Question about Logitech 967437-0403 Keyboard
Logitech wireless keyboard
Where is the connect button on the logitech wireless keyboard
  • 903 Answers
There should be a little red button underneath the keyboard that aslo has instructions on how to connect
Posted on Nov 15, 2008
SOURCE: set correct time on Logitech MX 3200 wireless keyboard
Cordless Desktop MXTM 3200 Laser
To adjust the LCD's time and date:
  1. Make sure that the time and date are shown on the LCD. If necessary, press (FN + F9) until the time and date are shown on LCD.
  2. Press (FN + F10). You are now in 'Set mode' (you can exit this at any time by pressing the Esckey).
  3. Set the correct hour by either typing the numbers on the numeric pad or using the cursor up and down keys, followed by Tab or Enter.
  4. Set the correct minutes by either typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
  5. Choose either 12-hour clock or 24-hour clock by pressing the cursor up or down keys to switch between the options. Then press Tab or Enter.
  6. Set the correct month either by typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
  7. Set the correct day either by typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
The time and date on the LCD should now be displayed properly.
Posted on Apr 26, 2008
SOURCE: logitech MX-3000 wireless keyboard not working.
Yes. I pressed the button underside of the keyboard right after I pressed connect. Still it's not working.
Posted on Aug 15, 2008
SOURCE: Logitech wireless keyboard and mouse (ex 100) won't connect
The mouse and keyborard have to be in direct view of the reciever. Even a small obstruction will effect the operation
Posted on Nov 05, 2008
MUKHTAR
  • 2022 Answers
SOURCE: Logitech mouse n keyboard wont connect
whenever you chage the battery you have to syncnonize your keyboard and mouse to sensor of the reciver. you can see on the back side of the keyboard there is connect button just press it and on the recevre side also press the connect buton same setting do with mouse also.
Posted on Sep 08, 2009
SOURCE: Wireless Keyboard not working
sensor are on but keyboard is not working
Posted on Oct 03, 2010
The wireless keyboard and mouse are not working.
  • Check to ensure that the wireless receiver is plugged into your computer. Press the "Connect" button on the bottom of the receiver to attempt reconnecting your mouse and keyboard to the computer. If your mouse and keyboard use Bluetooth, ensure that your computer's Bluetooth is active and detects the mouse and keyboard.
  • Check to see if the keyboard and mouse are turned on. If the power indicator lights on the keyboard and mouse are not green, press the "Power" button to turn the keyboard and mouse on.
  • Check the batteries of the mouse and keyboard. If the batteries are dead, replace them with fresh batteries and reconnect the mouse and keyboard to the computer by pressing the "Connect" button on the bottom of the wireless receiver attached to the computer. If your mouse and keyboard use rechargeable batteries, let the batteries recharge before using the device again.
  • Uninstall and reinstall your wireless keyboard and mouse drivers. Sometimes, the Logitech drivers are at fault for a bad connection. Use the Control Panel to uninstall the old drivers, then visit the Logitech website and install the latest drivers for your keyboard and mouse.
  • Search the Logitech Support Database. If your keyboard and mouse are still failing to function properly, visit the Logitech Support website and browse the support page for your product for specific solutions.
Feb 04, 2011 | Logitech Computers & Internet
Mouse will not work. I've changed batteries, unplugged and re-plugged the remote device. It will not work. What do I do?
Have you tried pressing reset/connection button on the device? Some Logitech models may have a connection button on the receiver which is plugged into the computer. The receiver button must first be pressed then press the device (mouse or keyboard) reset/connection button. Some Logitech models you will have to go into the Logitech software to start the connection software then press the reset/connection button when prompted.
Aug 13, 2010 | Logitech Wireless Access Duo Optical...
Logitech wireless rf keyboard and mouse quit
To fix the problem,
please press the connect connect button on the bottom of the mouse and the connect button on the reciever and relaese both the buttons together. this would rest the wireless connection and then the mouse should work fine.
regards.
Jan 28, 2010 | Logitech Wireless Access Duo Optical...
Keyboard isn't responding but mouse is
open the Logitech utility and try to reconnect the keyboard and pair it with the mouse. if it doesnt work uninstall/reinstall the software for your wireless mouse/keyboard.
May 27, 2009 | Logitech Wireless Access Duo Optical...
Logitech wireless keyboard not working
After changing the batteries and cleaning the corrosion out of the battery case, I pressed the connect button on the Logitech receiver, then the red restart button on the underside of the keyboard and it was fixed!
Mar 25, 2009 | Logitech Wireless Access Duo Optical...
Logitech Wireless CE 0682 Keyboard won't work but mouse does
did this come with software
and you might need to do a uninstall reinstall
if it worked on same pc before it should work now.
if you have a reset button on transmitter try resetting it.
Dec 30, 2008 | Logitech 967437-0403 Keyboard
Logitech wireless mouse and keyboard
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Sep 23, 2008 | Logitech Cordless Mouse
Wireless keyboard locked
Aug 26, 2008 | Logitech LX 700 9674180101
Wireless keyboard stopped working
Jun 11, 2008 | Logitech MX3000 USB PS/2 Wireless...
Logitech mx 5000 laser Keyboard
If it is wireless you will have to push the connect button on the wireless receiver after installing batteries even if the lights on receiver are on other wise your computer will not reconize it but you will get message that the item is working properly.
Apr 25, 2007 | Logitech 967437-0403 Keyboard
Logitech 967437-0403 Keyboard Logo
312 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
