Question about Compaq Evo N610C Notebook
Screen Darkens when powercord is removed
I have a Compaq Evo N610c and the screen brightness darkens when the power cord is removed and the battery is activated. I realize that this is to conserve power on the battery but I need to know how to override" the" power saving option. Thanks, LT
  • Compaq Master
  • 32,281 Answers
Go to the Control Panel and then select Power Options
Posted on Nov 16, 2008
Gateway laptop screen darkens after boot up
Have you updated a Graphic driver? Does it Dim on battery and AC? Look at power settings. Control Panel, Power. You could Rool-Back the graphic driver to see if that changes the problem. A Gateway mt6841 has Windows XP OS, right?
Nov 27, 2012 | Gateway MT6841 15.4 WXGA SHINY LCD SCREEN
My compaq evo n610c switches itself on when the
Disconnect the power cable from the Notebook and then remove the Battery pack. While the Battery pack is removed, press and hold the power button on the Notebook for 15 seconds.
Next, reinsert the Battery pack and connect the power cord to the Notebook and turn it ON. While the Computer is booting, you can view the information on the bottom of the screen to get to the Setup Screen.
On the Setup screen, use the right arrow key to highlight the "Exit" menu, then select the option "load/get default" and press the Enter key followed by F10 keypress to reset the BIOS and save and exit the screen.
Feb 26, 2010 | Compaq Evo N610C Notebook
Hello my compaq evo n610c don't start with power cord & battery
1>NEEDS TO TRY RESEATING OF THE RAM(SWAP THE RAM WHILE PLACING THEM BACK IN) AND THEN TRY TURNING ON THE COMPUTER
2> IF THIS DOES NOT WORK THEN NEEDS TO REPLACE THE MOTHERBOARD
BEST OF LUCK
Feb 08, 2010 | HP Compaq Evo n610c Notebook
My evo n610c will not boot, acts like it is going to then goes to black screen again
Try reseating your memory, if that doesn't work check power voltage at end of power cord to see if your getting correct reading
Nov 30, 2009 | Compaq Evo N610C Notebook
Screen turn off of Compaq Evo Notebook N610c
check your settings under power options in control panel, also check advanced power options in bios. very likley you will find problem here.
Jul 25, 2009 | Compaq Evo Notebook N610c
Screen darkens when i plug my charger i
remove your battery then place new battery
Feb 19, 2009 | Compaq Presario Notebook
Brightness decrese when i plugin the power cord.
Check your power settings, where the little battery is in your righthand lower tray,look for change screen brightness or something like that,there should be 2 columns, make sure u pick the one that says"plugged in" instead of the while running on battery setting.Adjust accordingly.
Dec 16, 2008 | Compaq Presario Notebook
Screen brightness with dcpower
this is normal if you have battery save mode. right click on the desktop and check your settings for screen or go into the control panel and check your battery save modes. not real sure where it is but that should give you a start of where to look.
Jan 03, 2008 | Compaq Evo N610C Notebook
Powered off.
Any beeps when you turn it on? unplug everything and then plug it back in. Make sure the monitor connections are good and that you have it turned on. Again make sure it's turned on. Sometimes it's the simple stuff. Was the monitor working well before it failed? Do you have a video card?
Remove the battery, AC, count to ten and try one last time?
Jan 01, 2008 | Compaq Evo N610C Notebook
Compaq Evo N610C Notebook Logo
91 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
