Question about Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Ghosting of black and darker colors. some times the picture is fine
  • dewomb31 Nov 16, 2008
    toshiba regza 42
    toshiba regza model# 42 lx177 built in 8/07
    Sergeant:
    Champion:
  • 227 Answers
Hey hello, now what kind of tv is this and what's the make and model number that will help me and you to try to fix this problem, UNITED WE CAN JAJAJAJA
Posted on Nov 16, 2008
  • ESTEBAN MERINO
    ESTEBAN MERINO Nov 16, 2008
    ok i have not seen this problem on this tv yet, but for your description it sounds like a problem in the video board.some techs call it digital board other techs call it signal board.it is hard to tell when you don't see the actual problem,my sugestion is :try to see if does it on all inputs like HDMI,TUNER, COMPONENT, A /V to have a better idea of what we are dealing with.
Picture got very dark
I assume you are talking about your TV. This happened to me. My TV got darker and the people were ghost like, the colors were all wrong. I was told it was the y-sus board. I purchased a used y-sus off eBay. After install the picture was still bad. Was told the screen was bad. Could have also been the board I bought was bad. I have no way of testing it. Was fun trying to fix, but just moved on to new TV. They are surprisingly affordable. Good luck.
Apr 20, 2016 | Samsung UN32D4003 32" LED 4003 Series TV
RCA D56W20, Works OK, so long as the "black level"
The green CRT has an issue and will need to be replaced. It could be the Green CRT drive board but doubtful as your describing the classic sign of a CRT thats developing a Short . You can get replacement green CRTs and CRT drive boards from www.tvrepairworld.com
Oct 14, 2011 | RCA D56W20 56" Rear Projection Television
My LG TV has suddenly become darker all across the bottom of the screen (10cm strip) it still has colour but is darker. In left hand corner it is considerably darker and depending on what you are watching...
Hi; your TV has burn screen or traces.it comes from one image left on the screen for too long, it can get burned into the screen, making it visible at all times. You can actually eliminate most screen burns with the use of a PC computer and a black and white screen saver. This trick eliminates screen burn after a period of several minutes because the black and white screens flash quickly, removing all traces of color from the screen. This will eventually eliminate any burned images on the LCD screen. you can do it by creating a DVD picture slide with only black and white image. you can use a computer to make DVD picture slide first go to paint brush and draw only white then save as white.jpg. second burn it into nero or other dvd burner third play it to your DVD player connected to you LCD TV.it has to be played in full screen let the white image display on your HDTV for several hours or even overnight. It should remove any burned-in images or ghosts. hope this help...............
thanks....
Sep 13, 2011 | LG 32LD350 32 in. LCD TV
My HLP5063W tv comes on and works for 3 to 5 min then the pictures gets dark and the colors are distorted. The remote no longer operates the set and I can not turn it off using the front or side switch. ...
It sounds like your lamp is about to die out,this tv lamps are good for 6000-8000 life hours which is a average time of 2-4 years old and with time the picture starts to get darker and darker until one day black screen. Try Encompass .com ; shopjimmy.com
Jun 11, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
What is a good Microwave Leak detector - make  absolute measurements? Can a cell phone be used to detects leaks from Microwave ovens.?
I replaced two convergence chips the resistors were all fine. This took care of the 3D look. I also replaced the coolant in the blue and green although it was the blue which was badly contaminated. The picture is now clearer than before but I am unable to get color. I can see vibrant colors when I pull up the TV's menu. I can see the colors in the convergence menu as well but no color in the picture. The color controls only make the picture brighter or darker. It is sepia in color not black and white. What could this be?
Feb 22, 2010 | Philips 51PW9303 51" Rear Projection...
Ghosting image on canon c3220
Suggest to check the transfer unit. Especially the transfer cleaning blade..
Jun 12, 2009 | Canon imageRUNNER C3220 Color Copier
Blurry text print with ghost image
Hey,
Your problem could be because of bad alignment. That means paper alignment and printer alignment don't match. There will be instructions in,your manual to properply align your printer.
Hope this helps.
Thanks
Apr 15, 2009 | HP DeskJet 3745 Printer
Kv-36hs20
Have you tried disabling SVM (scan velocity modulation)? Often touted as a "feature" of TVs, it's a way of artificially making a picture appear sharp. Totally unnecessary. When SVM (sometimes called VM) is on, it can lead to some color bleeding around edges.
Mar 24, 2008 | Sony FD Trinitron WEGA KV-36HS20 36" TV
Loss of color picture
I have a blue-ish yellow ghost tint which just appeared on my 51" 51SWX20B made July 2002. Did the magic focus got a number 5 at the end. Did you get a number when you did the magic focus?
Dec 01, 2007 | Hitachi 51SWX20B 51" Rear Projection...
Picture has gotten darker
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Nov 26, 2007 | Hitachi 53SWX12B 53" Rear Projection...
Toshiba REGZA 42 in. Flat-Panel LCD HDTV Logo
336 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
