Question about Hotpoint 24 in. DF56 Free-standing Dishwasher
Hotpoint DF56 dishwasher
My dishwasher has stopped working. I haven't used it after for a few months after a kitchen refit. It does a cold wash (progrqam A) properly - water comes in and is pumped out. All other programmes fail to do anything, though the controller on the front goes through the complete cycle and makes all the right noises. No water enters the machine - not even for the cold watch parts of the cycle. I'm baffled and very frustrated. Its ruining my soft hands!! Any suggestions? Angy
  • 3 Answers
SOURCE: DISHWASHER IS LEAKING A LOT OF WATER
I had the same problem with my machine - ie lots of water coming out front about two thirds of the way through the cycle - engineer (local and very reliable) knew as soon as he came in that I had started bying Powerball 5 dishwasher tablets - they produce too much foam (try opening the door during the cycle and see the amount of foam) and it therefore comes out of the overflow parts on the door. I tried Magnum 5 and got the same problem. Now I stick to either Asda's own basic (not the 5) or I buy the Magnum ones and cut them in half. Has never leaked since!
Posted on Aug 25, 2007
  • 183 Answers
SOURCE: It's Leaking Water!
Most common reason is that the lower spray arm splits on the seem and sprays water under the door, to proove if it is this remove lower spray arm and run through program if no leak fit new arm. Regards Advisor
Posted on Aug 31, 2007
SOURCE: dishwasher pump will drain but not force water into spray arms
If the washer is not used regularly the shaft can stick to the seals and prevent the motor from spinning. This happens quite regularly for me if I don't use the washer often. You can just take off the bottom panel - after shutting off power to the dishwasher - and access the motor. you should see some fins and then just try to spin the motor by hand. It usually takes about 90 degrees of rotation before the motor breaks free from the seal. You'll have to fight through the spring-like resistance created by the seal-shaft adhesion. After it breaks free the motor spins freely and you should be all set to go. I haven't found a more permanent fix for this other than running the dishwasher more regularly.
Posted on Feb 09, 2008
  • 1462 Answers
SOURCE: hotpoint aquarius dwf30 dishwasher
you can plumb into hot but there are some snags
first hot water pressure is often a lot lower than cold so the machine may take a long time to fill
second if the water is too hot it will destroy the resin of the water softener and you will see brown marks on the crockery.
third it a bit uneconomical as you will use a lot of hot water
Posted on Jun 25, 2008
  • 59 Answers
SOURCE: Hotpoint Dishwasher DWF 30
Just one question is the water to the unit turned on ? some times a unit will have a fail safe protection device where it would not start the system if there was no water pressure to prevent damage to the unit, but given the symptoms i really don't think thats it.
It sounds like there may be an internal fuse in the dishwasher circuitry that has blown and needs to be replaced.
Unfortunately without the circuuit diagrams its impossible to say if that is so. the manufacturers today don't supply circuit diagrams with the appliance and they tend to send a repair agent out who changes the whole board rather than just fixing the one problem.
If your adventurous you can try starting to apply power to various parts of the unit to see if they work - i.e. i am sure the pump works if you can get the appropriate power supply to it - but your risking some serious electric shock and issues with blowing things up.
Posted on Aug 14, 2008
I Have a Hotpoint BCI450 - it was conneccted by a previous owner and we do not have the instructions. A few nights ago the washer stopped washing 1/2 way through a progaram leaving a few inches of water...
The problem is associated with the main program controller unit and so it is needed to remove the panel and see if there is any moisture present that had caused the error.
Leaving if off overnight would have resetted the machine or made the panel OK.
So after cleaning if the panel does not work to trigger the inlet then the controller unit must be checked.
Please check on the links below for some tips:
http://www.espares.co.uk/advice/dishwashers/a/3/171/common-dishwasher-faults.html
Sep 02, 2011 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
Lower seal on door leaking
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Feb 26, 2011 | Hotpoint 24 in. DF56 Free-standing...
Have a hotpoint dishwasher full of little black
I have a Bosch SMS 4012 works fine till cycle finished. when I turn it off it trips the power safety switch at the switch board. To prevent trips happening I have to switch off at the power point and unplug .The washer is 20 years old and the problem started around 3 months ago.Is it a major problem.
Frank. C
Feb 15, 2010 | KitchenAid Dishwashers
Flashing lights on Hotpoint FDW20P Dishwasher
No solution! tried resetting to factory defaults but ended up that even the drain pump stopped working. after flooding the kitchen (nearly). I decided it was terminal and am loking for a new dishwasher urgently as I type. Cheers.
Feb 18, 2009 | Hotpoint 24 in. DWF32P Free-standing...
HOTPOINT aquarius WF541G
most likely suspect is the heater. undo wires from heater and see if fault persists. if not, heater is down to earth and will have to be replaced.
another possibility is a leak causing some of the wiring to be wet
Jun 28, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint dishwasher bci450
Here are the eco related error codes for your washer..
1)Light 3 (eco) flashes. Water is present in the flood catching tray at the bottom which usually indicates that there is a leak somewhere. More often than not this is just a pipe with a poor fitting and simply tightening the clip is enough to stop the leak. Our machine had a very slow leak from one pipe (not enough to trigger the alarm) which was fixed in this way. The leak is detected by a small float switch located in the flood catch tray.
Undo 4 screws on the metal plate under the dishwasher 3 at the front 1 at the back, this reveals The pump check the seals are in place on the waste pump.
2) Wash indicator lights 3 + 5 (eco + pre) flashing rapidly. Filter is clogged. Pull out the filter and clean it.
3)Runs for approx. 3 minutes and then stops. Lights 3 + 4 (eco and fast) flash. Probably caused by being plumbed into a hot rather than cold water supply. The incoming water is hotter than required for the wash which causes the machine to cut out. Plumbing the machine into a cold water supply will fix the problem with no apparent long term problems.
May 23, 2008 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
Hotpoint aquarius dwf30 dishwasher
May 18, 2008 | Hotpoint 24 in. DWF32P Free-standing...
Hotpoint Dishwasher 7830 Deluxe
you can change detergents i recommend eletrosol tabs they work great.Also run a mixture of vinager about 2 cups through the wash this should help
good luck
Dec 08, 2007 | Dishwashers
Hotpoint DF32 Dishwasher
I have a similar problem.When the water stops entering,I momentarily turn on my main kitchen cold water tap, and believe it or not,the machine carries on working!!
Nov 04, 2007 | Hotpoint 24 in. DWF32P Free-standing...
Hotpoint 24 in. DF56 Free-standing Dishwasher Logo
54 people viewed this question
Top Hotpoint Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
