Question about Coleman Powermate Proforce 6,000 Watt 12 Hp Portable Generator #PM0106000
New ProwerMate Pro 6750 will not stay running
We have just bought a new Powermate Pro 6750 with a Yamaha engine. It did not have any of the manuals with it since it was at the store for so long and was a self modle. Our problem is that it will not stay running. Oil and gas are full. It starts ok, 1st or 2nd pull and seems to be running ok, and then it will just slow down and stop running.
  • pegg0650 Nov 15, 2008
    That probably would have been the problem if this unit had been used before, however, we were the first. I just put the gas in the generator so it had not been sitting with gas in it.....thanks for your help.....any other suggestions?
  • pegg0650 Nov 16, 2008
    yes, all seems to be workng ok.....just will not stay running....while it is running have plenty of power.
    Almost acts like it is running low on gas....oil level is full and so is gas.
    Scholar:
  • 63 Answers
If all the above does not work, then take out the carb adjuster screw and inject some compressed air briefly. It sounds like a float is stuck, which happened often in the old Briggs&Stratton engines.
Basically, it is starting fine with a full float or full amount of gas, then that gas is running out and the unit starves out. So, you have a clogged fuel line-drain tank&blow out line-or the float mechanism is sticking. Sometimes the additives mentioned above will work, but a good blast of compressed air through the carb/fuel line has helped me many times, especially with an engine that has sat for any amount of time or that got some bad gas in it.
Posted on Feb 10, 2009
    Novelist:
  • 185 Answers
Sounds like a problem that is associated with any gas engine that has sat for a long time without running. That's why a lot of folks will use a gas stabilizer when they put up a small gas engine or drain the tank and run the engine until the gas in the carb is used up. I would drain the gas from the tank, run the card dry and then add fresh gas with a little fuel injector cleaner added to help remove any varnish type build up.
Hope this helps....Good Luck Loringh PS Please add rating if appropriate. Thks
Posted on Nov 15, 2008
  • Loringh
    Loringh Nov 16, 2008
    Pegg0650
    I guess my closing comment would be I suspect a fuel problem rather that ignition.Another thought as I went to close out. Governor working ok?????
    good luck
    Loringh
  • Loringh
    Pegg0650
    One last thought. That generator is a coleman right. Why not go to www.coleman.com and click on the "contact us" and see what they might have to say...
    Loringh
My coleman powermate pro 6750 generator only puts out like half power, after 30 minutes it loads up and runs fine. what causes this?
It would be surprising to me if the engine was running at proper speed while it is not putting out full power. I am not familiar with your particular model so my answers are coming from knowledge of generators in general. If it is running at proper speed then it would have to be a regulator problem. This is assuming that it isn't trying to run in an overload condition and that you are letting it run a little before you put a load on it.
Dec 22, 2015 | Coleman Electrical Supplies
1985 Yamaha XJ 700 S Maxim with the key off all power stays on bike keeps running
Hi, Anonymous you may need a new ignition switch for this scenario you will need your service/owners/ manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Yamaha XJ700N Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
Oct 07, 2013 | 1985 Yamaha XJ 700 S Maxim
Hi i have a Black max, Powermate Generator model #PM0496750 ,6750 watt it run great for 3 hrs and then stop generating,,, clean the frets on rotor where brushes runs on and its good for another 3 hrs then...
You have excessive arching on the rotor slip rings by the sound of it, if you clean them and it works well then 3 hours later same problem? What is the conditon of the brushes? Also I trust youa r enot cleaning polishing them with sanpaper etc, they have a very fine finish and should be polished with a super fine grit paper or stone, pref while turning the engine. Any scratches won't work
Oct 05, 2013 | Coleman Powermate Powermate 5000W...
Hi i have a Powermate model PM0496750, 6750 Black max Generator it will run for 3 hrs then stop generating ,,if i clean the frets on the rotor where the brushes runs on it will go for another 3 hrs ,,, I...
I doubt its anything to do with brushes unless power system has shutdown incorporated, could ignition coil breaking down when it gets really hot or similar check the oil level cut out switch
Have a coleman powermate 6750 generator that has quit producing power.
If the engine is running with the alternator not outputting then you must check with the LOAD TRIP switch.
if not remove the load and check if there is output. If not there is fault in tha alternator which might need some consensus.
Nov 05, 2011 | Coleman Powermate Powermate 5000W...
Engine won't maintain constant rpm
Hello There
Try cleaning or replacing the spark olug.
Hope this helps.
Many Thanks
May 22, 2009 | Coleman Powermate Premium Plus 6250W...
Runs rough when choke pushed all the way to run position
Where can i obtain a manual for the 5500 gas generator
Dec 26, 2008 | Coleman Powermate Powermate 5000W...
Coleman Powermate Proforce 6,000 Watt 12 Hp Portable Generator #PM0106000 Logo
979 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
