Shutdown and startup problem
Alot of times when I shutdown my laptop and reach the "loginoff" part my toshiba a305-s6864 just blocks. The same thing happens when I start my laptop and reach the "loginon" part it just blocks and I have to restart the computer like three times to be able to enter windows
  • eldahdah Nov 15, 2008
    thank you so much for the quick, efficient and clear help!
  • 4,806 Answers
When you get into windows you need to perform a surface scan of the hard drive and check it for bad sectors, i sounds like it is having difficulties reading the boot drivers, run chkdsk /f to check the disk for any problems and it should fix them for you, if the drive comes up clean with no problems then the system 32 folder is corrupt and you are looking at a full system recovery, make sure you back up all of your data while you can still use the machine
good luck
Posted on Nov 15, 2008
Disable auto shutdown
Restart the Computer and keep tapping the F8 key till you see the advance boot options, You should be tapping the key as soon as you see the manufactures screen. Once you get the advance boot options -> Select the option which says Disable Automatic Startup on System Failure.
Good Luck!!!
May 16, 2013 | Toshiba Satellite Computers & Internet
My toshiba laptop does not shut down
Some startup item may be causing it. Before you shutdown your laptop, close all applications. Also click on start and then run. Type msconfig and click on "startup" uncheck all unnecessary itmes and restart and then test it. Good luck.
Tech from Computer repair and data recovery Toronto
Apr 13, 2013 | Toshiba Computers & Internet
My laptop is automatically shutdown when they normally boot-up
if you can, hit start, if it is xp hit "run", type "shutdown -a" without the quotes, then hit enter. you will have to do this fast before the 10 seconds. if it is vista just hit start, then type "shutdown -a" and hit enter. if you are quick enough, the shutdown will abort. now, go to the startup folder in start>all programs>startup and delete anything there if you don't know what it is. this might stop it from happening again. someone might have put a shutdown command in the folder as a joke. it could also be a virus. so if this fixed it, download spybot search and destroy and run a scanmobile crusher
May 09, 2012 | Toshiba Computers & Internet
I cant boot up from my cd,after i installed a new wd 80 gb hard drive... i get a message saying that the vendor id dont match,what should i do????
try going into the bios and change the boot priority to cd first then hdd, you may also have to set the jumper on the hdd to master.
May 17, 2011 | Toshiba Satellite A305-S6864 Notebook
Toshiba A305 shuts down randomly. Hard drive replaced twice by different service companies. Still shuts down. Upon startup and after its been on a while. Any ideas?
More than likely it's from heat. The A305 gets hot quick, especially if your model uses the AMD processor. I would suggest you cleaning the machine out with some compressed air and verifying that you are running the latest bios revision for your model.
I've fixed lots of A305 just by doing the above ;)
Give that a shot, if it doesn't work let me know and I'll suggest more things you could try...but I'm pretty confident heat is causing your issues.
Jan 13, 2011 | Toshiba Satellite A305-S6863 Laptop
Sudden shutdown on my Toshiba A215 S5849 laptop. Has been happening once or twice each time computer is running.
mine has been doing same thing,I have same type of computer,
On mine if just the battery is in it won't shut down,but having the power cord connected causes a short or something and its like it "just goes click" and nothing,
I heard alot of toshiba laptops are doing this,this will be the last toshiba I buy
I can be contacted at if you wish to share more info about our problems
Dec 18, 2010 | Toshiba Computers & Internet
Hard Drive Recovery Partition for Toshiba A305-6837
In most cases you need to press F8 at boot like going into safe mode when booting the computer. If the option is not there then it is possible that the option is not setup properly. Note I have seen this from time to time.
Another way to tell is go into my computer and for a 2nd hard drive listed as recovery. If it is there and/or you knew it was there you just can not boot into Windows. Let me know and I can give you the steps to readd the recovery option to the startup.
Apr 15, 2010 | Computers & Internet
Toshiba Satellite A305-s6864
no problem, glad it worked
Aug 08, 2008 | Computers & Internet
No problem,
Yea, it should be the latest driver for your specific card
The Radeon 3400 series is the one you're looking for.
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
