Question about HP Officejet Pro L7680 All-In-One Printer
Standard black printing has faded to grey.
What was once a vibrant black standard-mode print now only prints in a faded grey. Meanwhile, the color printing is fine. The black cartridge has 60% of the ink left. I have run print diagnostics and print head cleaning through level 2 with no improvement. HELP!
Thank you.
  • 2 more comments
  • Art Nov 20, 2008
    I swapped out the black ink cartridge for a new one, and the printing is still so faded I can't hardly see it. :-(
  • Art Nov 21, 2008
    I emailed HP. I hope their tech rep comes up with a solution, because I love the AIO otherwise...
  • loritag Nov 23, 2008
    i have exactly the same problem.. I would appreciate any solutions anone comes up with.
  • Art Dec 03, 2008
    HP tech support had me replace the remanufactured ink cartridge with a genuine HP Ink Cartridge and also the black/yellow print head (ouch!) and that fixed the problem. It was an expensive lesson. Don't know why -- I was using remanufactured ink cartridges from the same vendor for a year without and problem. Oh well...
  • 104 Answers
Could just be a faulty cartridge?
My hp printer developed a similar fault, and despite all my attempts to clean, realign, whatever, the problem wasn't solved till I fitted a new ink cartridge. It's worth a try.
Posted on Nov 15, 2008
  • eecom Nov 20, 2008
    Thank you for your feedback ... I'm so sorry this quick fix didn't help you.
    Another thing to try is to disconnect the printer, then examine and clean the carriage and the cartridges, as described on this help page for your product group. There is a diagram about 2/3 down the page.
    If this doesn't help, and no-one at Fixya finds a better solution for you, perhaps it is worth emailing HP directly ......
Samsung clx 3185 printing is all faded, colors and black
When you go to print, your printer driver should have quality options. Make sure you're not using "economy" or "draft" mode. Try "quality" mode.
Jan 19, 2015 | Samsung Office Equipment & Supplies
Deskjet 1050A is not printing black. Help?
The black ink cartridge is cloged or empty. Try to refill it in case of empty, or clean in case of cloged ( left the printhead for 1 hour in clean solution or in hot water if you don't have )
All the best !
Jan 18, 2018 | HP Office Equipment & Supplies
You can find the user's guide here which lists all the parts and supplies. Here's the cartridge information from the manual:
  • HP Color LaserJet black print cartridge Standard black cartridge CE260A
  • HP Color LaserJet black print cartridge High-capacity black cartridge for CLJ4525 models only CE260X
  • HP Color LaserJet cyan print cartridge Cyan cartridge CE261A
  • HP Color LaserJet yellow print cartridge Yellow cartridge CE262A
  • HP Color LaserJet magenta print cartridge Magenta cartridge CE263A
You can use the HP numbers to look for original or after-market replacements.
Apr 29, 2011 | Office Equipment & Supplies
My HP 3550 won't print black when it is out of a color.
restore the properties.... set as "print in grey scale" or "print color as b/w images"...
also if the print become less or more dark you can change the settings to print whit more intensity or less...
there is no necesary change all your documents as "watter ink" only change the print options to fade to black
May 15, 2010 | HP Color Laserjet 3550 Printer
Printer printing grey rather than black
ya mine also same when i refilled my catridge. im using canon printer. this is because of the color of cartridge u just refilled..........
Nov 11, 2009 | Office Equipment & Supplies
All colours and black print faded. Black is a
Assuming that you are using original Canon cartridges or a brand of Compatibles that you have used before.
If print results are blurred, colors are faded or not printed correctly, the pint head nozzles are probably clogged.
Follow the procedure below to print the nozzle check pattern, check the print head nozzle condition, then clean the Print Head. You may have to do this 2 or 3 times.
If printed ruled lines are misaligned or print results are otherwise unsatisfactory, aligning the Print Head may improve print quality.
Caution Do not rinse or wipe the Print Head and ink tanks. This can cause trouble with the Print Head and ink
Note Before performing maintenance
Open the Top Cover and make sure that all lamps on the ink tanks are lit red.
If not, see Checking the Ink Status and take an appropriate action.
Increasing the print quality in the printer driver settings may improve the print result.
Sep 30, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Ink cartridges
Go through your standard print procedure. File>print then look for the properties button which is usually on the top right of the window. Press Properties and look for either Printing in B/W or grey scale. That should prevent your color cartridges from printing. After you check that box, you should be able to print black only.
Aug 19, 2008 | HP Photosmart C6280 Printer
Hp officejet 5610 how to select black ink printing only
Start, Printers and faxes, Right-click your printer - Properties, Printing preferences, Advanced, Print in grayscale - Black only...
Nov 05, 2007 | HP Officejet 5610 All-In-One InkJet...
HP Officejet Pro L7680 All-In-One Printer Logo
406 people viewed this question
Ben Johnson
