John Kitchen - Samsung HL-R6167W
I put the jumper on the dmd board and the TV would not turn on. I took the jumper off and now it turns on. But the light colors are still not appearing normal.
  • 1 more comment
  • johnkitchen4 Nov 16, 2008
    I can't see anything in my TV that looks like the voltage adjustment module in the picture you linked me to. Do you know where I can find that control in my Samsung?
  • johnkitchen4 Nov 24, 2008
    Eagle338,
    I have been out of town for a week. I am still trying to get my Samsung 61" TV to display the light colors correctly.
    Can you help me to adjust the color voltage? I just need to know what it looks like.
  • johnkitchen4 Dec 18, 2008
    OK, I found the setting inside the "Service Menu" on the TV. I was sent the service manual for free and fiddled my way through it until I found the "Color Indexing" settings and it worked like a charm.
  • 4,889 Answers
Hmmm... So that wont work.. How about the color voltage fic? Di you try that?
Posted on Nov 16, 2008
  • 2 more comments
  • eagle338
    eagle338 Nov 24, 2008
    Can you please post an image of what the picture looks like so that I can guide you with the adjustments?
    Thanks,
    Sai.
  • eagle338
    ALso just make sure if ou have done everything right while replacing it . Here is a manual for refrence
    http://unitool.files.wordpress.com/2008/...
  • eagle338
    eagle338 Nov 30, 2008
    You will find them on the ray gun tubes. Shouldn't be too hard to locate if you know what a ray gun is(Which I assume you do).Sorry for the late reply though. I didn't see your comment alert mail as my mailbox is overflowing with alerts about comments in our experts lounge.
  • eagle338
    eagle338 Dec 19, 2008
    Great to know that you have fixed it. Cheers!
    Sai.
TV won't get light to screen??
If you hear the color wheel and then see the lamp actually light up you most likely have a bad DMD board. The part number is either BP96-00678B or BP96-00678D it depends on the chassis you have in your TV. The parts are available through http://www.samsungparts.com
Mar 04, 2010 | Samsung HL-R6167W 61" HDTV
Same problem
You have two options only. One is to pay a trained Samsung tech to replace the DMD bd which takes a Tech to properly align the DMD bd and takes some time or you can replace the entire Engine which is more expensive but quicker and easier. Wish had good news for you.
Jul 12, 2009 | Samsung HL-R6167W 61" HDTV
Do I have a bad dmd board?
It sure does sound like it. Normally I replace the entire light engine at the same time because as you know this is a problem with DLP's.The replacements come complete, DMD - Color Wheel, the whole nine yards, makes the job easier. Good Luck..
Mar 28, 2009 | Samsung HL-R6167W 61" HDTV
Mixed colors
Color wheels in that unit were updated to remedy a flaw in their initial manufacturing. I suspect you have one of the updated wheels and now the dmd board is having a problem distinquishing relative speed etc. Pull dmd jumper to fix it. Remove the jumper pin on the dmd board, metal shield has a cut-out so you can just reach in and grab it with a pair of needle nose pliers and pull it out.
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Nov 04, 2008 | Samsung HL-R6167W 61" HDTV
Samsung HL-R6167W set turns itself off
sounds like the digital main board, seen this before
Jul 18, 2008 | Samsung HL-R6167W 61" HDTV
I have a DLP Samsung HL-R6167w and it's not working
I had a bad digital board also. I went to parts.com to order a new part way cheaper than from repair service. the only problem I had was that after installation which is super easy 4 cables to unplug and replug. when I turned on the TV the picture came in upside down, not good. no one would give me the code to flip the screen as it is in a hidden menu, well after months of searching the web I found it!! It works for most all newer Samsung TV's. turn the TV off, hit mute then 182 and then power on button on the remote. the "hidden" menu will pop up and you scrool down to h-flip and flip the screen. I don't recommend messing with any of the other setting as you could likely really jack up the TV but at least you can fix it for a 3rd of the cost you would spend otherwise.
Jun 18, 2008 | Samsung HL-R6167W 61" HDTV
T.v. will not turn on. flahes "lamp" then no picture!
This will have to be narrowed down to a specific problem. I would try the easiest things first. First check the lamp. Is it bad or just starting to go bad or does it just need to be reseated with the ballast? If the ballast flickers when turning on your TV, then you will know it is the lamp that is not working or the ballast may need to be replaced. If that is not the problem next check to see if the color wheel is spinning or broken. If broken, it will need to be replaced. If not spinning it is the DMD board that is bad. The color wheel is plugged into the DMD board. If the DMD board is good it will spin the color wheel, that is what will start your lamp. When you lamp starts, you have your picture.
Mar 23, 2008 | Samsung HL-R6167W 61" HDTV
Picture on my TV starts to flash after a few minutes of use
This problem is common in Samsung projection TVs. The DMD board is going bad.
Mar 21, 2008 | Samsung HL-R6167W 61" HDTV
Samsung HLR6167 - picture freezes
This is very common in Samsung DLPs. The DMD board is going bad. You will need to replace it.
Jan 07, 2008 | Samsung HL-R6167W 61" HDTV
Televison & Video Logo
263 people viewed this question
Top Televison & Video Experts
