Question about Philips HTS3400/37B System
My player won't read some Dvd's
I have a philips HTS3400 Dvd home theater system and for some reason it has started to give me a problem of it saying no disk on some of my movies when I try to play them.I have watched these movies in it before,Sometimes only days befor.It won't read my cleaning disk at all.Does anybody know a way to fix this or if need be,what dvd rom I can use for replacement parts?
  • 5 more comments
  • Charles Young Dec 16, 2006
    It works,now Thank you.I was reluctant to try it at first because some Dvd players the laser will get off center when you manualy clean them.Once again though THANK YOU.
  • Anonymous Dec 31, 2007
    same problem same system got mine tore down and trying to clean it out
  • Anonymous Jan 01, 2008
    i have phillips hts3400 and it suddenly not reading disk all disk. screen says (no disk0
  • michaelg22 Feb 08, 2008
    I too have the same issue. My Philips HTS3400 says "No Disc" everytime we try to play a DVD. Can someone explain to me how to go into the unit and clean?
  • solo-lab Aug 05, 2008
    i aiso have been exspirencing the same thing, and i notice that the drive motor is not turning like it should ca i replace it?
  • crimzonthund Mar 15, 2009
    drive motor not spinning and no disc error
  • burger2535 Mar 21, 2009
    make machine won't read anything anymore. It started saying "No Disc" every now and then, now that all it says and I can no longer play movies. I have only used it about 25 times at the most and there is nothing about this problem in your manual under troubleshooting.
    President:
  • 3,130 Answers
You may have to go into the unit and manually clean the lens off. If this does not help, you could have a focus or tracking servo problem or it may need a servo alighnment. Worst case, would be a weak laser assembly. In most cases these days, Im sorry to tell you, even a small servo alighnments not worth the time or money to have done, as it usually cost 3/4 or more of the cost of a new player/recorder. Good Luck PS please do not forget to rate this thread.
Posted on Dec 11, 2006
Best solution and # 2 worked for me too.  Just took off the cover and cleaned the lens with a dry q tip and everything was back to normal.
Posted on May 24, 2008
Techman's solution to dry clean it worked! I also used a dry cotton swab and it immediately started working again. Thanks!
Posted on Sep 14, 2008
Mine did the same, except it still played CD's and "home burned" DVD's (photo discs, etc...). Tried cleaning, but no good. Once I opened the case I nudged the main laser assembly forward. Let me emphasize 'nudged', be gentle. The assemly slightly slid forward with little resistance. This seemed to do the trick. It realigned and plays fine again! This will probably only work if it still reads some discs, otherwise your option would be replace the unit, yuck!
Posted on Feb 22, 2008
Quick note on this - techman's solution seems to work fine. Thank you. I used a q-tip (ear cleaner) for this. Dry, no solution or water.. Boaz
Posted on Aug 12, 2007
SOURCE:
The dvd player reads the cds but when dvd is inserted it says no disc after few seconds of load
the laser is weak. need to replace. you could also try opening unit and clean lens with alcohol.
Mar 23, 2011 | Philips HTS3400/37B System
When the DVD disk is in the player it says no disk
I suggest you either flip the disk over, clean the disk with rubbing alcohol, push the drawer in after its closed to makes sure it is shut all the way or power off the dvd player for 30 seconds and power on, sometimes it needs to be reset.
Feb 07, 2010 | Philips HTS3400/37B System
Philips hts3400 will not play dvd
first clean the laser lens if this donçt solve the problem change the motor disc spindle because are on bad conditions
Jan 09, 2010 | Philips HTS3400/37B System
Philips HTS3400 door won't open and shut. Says NO DISC
open up the unit and replace the broken drive belt for the dvd tray. us an O ring that you can get at any auto parts store. i replaced mine and it works fine now.
Oct 06, 2009 | Philips HTS3400/37B System
What recordable dvds will play in philips HTS3400??
it might be the programs your using to burn your dvds try using windows dvd maker if you have the operating system vista or convert x to dvd if you have xp that should work
May 30, 2009 | Philips HTS3400/37B System
Need the speaker clips for HTS3400
Hi my name is srinivas i have the speakers for your matching philips home theater
if you are interested iam ready to provide you for lesser price my email id is srini_pana@yahoo.com
May 19, 2009 | Philips HTS3400/37B System
No Disc
Run a dvd cleaner through system, and try again. If that fails, unplug the HTS from the wall outlet for 10-15 seconds, and replug it. If that fails, it will need to be repaired.
-Tha Mp3 Doctor
Feb 08, 2008 | Philips HTS3400/37B System
Reads NO DISC Philips HTS3400 Home system
-Tha Mp3 Doctor
Jan 27, 2008 | Philips HTS3400/37B System
Philips HTS3400/37B System Logo
745 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
