Question about Sony KP-61HS20 TV
WONT TURN ON
I have a sony kp-61hs10 and will not turn on,,,,,,,,, it is blinking once a second, every second with no delay,,,, the sony blink codes says its "no reply from jungle IC301 (data bus is busy,shorted to ground or high yield) IK video path is defective"...... What does this mean and can I fix it, or is it going to cost me a ton of money????? I am very handy and can fix anything............ Please let me know if this is worth fixing, or having someone come out or should I trash the unit and replace it.....Thanks Tom
    President:
  • 3,130 Answers
If you know how to trouble shoot solid state electronics and know how the curcuits work, then Im sure you can handle this repair. But my friend a tv set is not a place for a handy man to be experimenting around inside of, as there is alot of high voltage inside this set even when its turned off! Its best if you do not know all of the safty issues to seek out a pro to assist you in this repair. It could be a bad solder connection, or a bad filter capacitor that supplys the B+ to the video chip. Without looking at a schematic and tracing the circuit, its all a guess. There are no real user replacable parts inside this set. Good Luck PS please do not forget to rate this thread.
Posted on Nov 25, 2006
Tv wont come on and a red light is blinking. I have a Sony Wide screen projection TV model kp-46wt520
Can you unplug the TV for about 15 seconds, and then plug back in and watch the stand-by light. Tell me how many time the stand-by light blinks in regular intervals. If it doesn't blink at all, you need to change a fuse on the g-board. Once this is done run back through the stand-by blink light process, and more troubleshooting can be done if problem isn't already solved. If the stand-by light just keeps blinking with a count over ten just tell me, and I'll look for other possibilities.
Oct 25, 2009 | Sony KP-46WT520 46" Rear Projection...
Sony KP-61HS10
Five blinks is a video abnormality detection and I am all too familiar with this repair... One or more of the crt's in this unit has a bad set or failing guns in it... You can have a local tech bring out a crt tester and rejuvenate the tube for a temporary stay but it will eventually fail for good and in a short period of time it will be one or the other - - VERY expensive to repair or off to the dump...
Please don't kill the messenger!
William Rayburn, CET
Premium Technologies
Oct 05, 2009 | Sony KP-61HS10 61" Rear Projection...
My KP-51WS520 blinks 10 times
Type in Sony Blinking codes on Google you will find all blinking codes and what they mean.
Aug 06, 2009 | Sony KP-51WS520 51" Rear Projection...
Where can I find the fuse for the Sony KP-61HS10
Just take the back off and follow the power cord into the set. The main fuse will be within inches of where the cord attaches. That wont do you much good though. The fuse probably isn't blown and if it is the replacement will most likely blow right away. If the set is dead the LED should blink a certain number of times after you try to turn it on. The number will tell a tech what area has a problem.
Jul 09, 2009 | Sony KP-61HS10 61" Rear Projection...
61'' SONY Rear Projection KP 61HS10 blinking
My Sony HiScan 61" intemittent black screen for couple of seconds. I opened the back and look at what is happening. All three blue, green and red projection lights go off for a second or two frequently.
Anyone know what is the fix.
thanks
James
Mar 25, 2009 | Sony KP-61HS10 61" Rear Projection...
Tv Problem
How many times does the light blink in between pauses? Also is your model the KP-61HS10 ? Please respond to this same post and I should be able to help you.
Jul 01, 2008 | Sony KP-61HS10 61" Rear Projection...
Television wont power on
Is the led blinking? If so please let me know how many blinks its making before pausing for a second.
Apr 13, 2008 | Sony KP-51WS520 51" Rear Projection...
Sony KP-61HS10 blinking codes
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with
the video. Check video out, Q705, 732, 761 and other components on the C
board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
try turning up screen slightly.
You can get the service manual and free support at the following site to help yu with the repair of your sony the manual is 10.99 support is free here is the link. They will email the manual to you.
http://servicemanuals.vstore.ca/
Feb 14, 2008 | Sony KP-61HS10 61" Rear Projection...
Sony KP-61HS10 61 in. Rear Projection Television
plug it out to reset itself and if that does not work,you will have to call a tech as the tv has a problem in its power supply an its related circuit good luck.
Apr 06, 2007 | Sony KP-61HS10 61" Rear Projection...
Sony KP-61HS20 TV Logo
108 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
