Question about HP Pavilion a305w (DM181AR) PC Desktop
My Computer will not work fans did work but have also now stopped
Hello everyone having some serious problems with my computer I've had it about fve years and never a problem untill now. Tryed to clean it the other day and made a mistake of rubbing off the heatsink greese because it was all dry and was missing in areas, replaced heat sink after cleaning the whole board with canned air. when I fired it up nothing. thought that i might of fryed the processor so got a new one P4 3.2GHZ upgrade on last which was P4 2.9GHZ. got some more greese and installed the new processor. Nothing, I found that the psu is giving power to all areas (Hard Drives, Floppy Drive, Mother board on switch and cd rom). I did take all the wires out and put them all bck in and one the second or third time the fans worked and hard drives spun then put it all back in and together and nothing just sometimes the a fan which is powered from one of the power ports out of the psu twitch's. the computer is a packardbell Imedia 1503. Please any help would be great I feel it's the mother board because the processor is brand new and sealed.
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    does the motherboard beep at all? if so please describe them
  • 300 Answers
You may want to make sure that both the atx connector and the additional 4pin p4 connector are tight. Also, either tighten or remove all expansion cards because one could be loose or bad. You may also try re seating the cpu. It could also be the voltage switch on the back of the power supply (if it has one -- some do some dont). There could also be something shorting between the motherboard and the case.
Could also be the case that the initial cpu is fried due to no grease and the new cpu may not be compatible with that motherboard. Make sure that if that motherboard has jumpers that they are set correctly for you specific cpu.
YOu can find documentation and driver for your product here.
Hope this helps. Please remember to rate this information.
Thanks
Posted on Nov 15, 2008
Fujitsu Siemens CPU Fan does not spin?
First check to make certain the fan is plugged into the motherboard.
Follow the connector from the cooler unit to the m.b.
When you've located the proper plug - unplug it and then re-plug it back in, making sure it is firmly plugged in (make sure you turn off the power and unplug from the wall before doing any of this).
Then look at the fan closely and make sure it's not overly dusty or dirty.
This can clog up the fan and cause it to stop working.
If you've done all this and powered back up, and it's still not working - then you need to get a new fan.
Do not run your system without this cooling fan because you can fry your CPU.
DO NOT ATTEMPT TO OIL OR LUBE FAN THIS CAN END IN DISASTER
hope this helps
Aug 15, 2012 | Computers & Internet
I have a acer travelmate 5740. When I turn it on the fan whirs for 5 secs then stops. The computer doesn't start and the screen remains black. I've tried holding the power on button for 60 secs as...
hello sir!
it seems that *********** borad or power board isn't working. just take it to some machenic he will repair it in about 20$ or less..
thank you.
Apr 18, 2012 | Acer Computers & Internet
So I am having a problem with my A/C that everyone says is my cabin air filter. When I am parked, the A/C hardly blows at all, but when you speed up it starts going. By the time you hit 70 mph there's...
I would put some thought into replacing the fan or the fan switch first. If the fan works OK when in heat mode, then i would suspect the A/C controls as what you say tells me the fan is not working. Only forward motion of the car causes air to pass through. Your vehicle has a cabin filter, NAPA part #
4814 but it would surprise me that its being blocked could cause the problem you described. In fact I do not think any cabin filter could be blocked to that extent.
May 17, 2011 | Chevrolet Silverado 2500HD Cars & Trucks
ATI graphic driver not working properly. while playing games my computer stops. i have vista business.
Hello a4akhtari, Your computer could be over heating. Put a Fan next to your computer to stop the heat. If that's not the problem, You will have to reinstall your computer, Or reinstall the ATI drivers and reinstall them. I hope this works for you :)
- Steven ASAP
Here to help!
Apr 23, 2011 | Computers & Internet
Hi, We have an Acer Aspire 5051 AWXMi laptop, made in Nov 2006 (if I interpret the Manufacturers label correctly) which we bought in early 2007. Up until now the unit has worked well, until recently,when...
Reboot the machine and press either F2 or DEL to enter in BIOS.
Under one of the settings ( it's in advanced -> fan settings. in my current bios ) You should be able to choose what percentage the fan speed runs at.
If this doesn't help, some serious hardware damage may have been done when the laptop overheated.
Installing software will not not fix the issue. Most of the information on these types of programs are all visible in the bios under hardware status anyway.
hope this helps,
Dan
Sep 10, 2010 | Acer Aspire 5050-3242 Notebook
I have an Acer Aspire 5735Z. The cooling fan works intermittently. I am not sure if I need a new fan, or the problem could be more serious. Thanks for any help. divakathryn60@gmail.com
sometimes the fan races if you like, sounds loud, then when its cooled the comp down, it stops or goes slowly, until comp gets hot again. hope this helps, make sure you always rest the computer on a hard solid surface never a soft 1 like beds or cushions ect.
Apr 27, 2010 | Acer Aspire One PC Notebook
6 long beeps Dell GX280 -- unsolved Please help auntie! I have four PCs model RB-DT-OL-Dell GX280 ? they are fairly thin and light, you can open them like a suitcase. They worked just fine, then all of a...
I had 1 long beep, 3 faster beeps, then 2 beeps *I think*, and also my fan was going crazy fast - like someone else said "a vacuum cleaner"...
Well, I reseated the memory and problem was gone - it did seem like the memory was kind of "loose" - perhaps from shipping (bought this used).
The link to Dell's website was good for the beeps AND the "ABCD" codes reading on the back. Thanks very much! God Bless.
Jun 27, 2009 | Dell OptiPlex GX280 PC Desktop
You may have some machines with the bad capacitor problem. Check out saome pictures from my web site at www.ccl-la.com/badcaps.htm Open your computers and see if you have any capacitors that look like the pictures. The Dell GX270's and the GX280's have the problem. There are several places on the internet that can repair your boards if you find that this is the problem. I hope this helps.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years providing PC and printer support/repair
Jun 20, 2009 | Dell Dimension 4300 PC Desktop
My five fans stopped working
As long as the CPU fan is operational your OK - the land in the power supply for the 12VDC fan voltage probably got hot and has an intermittent connection. You could try to connect the fans to another power supply connector - but as far as the computer itself you should be OK
Nov 19, 2008 | Aspire Digital Aspire X-Navigator,...
HP Pavilion a305w (DM181AR) PC Desktop Logo
112 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
