Question about GE JKP15 Electric Single Oven
Won't unlock for a week...then F3
The oven's been locked for over a week tonight it just started beeping it said F2 till i messed around w/the buttons then it went to F3 and wounldn't stop beeping till i set the timer. i have about 9 hours and 45 min till i think it'll start again. help!!
Or oven says PF we dont know what that means and our oven doesnt work changed all fuses need help
Posted on Dec 10, 2010
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 35 Answers
INGLIS Royal 100 STOVE F1 F2 F3 ERRORS
Mode lUP 48500 ( thats eye you, not ONE U )
I got the dreaded F3 error on the Display Panel,
every time I pressed BAKE or BROIL, BUT, I could
hear the three relays click in, and then kick out in
sequence, just before the F3 appeared.
I called Westinghouse ( that services INGLIS ) and
was told that F3 " means unpug for 1/2 hour and then
press CLEAR 5 Seconds to reset ". Which is nonsense.
All functions on the clock and timer work fine, and the
three relays were working, so its not a computer problem.
I called service REPAIR companies who said it was the
THERMOSTAT, and replace it - $147.99 ... The Glass tube
of the display is $200 with no circuit board, the relay board
is $300 and the computer/display is $400.
I did tests on the thermostat, first heating it with a propane
lighter, and it raised from 475 Ohms at room temperature,
to 600 ohms, so I knew it was functioning.
Then, I plugged in a variable resistor where the thermostat
plugs in. I went from Zero Ohms resistance to 5000 Ohms in
200 Ohms steps.
Zero Ohms ( equal to burnt out or unplugged) gives you
an immediate F1, which you cannot clear.
From 100 Ohms to 400 Ohms, you get Error F2, which
means thermostat too low.
From 400 Ohms to 665 Ohms there is no error.
At 665 Ohms, the BAKE will beep twice, stating that you
are setting the temperature at or lower than the actual temperature
of the oven ( you cant set the oven at 200, for example, if it is
already at 450 Degrees )
Using this 2 Beep code, I raised and lowered the resistance
and made a graph of the reading on the display versus the
OHMS that the thermostat would send to the controller:
665 Ohms = 170 Degrees Farenheit, which is the
lowest reading in the BAKE MODE.
800 Ohms = 240 Degrees
1100 Ohms = 380 Degrees
1400 Ohms = 500 Degrees, which iis the maximum that
the unit showed in the BAKE MODE.
1430 Ohms to 2750 Ohms, there was no reading, an NO ERRORS.
ABOVE 2750 OHMS, the F1 ERROR appeared again, meaning
thermostat out of range.
Note that the computer module supplies 5 volts DC to the thermostat,
to see the changes in current with changing resistance.
You can easily check the thermostat to see if it is OK, with an
Ohmeter across the thermostat, which should read about 475 Ohms
at room temperature. If it reads Zero, it is burnt out. If it reads
over 2750, it is defective. Check to see if the thermistor in the
tube is SHORTED to the steel outter case as well, as this should be
infinite ohms ( no contact )- if it reads ZERO it is shorted to case.
I found that on the Internet, there are hundreds of people looking for
the F3 code for the ROYAL 100 ( model number IUP 48500 )
and a general search shows that for 400 " other" models of all kinds,
F3 = REPLACE THERMOSTAT ! Not on this model, and all typical searches
for technical support or diagrams or troubleshooting did not even list
the Royal 100 AT ALL, as if it never existed.
I then did tests on the relay board, and replaced the capacitors, a few diodes,
some resistors that were a bit out of value, and two transistors that were
a bit out of value. There was no change in F3.
I cleaned the contacts on the three relays using a typical board fingernail
file that ladies use for their finger nails ( I keep a supply for cleaning
relay contacts, since there is sandpaper on both sides, and they are
tiny enough to fit between most contacts ). THEN, I realized that the BROIL
contacts were bouncing apart - they were too far apart, and not closing
properly, so I bent the stationary contact a bit closer, and plugged in the
stove = NO ERRORS..
I analysed the circuit, and after turning on the 3 relays ( NOTE, when you
turn on BAKE, as in a regular oven, THE BROIL ELEMENT goes on at first
to quickly help the BAKE element get the oven up to temperature )
there is a feedback circuit that feeds 250 Volts back into the 5 Volt computer
chip ( ! ! ! ) It uses two 22 Meg Ohm resistors in series for a total of 44 Million
Ohms, which shows about 46 volts accross the resistors. Since the gas
tube display uses 30 volts to light up, the 46 volts is within the computer
board's ability to lower it enough to feed into the computer. There are transisors
on the back of the control board and Zener diodes etc. to " compare " the
voltage, where 46 volts in = 250, and Zero volts, means that the element
is burnt out, the element fuse in the fuse panel is burnt out, or, the relay
contacts are dirty. The relays are absolutely standard 24 volt relays,
with a plasic cover that snaps off if you pull and wiggle it. You will see
the round silver contact pads are blackened and probaly pitted.
Sand these flat until silver/brass shiny, and test to make certain that
when you press the metal lever that the magnetic coil pulls DOWN,
that the contacts touch! If they do not touch tight, bend the
stationary contact in a tiny bit and test again.
You can first check the fuses - there are two 120 volt fuses in the
fuse panel that give you 250. Then, you can unplug the stove,
and use an OHM meter to see if the element is burnt. The two types
of elements I checked were 3000 Watt at 18.7 Ohms, and 2500 Watt,
at 48 Ohms. If the elements are burnt out, you will get ZERO ohms.
If the element is burnt internally through the insulation in the tube,
and shorting to ground, between the ends and the steel back of the
stove ( ground) you will get a reading of X amount of ohms ( which
normally should be ZERO ) If the element is burnt or shorted to
ground, replace.
The F3 error is a really dumb mechanical errror of whether the 250 volts
is on the elements. It does not involve the computer or the thermostat,
or the relay " electronics" at all - it is just simply 3 contacts that supply
250 Volts, and whether or not the contacts work, the elements work,
or the fuses work. This the same 250 Volts that is on an ordinary
dial stove, and the dumbest part of the whole unit.
When I called service, they said they would order the $147.95 temperature
thermostat, and " see if this fixes the problem", if not they would start
replacing the modules - $300 and $400, plus labour, plus tax etc., and
since the problem was on the module, this would cost $147.95 + $300,
plus $75.00 for the first 15 minutes, and $15 for each additional 15 minutes,
for a total of about $466 dollars ( CDN ) which is about $460 dollars US.
A package of 25 fingernail files is $1.00 at the dollar store. That is all that
it cost to fix the problem. You need a square ( Robertson ) head screwdriver
to remove the 7 screws on the back panel, and then you wiggle the
covers off the relays, and clean them. It takes 10 minutes.
good luck ! Damned the manufacturers for not putting this information
in the user manual.
Robin Graves, January 2008, kidbots.com
Posted on Feb 01, 2008
  • 3 Answers
The F2, F3 error is an indication the Temp Sensor(6 inch device inside the oven top) i not working/connected.
Remove oven from wall an measure approx. 1000 ohms across this sensor at the location where it plugs to the Clock Control Board.
Posted on Dec 09, 2007
  • 833 Answers
Try to cut power to the unit for a while. Also, check for loose electrical connections nearby and on the stove (unplugged or breakers open!!). Restore power. Fixed..done. Not fixed, change circuit board.
Posted on Dec 07, 2007
F3 f4 gaas oven when preheated these numbers appear it beeps and shuts off
Hi, replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
Jan 22, 2011 | Magic Chef Ovens
Amana Self-cleaning Oven flashes F2 and F3 and beeps. It doesn't get real hot. Although it does heat up not the appropriate temperature.
Hi, F2 error code on the Amana Oven means "Oven too hot" You have to replace Oven temperature sensor to fix it.
F3 error code means "Open or shorted oven temperature sensor". Yo also have to replace Oven temperature sensor to fix it.
Summarily, both code has to do with the temperature sensor which you need to replace...
Oct 23, 2010 | Amana Ovens
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
Oven control lock beeping along with F3:E4 flashing on the display
Hi-- The code described; F3 E4  indicates an open circuit- oven sensor.  As far as oven problems go this one is easy to fix. -------Unplug sensor and check resistance. Normal is around 1100ohms. ---If open, then replace with new part.  <This will solve the problem>.  You did not provide any other information besides 'beeping' and 'F3:E4'.  A simple Model # from the tag on unit is required for any service or information.  However, since this is a specific fault code, the oven temperature sensor is the most likely suspect. Please acknowledge this post. Solution is to replace the oven temperature sensor.  Thanks-  Ed
Mar 30, 2010 | KitchenAid Ovens
How do i unlock my stove, it is a ceran hotpoint stove. while cleaning it locked and started beeping a flashing F3 . what can i do.
f3 fault code / open oven temperature sensor .) this sensor tell the E O C ( clock ) oven tempts . it will have to be replaced .. ther could be other problems with oven but first things first replace sensor and see how it works .. **** . hop this will help .
Dec 04, 2009 | Ovens
Beeping with 'f2' & 'f3' message when cleaning but did not finish cleaning. Oven now cooled but still locked.
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$@#
May 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
F2 f3 starts beeping when using stove or oven
F2
Oven temperature too hot
Check and replace oven temperature sensor (RTD).
F3
Open oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
So i suppose its a sensor replacement is necessary.These are the fault code explanations by frigidaire.good luck with the machine.Please do post results and comments.
Apr 15, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
F2 and F3 error messages on Tappan wall oven model 12-4980 10/03
These are the F2/F3 error codes for a Tappan oven
F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
please take the time to give this solution a fix ya rating.
clarkco
Feb 09, 2009 | Tappan Ovens
F2 and F3 code appearing along with annoying beeping
i think f3 error code has something to do with the temp probe maybe it is the problem. the temp probe is located if you open the door directly in the back wall. it looks like a prong. should read 1100ohms the f2 error code though usually has something to do with the keypad i would check all the connections maybe they are loose.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
GE JKP15 Electric Single Oven Logo
649 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
