How do you reset the warning to replace lamp.i replace the lamp on my pt-50dl54 but the replace lamp still comes on
  • ckoss Jan 20, 2009
    Any clues?
Turn your television on
Press volume down on the TV
Press the mute button on the remote
Green LED light on power button will flash
-timer now reset (no more warning light)
Posted on Jan 20, 2009
  • rick9268
    rick9268 Dec 22, 2012
    This is the one that works,Thank You very much !!!!!
How to reset lamp timer panasonic pt-50dl54 ty-la2004
Consult the owner manual or call Panasonic customer service for the method for this model.
If I see one I do not know, I also will Google the model number with "reset lamp timer" etc. if the Panasonic line is busy.
Dec 19, 2012 | Panasonic PT-50DL54 50" Rear Projection...
PT-50DL54 50 in. Rear Projection HDTV-Ready Television: started to get dimer and dimer and finally picture...
You should have received a message on the screen about replacing the lamp. Also, the LAMP led on the front should be lit in red.
You can replace the lamp assembly easily for about $150 - $250.
Don't try to replace the bulb only.
A new Panasonic Plasma TV will cost about $1000 and good for another 5 to 6 years.
May 05, 2010 | Panasonic PT-50DL54 50" Rear Projection...
Replace lamp flashed today, how long til i lose picture pt 50dl54
It's a timer, it counts the passing of time. The timer does not indicate the condition of the lamp. You may have a day or a year. Best advise would be to have a lamp on hand for when the lamp failure does occur.
Apr 16, 2010 | Panasonic PT-50LC13 50" Rear Projection...
I am about to replace a DLP lamp. How do I reset the lamp time on a Panasonic PT-50DL54J, using a TY-2004 lamp?
This all probably comes a couple years too late, but when you install a new lamp, you’ll want to reset the hours on the counter your television has. Doing this will allow you to avoid getting any messages about the lamp needing to be replaced despite you having a new lamp inside your set.
If you need to get into the service menu, you can do so by following these directions:
With power on, hold down VOL minus button on projection display and hold down the PIP or SPLIT button (try both) on the remote simultaneously for more than 5 seconds.
Jan 31, 2010 | Panasonic PT-50DL54 50" Rear Projection...
Resting my lamp?
Hold the Volumn Down button on the TV,
and the MUTE buttom on the remote for 5 seconds.
Jun 23, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Replaced lamp and still no picture
You need to reset the lamp timer.
Hold the volume down button AND the Mute button on the remote for 5 seconds.
Jan 03, 2009 | Panasonic PT-50DL54 50" Rear Projection...
LAMP REPLACE FOR PANASONIC PT-50DL54 INSTRUCTION
Pull off the panel below the screen.
Remove the two screws hold the 2nd cover from the left.
Remove one screw from the lamp module and pull it out.
Buy the lamp module. It is not worth it to try replacing the lamp. You can damage the bulb easily.
Aug 08, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Lamp timer reset?
I believe on this set it is actually in the customer menu. About 4 screens and it is second option to reset the lamp timer.
Jan 21, 2008 | Panasonic PT-50DL54 50" Rear Projection...
PT-50DL54 panasonic 50" DLP
to get rid of "replace lamp" push the blue action button on the remote and the volumn down on the tv set for a couple of seconds. this has to be done at the same time, good luck.
Bob
Dec 09, 2007 | Panasonic PT-50DL54 50" Rear Projection...
Televison & Video Logo
335 people viewed this question
Top Televison & Video Experts
