the ...
Oct 29, 2015 | Kitchen Ranges
Is there a pilot for the oven that can go out and needs to be manually relit? I have alrady replaced the igniter
The Whirlpool SF357 (SF357PEKQ0 specifically) does not have a pilot light; only the electric igniters that light the gas on demand for both the range and the cooktop.
On my gas ovens, checking the ignition is easiest with the warming drawer removed and the cover plate removed from the oven. Do you see a glow at the igniter? If yes, then the igniter is probably working. If not, check that the wiring harness between the igniter and the control board is connected and giving the appropriate power.
The next thing to check is that the oven gas valve is open. (Mine have a separate valve here.) Then check that nothing is blocking the gas line and that the regulator is opening and closing properly. We had an old oven that would start the gas flow and come up to temperature normally during the pre-heat time. However, when the oven cooled, the regulator wouldn't reopen thus the oven wouldn't stay at temperature. The regulator could be forced to open with a tap to the mechanism when the oven needed to come back to temperature.
Whirlpool has manuals and parts lists for the SF357 ranges on their site. . The installation guide is here: . The owner's manual is here: .
I hope this helps.
(In the case of our old oven, we replaced the entire range. The difference in price between a new range and the needed parts (and labor) to fix the old one were nearly the same.)
Nov 12, 2011 | Whirlpool SF357 Gas Kitchen Range
Oven not heating to correct temperature
Replace the oven glowbar ignitor. It is too weak to keep the gas valve open.
Aug 19, 2009 | Whirlpool GS460 Gas Kitchen Range
Dacor oven overheating
sounds like your bake relay is not closing
you need service relay board replaced
Aug 01, 2017 | Dacor Preference PGR30SS Gas Kitchen Range
Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
Feb 25, 2009 | Ovens
I have a whirlpool gas oven model # SF395LEEBO
Oven temperature sensor opened Replace oven temperature sensor
Jan 11, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Oven won't turn off
My gas oven won't stay off. It feel like it's on, always warm.
Jan 05, 2009 | Whirlpool SF379LEKS Gas Kitchen Range
i dont know want is wrong with it when i turn the oven on it keeps saying e2 and f3 i dont know what that mean please help me one on .... :(
Dec 05, 2008 | Whirlpool SF357 Gas Kitchen Range
Whirlpool 465 oven temp
Go to Calibration mode and adjust the temperature up by 10, 20 or 30 degree. This is in each manual.
Jan 11, 2008 | Whirlpool GS460 Gas Kitchen Range
Whirlpool GS460 Gas Kitchen Range Logo
808 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
