Question about Panasonic SC-HT680 System
Panasonic SC-HT680 Pro Logic Question
Hey guys, I play a lot of video games through my Panasonic SC-HT680, and can't figure out how to take advantage of the Dolby Pro Logic II. Does anyone know how it works with the aux inputs of my system? This system does not have an optical input, just the old stereo red/white. It has Dolby Pro Logic II, I just have no idea how to get it to work with the AUX channel! odaatpunk@hotmail.com
    Genius:
  • 1,067 Answers
Well if thats a digital fet it wont work with aux in just the dvd player in it onl;y plays that settings usally how it is
Posted on Jan 06, 2008
SOURCE:
CD/DVD PROBLEM ON A PANASONIC SA-HT680
Check your "Setup Menu" with NO DVD in the player. Could be the wrong format, should be 720p or 1080i or 1080p. Are you using Component cables to your TV or HDMI? if Component, check your connections, it is color coded but may be hard to see with most installations. Use a flashlight to make sure colors are correct Red to Red, Blue to Blue and Green to Green. Sounds like you've got cables mixed up. It happens to the best of us! and I do it for a living! Hope this helps
May 21, 2009 | Panasonic SC-HT680 System
DVD player won't work for Panasonic SC-HT680
la tarjeta de elcctricidad se me quemo y no encuentro respuesto
Oct 11, 2008 | Panasonic SC-HT680 System
Panasonic wireless speakers
did you play with the settings on the remote? turn the pro logic on.
Aug 08, 2008 | Panasonic SC-PT960 Theater System with...
CONNECTING THE PANASONIC SC HT680 TO A SONY TRINITRON COLOR TV AND CABLE BOX
audio/video OUT from the cable box to the aux IN on the panasonic right? So you can see the output from the cable box but only sound from dvd. Are you changing the input on the tv when you go from watching the cable box to watching the DVD? the panasonic handles audio, but the video from each goes to two different inputs on the sony. I hope none of this sounds condescending.
Jan 27, 2008 | Panasonic SC-HT680 System
Bit rate showing at top of screen
is it possible to play my cable tv through my system
Dec 03, 2007 | Panasonic SC-HT680 System
Suround speakers and center speaker is not working
Well you can change the setting to hear from different speakers. Play with it you will hear the front on one setting then all 5 on another
Nov 29, 2007 | Panasonic SC-HT680 System
Code for rmote
do serch on makers website like charter.net then see if they have codes for remote for your model dvd player if so they give u code u can email cust support ther also
Oct 13, 2007 | Panasonic SC-HT680 System
Disc tray 1 is blinking with 2 ovals around it, tray not in right Panasonic SA-HT680
I had a jammed disc that was causing this same error message. To remove the jammed disc, remove the top by removing the screws and then you can remove the stuck/jammed discs. For the Panasonic SC-PT750 there are 7 screws, three small silver ones on the back, then 4 black ones, two on each side, all philips head. Once you have that off, gently pry it off starting from the back, the cover is actually hinged into the front plastic piece of the player.
Nov 19, 2006 | Panasonic SC-HT680 System
Panasonic SC-HT680 System Logo
173 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Joaquim Martins
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
