Question about Kenmore 60172 Electric Commercial Dryer
Dryer won't turn on
Some engagement of power but won't kick on
    Problem Solver:
I recently had the same problem and the capacitor on your motor has probably burned out so I had to replace the motor.
Posted on Nov 15, 2008
  • Tim Cole Nov 15, 2008
    If you want to check this out have someone help you and open dryer door hold door button in and push start button and have other person give the drum a turn, if it takes off it's the capacitor.
Kenmore he2 plus washerwashing machine turns on but cycle does not engage
The error F21 is a long drain error and usually the drain pump is not working or the filter is clogged. Remove the lower kick plate and clean the filter. Post back your results.
Jun 28, 2013 | Washing Machines
My whirlpool dryer WED5800SW0 won't start. It is receiving power because the timer switch still makes the clicking sound before you start the dryer. I have had recent issues of the pin not engaging...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 11, 2011 | Dryers
I have a Maytag LSE1000. The dryer and washer each have an issue at the moment. The dryer intermittently won't engage when it is turned in. When you press the "regular" button to start it,...
I really have NO idea what's causing your Maytags to misbehave, BUT I can tell you that the Maytag service centers have always been very accommodating when I've called about problems with dishwashers, dryers, and washing machines.They have explained the construction of the appliance and even told me the type of tools I needed to make repairs! If you still have your owner's manual, the toll free number should be in there. I hope this helps!
Jul 28, 2011 | Maytag Dryers
My maytag dryer got to hot heating a blanket and now it won't work at all. When u push the power button I feel it wanting to kick in but it won't do anything!! I know nothing about dryers Help...
heatman101
Jul 04, 2011 | Maytag Dryers
I'm tryin to find out if my a/c compressor is out. So I know that the dealer said that I need it charged and I didn't get it done. So lately it has been makin a loud noise and rattlin on the...
You may be having AC problems but that is not what happened when the Steering locked unless the AC is on the same belt as the Power steering unit. That whining you are hearing when you turn is actually the power steering unit being low on fluid or the power steering pump going out. Based on what you have described my guess is that the unit has gone out and needs to be replaced. As far as the AC compressor is concerned, if the unit is low on Freon it will not engage once it gets too low unless the clutch goes out. When you look at the center of the AC compressor when the engine is running and the AC is off you should see the pulley free spinning and the very center of the pulley won't be spinning, that is the clutch Dis-engaged. When you turn the AC on the Clutch should engage and allow the compressor to work. You will hear it kick in and kick out repeatedly if it is low on Freon. If it is too low it will never kick in because the low pressure switch won't allow it.
Jun 16, 2011 | 1995 Oldsmobile Aurora
The a/c clutch wont engage
Did you try jumping where the Clutch relay plugs into the fuse/relay box ? Pin 87 & 30 are the compressor clutch coil power supply . If you look on the bottom of the relay you will see four set's of numbers 30 & 87 , 85 & 86 . If you take a piece of wire an jump 30 to 87 this will send B+ voltage to the clutch coil engaging the compressor . Is the PCM turning on the relay ?
The Trainer 40 When the compressor won compress
Jul 29, 2017 | 1998 Chrysler Town & Country
Gas dryer's start button doesn't stay engaged
bad start switch on motor, rare. that model # came up as maytag range not a dryer.
Jul 19, 2008 | Dryers
Roper REX4634KQ
That should be just a push to start switch. The start switch is inside the motor. When the motor turns fast enough it trips an internal switch to keep the motor running. It sounds like you have a motor on the way out.
Apr 24, 2008 | Roper REX4634KQ Electric Dryer
Kenmore 60172 Electric Commercial Dryer Logo
51 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
