Question about Amana 24 in. ADB1500AWS Stainless Steel Dishwasher
Amana sofsound 2 latch
The latch on my dishwasher is very hard to open. I have to use a knife to force the handle down and then I have to pull up very hard. Can this be fixed or replaced ? Where can I find a schematic to see how to I can open the machine up ? TIA
  • Anonymous Nov 27, 2008
    I had the same problem - twice - with a similar Amana Sofsound II dishwasher.  The handle is very poorly designed, and the hinge points break after repeated use.  You will need to replace the handle.  I recommend replacing the handle/latch assembly, because it is very difficult to just replace the handle on this assembly.
  • 219 Answers
SOURCE: Maytag Model # MDB7600AWW door will not latch
double check door latch make sure connections are proper if right and still not working probably main board and panel
Posted on May 01, 2009
SOURCE: Amana Sofsound II Dishwasher, heated
push the button for a different option: it's like a radio button in Hypercard: one must be chosen, and choosing one will "unselect" the others.
Posted on Aug 14, 2009
SOURCE: Door latch problem
called a service repairman
Posted on Aug 29, 2009
SOURCE: Amana Dishwasher door will not open. Latch you grap is very loose
We have the same problem and I bought the latch locally for $26.00 now trying to figure out exactly how to get the door apart to replace.
Posted on Mar 04, 2010
  • 6 Answers
SOURCE: Sandy grit left on dishes.
Our Kenmore was doing the same thing, whereas the water temperature was too low....Someone turned down our dial on the water-heater. Turned it up and now all is fine.....
Posted on Aug 05, 2010
My Amana sofsound dishwasher is not cleaning the dishes
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Nov 22, 2012 | Amana 24 in. ADB1500AWS Stainless Steel...
Amana dishwasher handle
Push the screw driver against the center spring mechanism.
May 14, 2012 | Amana Dishwashers
Amana ADB1200AWQ model dishwasher, built -in, bought replacement part for broken door lock handle. Any idea as to steps to replace it?
Just replace my door latch handle for the 4th time in 6 years. its very easy,,, you have the same as i do. latch and handle assembly i got from amana parts on the internet, # for part is W10130697. it is the same i think as a whirlpool part. call 877-827-5003 to order about 48 bucks. very easy to fix. Open dishwasher door and take out the tork screws ,you will see the latch with the 2 micro swithes on both sides, black on the right and white wires on the left. pull off the plugs , put the new door latch assembly in place and put the two plug bacl on micro switches, put back in all the tork scews and your set to go.... good luck... it is real easy.
Nov 22, 2011 | Amana 24 in. ADB1200AW Built-In Dishwasher
Amana Sofsound 1 door will not open
You will be able to open the door by unplugging machine, remove top cover and look down to door. YOu will see a cable running from door latch up towards the motor.
This cable will need adjusting.
Either that or the door latch is broken/scratched.
Hope this helps?
Jul 31, 2010 | Dishwashers
Cannot open the dishwasher door. Maytag Quiet Ser...
This model has a problem where the handle must be depressed fully upwards to allow the latch to clear completely without straining the mechanism. The lip on which you pull open the door gives the operator a better handhold to force it open even when the mechanism is not fully depressed. Do this enough times, and the plastic tabs on the handle begin to fatigue and eventually break. The handle becomes lodged but can be forced down to eventually open the washer. By this time, a specific portion of the latch that depresses a micro-switch will most likely be broken, and the washer won't turn off if the door becomes ajar. Remove the torque screws along the inside perimeter of the door and you can spread the face panel open to access the latch unit for replacement.
May 19, 2010 | Dishwashers
My dishwasher handle is broken and i can't open the door, it is bolted to the counter and i can't unscrew it to pull it out because i cannot open the door
Even with a broken handle, you S H O U L D be able to press the Open latch with a screw driver (flat blade).
If that fails, you can use the screwdriver to force the fastening screws out of the underside of the cabinet (or use a hack saw blade to saw through the screws ...and then pull the dishwasher out....
HOWEVER, you will still need to open the latch with a screwdriver - removing the dishwasher from the cabinet location will not make it easier to open the door
Feb 19, 2010 | Dishwashers
Maytag dishwasher door handle not latching
I have experienced the same problem. You can take a knife and stick the tip under the latch and pull towards you. Will work for a while.
Nov 09, 2009 | Maytag MDB7100AWB Dishwasher
Dec 12, 2008 | Amana 24 in. ADB1500AW Built-in Dishwasher
Door Latch does not open door
I threw caution to the winds and removed the outer panel of the appliance. The plastic latching handle practically fell out--it was broken. Called all local parts suppliers--none had any parts in stock for this dishwasher. Called the manufacturer, who had a part listed on his computer at a distant location. Ordered it, paid for it, and was assured the part would be received within 2 days. Incidentally, you can't order just a replacement latching handle. It is included as part of a component.
Sep 22, 2008 | Amana 24 in. ADB1200AW Built-In Dishwasher
Amana Sofsound II Dishwasher, heated dry display light won't shut off
Aug 23, 2008 | Amana Dishwashers
Amana 24 in. ADB1500AWS Stainless Steel Dishwasher Logo
658 people viewed this question
Top Amana Dishwashers Experts
Oloyede Monsuru
Mike
Kolbrun...
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
