I recently bought a new laptop, and the software is Windows Vista. My old computer was Windows XP, and my camera cannot connect with my new computer because I only have the old software. I need to find a download link for finepix driver a345 for Windows Vista. Any help?
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Windows Photo Gallery or Picasa.
SOURCE: The AutoPlay Wizard does not launch when I connect my camera
We suggest running the Microsoft AutoPlay Repair Wizard utility which is available as a free download from the Microsoft Download Center. The AutoPlay Repair Wizard scans your computer devices to find defective AutoPlay settings, and attempts to fix those it finds. To download this utility, please go to the Microsoft Download Center and enter "AutoPlay" in the Keyword box.
SOURCE: softwear for finepix camera
The A202 is a European model and they do not have updates for Vista that I could find. You can however find the updater program for the FinePix software that includes Vista. http://www.fujifilmusa.com/JSP/fuji/epartners/ServiceSupportSoftwareContent.jsp?dbid=864214&prodcat=644675&sscucatid=664260
SOURCE: Webcam a345
You need the USB cable to connect the camera to your computer and in the setup menu, change your USB mode to PC
SOURCE: Need Fuji FinePix A500 Software
Go to their website, Its a whole lot easier just to get a external card reader or use one thats built in your pc if you have one...
SOURCE: Camera turns on but lense does not open
The lens needs to be removed, stripped and cleaned. It's jamned up with dirt or some foreign objects. the drive gear on this model and other similar models e.g. A345, A350, A360,and A370 are all open on the side of the lens unit. Unlike other fuji's where the drive gear is inside the lens unit and less likely to jam. This is a great little camera otherwise. Well, I like it anyway.
I have the same problem with my new desk top. The set up software won't install.
I have Windows Vista and I need to install the Fine Pix software, what I can do?
I have the same problem. Someone please help......:(
