Hey there, lp820 user
I have the same problem you posted in april with my projector(lp820). did you ever come to a resolution with it? I would like any help i can get...my projector was working fine, and all of a sudden this crazy problem happened. im about to buy a new bulb...
thanks for your response
No I was never able to come to a resolution for this projector.  My next step was to buy a new bulb but I haven't gotten around to that since I already have another projector that works.  If you do buy a new bulb, let me know if that fixes the problem.  The only other thing I've heard it mind be was a memory problem or the temperature sensor...  good luck
Posted on Nov 17, 2008
LP820 projector powers up and all is well. After about 40 seconds to a minute it powers down. Control panel lights are on and LCD display says restarting. It comes back on for a couple of seconds and...
It could be are any of the led's blinking. ?
The other thing is to check the bulb is seated correctly in its connector.
Try removing bulb and reinserting.
Also clean the air filters at same time to make sure they are fine.
Please dont forget to vote if you liked my answer
thanks
Feb 10, 2011 | InFocus SP-LAMP-012 Projector Lamp for...
In Focus LP820 The projector will not turn on because the fan won't turn on. What do we do?
make sure nothing is stuck in the fan if you can. it would be helpful to know which fan is not working. the easiest thing to do is to make sure all are plugged into the main board. the next thing is determine which fan is not working, usually it is the lamp blower. at any rate, it will have to be repaired by a technician.
Mar 30, 2010 | InFocus Office Equipment & Supplies
I have an infocus lp820 with what looks like an blue ghost omage in centre of screen,i suspect optical engine or lcd panels
This projector is one I've worked on many times and you are correct. The lcd panels are burnt probably due to a hard shutdown not allowing the fans to cool the inner components done repeatedly over several sessions.
Mar 22, 2010 | InFocus SP-LAMP-012 Projector Lamp for...
Have a infocus lp820 . There is a blue line on the
if it's a pixelated line, it's your lcd panel. if it's a blended, uneven line, it may the polarizer on the lcd panel. either way, you'll have to replace the whole optical engine.
Dec 07, 2009 | InFocus SP-LAMP-012 Projector Lamp for...
Lp820 infocus will not turn on
Some capasitors should be changed in the powersupply and several diodes too, may be. There are temperature mode in the power supply is very hard and those capasitors broke from that. Therefore running of projector is not stable. However if dont change capasitors at time then one diode may be broken and the projector will not start afterthat alwase.
Its not so big work for repaire.
I hope may english is understandable for you.
Best regards. Sergei82@gmail.com
Jun 15, 2009 | InFocus LP 820 Multimedia Projector
The projector is projecting an "out of range" message for a powerpoint presentation. I know it works b/c it switches to DVD just fine. Also, when I unplug the cable from teh comp to the projector the...
Whether you have a laptop or a desktop hooked up to this projector, you will need to adjust the resolution of your desktop to a level that the projector can handle. Without the Model number of the projector, I cannot tell what the resolution should be. I would hook it up and then lower the resolution level of the PC as see if it shows a picture. Does the projector show your desktop image on the screen? If not then changing the resolution will solve the problem.
I hope that I have provided the correct information that will assist you in the resolution of this issue.
If you have any questions, please post back with a comment to this thread.
If I have helped you with your question and/or solved the problem, please take just a moment to rate this post. Thank you!
May 06, 2009 | Computers & Internet
Connecting Dell laptop to Infocus LP820
The USB cable doesn't transmit Video. You need to plug in the VGA cable. The "DVI" port on the LP820 is not a a DVI but a M1 Digital port and won't work with DVI unless you get a converter.
Nov 30, 2008 | InFocus LP 820 Multimedia Projector
Sanyo Projector==No signal
Hi, Perhaps you can try lowering the screen resolution first of the laptop before plugging in the projector and then the Fn + F8. Thereafter, gradually increase the screen resolution until projector stops displaying. The idea is that your current screen resolution maybe too much for the projector to handle. This of course is assuming that there is no hardware problem with the projector. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 10, 2007 | NEC MultiSync GT1150 Multimedia Projector
139 people viewed this question
k24674
jasbo
jasbo
