Question about Soundstorm F850M Car Audio Amplifier
What size fuse does the F850M amp use?
I replaced is with the 20amp fuse and I keep getting the protection light when the bass hits. Please help.
Thanks
Black
  • 147 Answers
Have you checked the ground
Posted on Nov 15, 2008
Hey names Nathan and I just got a kicker ZX300.1 and a I connected it to my kicker comp 12 and an alpine cde 102. So the problem is that the protection light flashes with the beat of the bass at high...
Your speaker wires could be shorting to ground at the subs or at the amp. You could be experiencing a drop in voltage when the bass hits. Check your power connection at the battery, fuse and amp. Check your ground connection at the chassis connection and at the amp.
Aug 19, 2012 | Car Audio & Video
The fuse inside was blown and on opening found the blown fuse broken. replaced it and it is working. however the blown fuse was smaller in size while we replaced with a bigger size. does it matter???
you must replace the FUSE with the same capacity for example: you will see in the metal fuse the incription 240vac-15amp see if the fuse is Ceramic or Glass, you CAN not use 125vac,10amp or 20amp, the circuit WILL not protect the electronic system, and will dammed another section. Please rectify this INMEDIATELY.
God bless you
Jul 31, 2012 | Microwave Ovens
I believe I might need to change my (20 amp) breaker switch that is running on 10-2 wire which supplies power to my Rheem Classic 10 Seer. I'm not sure if I need to have 220V of power on a 30amp...
Hello, the unit runs on 220 volts that's why # 10 wire must be used. The best bet is to use a 40amp breaker for 220 volts, gives the circuit more protection.
Sep 04, 2011 | Heating & Cooling
A4004T AUDIOBAHN HEARTBEAT FROM AMP WITH BLINKING POWER LIGHT BUT NO PROTECTION LIGHT. UNPLUG SPEAKERS NO PROBLEMS. TRIED NEW WIRES, NEWER BIGGER GROUND. SUPPLIED WITH 40AMP FUSE NEAR BATTERY AND 2 20AMP...
If you disconnet you speakers and there is no problem, Then it's your speakers.
1. try your speaker wire in one port at a time (may have blown one of the outputs)
2. Check the speaker connections directly on your speakers (not loose or damaged)
3. try a different speaker all together and see if you get sound etc.
4. try a different wire from your speakers to your amp (wire may have shorted out or have breaks)
Hope this helps and please rate. If you require further info please comment and I'll get back to you asap
Mar 19, 2011 | AudioBahn A4004T Car Audio Amplifier
I have 97 ford mustang gt v8 4.6 engine as i was driving home one day my car died check the 20amp fuse that was blown and small 30amp under the hood. replace the fuse blown again crank the car up the theft...
The twenty amp maxi fuse in the under the hood fuse panel goes to, you guessed it, the fuel pump. It sounds to me like you have a short to ground in the wiring that keeps popping this fuse. Find and fix the short, or you will keep blowing fuses.
Aug 12, 2017 | Ford Mustang Cars & Trucks
Protect led flashing with hit of bass
Try a bigger amp. This one wants to be turned down. But seriously the protect can act like sort of a clipping device when the unit is trying to amplify out of a certain range. The transistors may be getting weak and need to be replaced. That said I would move this amp to the midrange or the highs and get a little bigger amp for you low low's. Hope that helps.
May 08, 2010 | Blaupunkt GTA 260 2 Channel Amplifier 400...
What is the dome fuse for?
Check the manuel for the fuse size. Also to keep the fuse from going out when you put it in unhook batt cables then replace fuse then replace batt. cables
Apr 27, 2010 | 1991 Toyota Camry
Large 20amp fuse keeps blowing
Change the fuse for the correct size AMP.
More details about Power Center Distribution, check the Section 8W Wiring Diagrams
Good luck.
Aug 19, 2009 | 1996 Jeep Grand Cherokee
Amp cutting out when bass hits
With an amp like that you can not pull enough power from you cars battery alone. That is why when it hits hard it drains the amps from your battery and you amplifier cuts out. The light on the amplifier most likely dims when the bass hits. You need to get a capacitor. They are easy to hook up on the main power wire. You can get one from http://phatcaraudio.com/capacitors.html or get a used one off ebay.com. Good luck
Jul 01, 2009 | Alphasonik PMA1000D Car Audio Amplifier
Green light turns red on hard notes with kicker 750 mono amp
First off, never, ever replace a blown fuse with a bigger one (especially one that is almost twice as big) unless it's an absolute emergency. Most of the time, the reason a fuse blows is because of a problem with the device (in this case, the amp). By installing a larger fuse, there's a very good chance the problem will become permanent (i.e. busted amp).
The amp could be going into an overcurrent mode when the bass hits and power cycling itself to try and reset the problem. If this is the case, take it to a local electronics repair shop and see what they can do.
It's also possible the input voltage to the amp is dropping too low during the bass hit, making the amp restart. Try putting a 1.0F or higher capacitor on the battery to buffer the power during the bass hits.
Mar 16, 2009 | Kicker (ZX750.1) Car Audio Amplifier
Soundstorm F850M Car Audio Amplifier Logo
Top Soundstorm Car Audio & Video Experts
Coss
hoyzee1
Are you a Soundstorm Car Audio and Video Expert? Answer questions, earn points and help others
