Question about Gaggia Coffe Deluxe Coffee Maker, Espresso Machine
Replacement Part I need a Coffee Grounds Drawer for Gaggia Titanium
  • Gaggia Master
  • 19,396 Answers
Check one of the followinfg sellers :
Home Page Seaco,Gaggia,Spidem,UNIC,LaPavoni Espresso machines, parts
Gaggia Espresso Machine Parts
or see here GAGGIA Replacement Parts
You usually need to call the seller to get the price and order the part.
Posted on Nov 15, 2008
Gaggia titanium
A nice coffee maker. So, please could you tell us what is your question?
Maybe some operating instruccions?
Check support library:
Or do you want to repair something?
Gaggia TITANIUM Espresso Machine Operating Instructions Manual
GAGGIA
Gaggia Titanium Super Automatic Espresso Machine
Cleaning Gaggia Titanium Espresso Machine Gaggia Titanium Steam Valve Replacement
Aug 03, 2015 | Gaggia Titanium Espresso Machine
Gaggia Titanium Weak coffee medium cup only produces a dash of water and weak coffee, also the ground is very course and I am going through lots of beans done the cleaning and re-calibration but still the...
The coarse grounds is definitely the problem. make sure your machines setting are near 5-8 depending on the beans you use.
You need to make 5 cups of coffee before you see the new grind size. Do not change the grind too often or you will not see what you are looking for.
If the coffee is still too coarse you may need to replace the grinder burrs. http://www.cerinicoffee.com/grinder-burrs-saeco-gaggia-asp.html
or you should take it to a service center.
http://www.cerinicoffee.com/espresso-parts/espresso-machine-service-center-new-york.html
Aug 11, 2013 | Gaggia Titanium Espresso Machine
Gaggia titanium machine, display says dregdrawer missing, even when I've clicked drawer back in place after cleaning it...
Hi
Either your tab is broken on the back of your dredge drawer or your microswitch has been moved from its correct position. There should be a tab on the back of the dredge drawer. If not you need a new dredge drawer.
Sep 13, 2010 | Gaggia Titanium Espresso Machine
The brew unit is not tamping the ground coffe properly.
Give the brew unit a good wash,then lube all the moving parts with food grade grease.
If you are able dismantle the brew unit and wash in warm soapy water,this removes coffee and any old lubricant.
Feb 21, 2010 | Gaggia Titanium Espresso Machine
Brew draw blocked
Ok if brew unit is displayed,the cause is the brew unit needs to be to cleaned of all old grease and coffee grounds.
Once cleaned you will need to regrease the big oring at the top of the brew unit,pretty much anywhere that moves needs to be lubed and the two smaller ones near the back of the dreg drawer.
In some cases a tight or siezed brew unit can damage the main control board.
Feb 02, 2010 | Gaggia Titanium Espresso Machine
Dreg drawer says full although empty
Hi
When you want to empty the grounds because it says to in the menu, REMEMBER TO LEAVE THE MACHINE ON when you remove the drawer. The machine is a counter and when it reaches the magic amount for that machine the message comes on. If the machine is turned off when you pull the drawer out, the machine doesn’t know this and the message will be there when you turn the machine back on. Also remember to leave the drawer out for at least 15 seconds or a little longer so the machine thinks you actually dumped the grounds.
Oct 24, 2009 | Gaggia Titanium Espresso Machine
Gaggia titanium is leaking water
Mine had the same problem. Take out the dreg drawer and brew unit. Then you will see a plastic cover roughly in the middle of the machine (behind where the brew unit was) that is held in place by two philips screws. Unscrew the screws and take out that small cover. It is probably filled with coffee grounds that prevent water from dripping out through a dripping hole. Clean out the grounds and you should be all set.
Gerwin Schalk Albany, NY
Dec 16, 2008 | Gaggia Titanium Espresso Machine
Coffe groungs drawer full of water
when you make ourself a expresso do you have the same amounth of coffee or it mush lower if recently you clean the machine inside check if you screw or put back everything at there right place let me know thanks for using fixya pierre
Feb 11, 2008 | Gaggia Titanium Espresso Machine
Gaggia Coffe Deluxe Coffee Maker, Espresso Machine Logo
486 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
