Question about NetGear WGR614 Wireless Router
Cannot connet my laptop to he wireless router
It keeps saying it is acquiring network address. hey! it keeps saying aquiring network address and so many people have told me that i need to reconfigure my wireless adapter settings but i dont know how to do that!! if any's got some simple steps that i can follow then i would be very grateful! i am able to connect to the internet through my router and enet wire and i can connect on to some 1 else unsecured network but i want 2 connect 2 my own!! so please help!! thanks
  • gups1 Nov 15, 2008
    hey!! thank u sooooooooooooooo much! i changed some settings and it seems 2 be working! but do u know if it is ok 2 use the WEP security setting instead of the other 1? I'm well happy!! THANK UUUUUUUUUUUUUUUUUUUUUU
Thanks again! Great serivce :)
Posted on Nov 15, 2008
  • 104 Answers
Hi gups1, I will try and help you make a start.
It would help to have the name and model number of your router if possible (eg Netgear, Linksys?)
First, look at the router itself. Is there a label on the base of it? Sometimes this tells you the address you need to get at your wireless settings. It will look something like http://192.168.0.1 If you have a manual, you should find this info in there.
You need to type this address into a web browser, as if you were going to look at a web page (but note, there is no 'www' in the address).
If you succeed in doing this, a box pops up requesting your username and password. If you don't know this, again look at the base of the router or in the manual.
If you succeed in logging in to your router, you will see a menu where you can configure or change your settings. Come back if you don't get this far, or if you need more help at this point.
  • 1 more comment
  • eecom Nov 15, 2008
    Sorry, I've just seen you've given the model number. :)
    .... so this page should walk you through configuring your settings:
    http://kbserver.netgear.com/kb_web_files...
    Come back if it doesn't solve your problems though.
    :) Hey, that's great news! I'm really pleased for you!
    WEP security is OK, but not strong and easy to break into. Try the WPA-PSK option for stronger security.
    You need to enter a passphrase when you select this, such as a sentence (no spaces) with some numbers. For example, 23happyHolidaystoeveryone56777.
    This phrase is also called a network key. You need this when you next log on to your network, then your computer can be set to 'remember' it and connect automatically. Note down the passphrase/network key carefully as you'll probably need it again!
    Good luck, and a big thank you for the feedback. :)
Says i am connected but when i open firefox it says that i have no network connection... the wireless icon also says it is acquiring ip address
if the message aquiring ip address comes in computer then it says that the wireless router is not giving an ip address to your computer.... check if any static ip address is assigned to your wireless connection...if so change to "obtain ip address automatically".... right click on wireless network name> goto properties > authentication tab> uncheck "enable IEE athentication"
now try to connect again,still not restart the computer once...... this will resolve the issue.... still if it is not connected then check for the security settings in the router... if your computer is XP/MAC, it may not recognize WPA security type.... change it to WEP type and try to connect again....
Apr 19, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
I can not connect to my netgear wgr614v6 with my hp netbook. I can connect with my other laptop and the netbook has been connected before. It keeps saying "acquiring Address"
If you're trying to connect wirelessly, and it says "acquiring address" and never connects, it's most likely because your wireless network has an encryption key enabled, and the encryption key on your laptop/netbook doesn't match. You should disconnect from your home wireless network, and then try to re-connect to it. Verify that you're using the correct wireless key to connect. If that still doesn't work, you should reset your router to factory defaults so that there's no wireless key required to connect - and then try again. If you want to put the wireless key back, you can run the CD or connect to the router using the web interface and configure it again.
Mar 07, 2010 | NetGear WGR614 Router
Cannot aquire ip address from wireless router
Hi, If your newer usb wireless adaptor does not have the same settings as your router this is the problem you have. First make sure you have installed the cd software that came with the usb adaptor without it plugged in. After that is complete make sure the wireless adaptor is seen by the computer it is attached to. Then you need to open the settings of the usb adaptor and set it up same as your router's settings. This includes the WEP security password if you use it. Good Luck.
Sep 19, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
Aquiring Network Connection over and over. RAWR
How many DHCP devices are there on the network?
There should be only one. Try disabling the DHCP in your device, then your neighbours router should issue IP addresses and all will be ok.
Apr 26, 2009 | NetGear WGR614 Wireless Router
Cant connect router & dsl modem, cant aquire ip address
Try typing another website on the address bar.
Try checking on your router advaced setting make sure that Mac filtering is off under network filter.
Make sure all other settting on the advaced setting are also in default setting.
Jan 06, 2009 | D-Link 802.11g Wireless Router WBR-1310...
If compuetr always saying acquiring network address you can try firt restarting the computer, but if still wont get a valid ip address, you need to adjust the wireless settings of the router and after that try to reconnect to the wireless network....
Oct 25, 2008 | NetGear WGT624 Wireless Router
Acquiring Address Problem
you will need to make sure that DHCP is enabled within the routers settings as this will tell the router to assign ip addresses automatically, then go to network connections, right click on your network card>properties>TCP/IP line>properties and tick 'obtain an ip address automatically', click ok, close window and restart pc.
Sep 24, 2008 | HP PAVILION A6230N DESKTOP PC
Acquiring network address
It would be best if you have another wireless computer maybe a laptop so you can further isolate the problem, you can check if the other wireless will encounter the same problem. If that is not possible, make sure to check the wireless settings on the router, take note of the ssid, channel and wireless security. Try to reconnect again. if same problem exist, try changing the channel on the router.
Aug 25, 2008 | Computers & Internet
Laptop can not connect to router
If you care to try, manually enter IP settings in your laptop as follows:
IP Address - 192.168.1.2
Subnet Mask - 255.255.255.0
Default Gateway - 192.168.1.1
DNS - whatever your ISP is using
In your Internet Explorer >
Tools, Internet Options, Connections tab, LAN settings button, check "Automatically detect settings", OK, Advance tab, check Use HTTP 1.1 through proxy connections.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 23, 2007 | Linksys WRT300N Wireless Router
Acquiring ip address
you may need to set a key on your router and PC (recommended for security anyway). Access your router with your internet browser (default is often 192.168.0.1 - listed in your manual) and get the long default key. Put this key into your wireless card set up and reboot.
Nov 23, 2007 | Computers & Internet
NetGear WGR614 Wireless Router Logo
64 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
