Question about Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer
HELLO FROM CYPRUS- PLEASE HELP ME TO CLEAR PAPER JAM---X7170
GOOD MORNING EVERYBODY FROM CYPRUS. IAM USING AN X7170(NOT ANYMORE) LEXNMARK AND LAST TIME WHEN I TRY TO PRINT A CAR,IT TOOK A PAPER AND START TO PRINT BUT THE PAPER WASN'T STRAIGHT. SO I TRY TO TAKE THE PAPER OUT WHICH I DID WITH A LITTLE BIT FORCE.THE WHOLE PAPER WAS OUT WITHOUT TEAR IT. FROM THAT TIME WHEN I WAS TRYING TO PRINT THE PRINTER WAS WORKING BUT , IT WAS MAKING THE NOISE AND THE MOVEMENTS BUT THE PAPERS WHERE BLANK. I CHANGE THE INK CATDRIDGES WITH NEW BUT THE SAME RESULTS. AND I COULD SEE THAT THERE WAS INK INSIDE THE ROLLER. ANYWAY , THE BAD THING IS THAT ,I WAS THINKING IS JUST A SMALL DETAIL OR A PIECE OF PAPER INSIDE AND I TRY TO FIX IT BY OPENING WHICH I CAN SAY IT WAS LITTLE DIFFICULT.(IAM NOT A SPECIALIST) I DESMALLED THE MACHINE AND I PUT BACK TOGETHER AGAIN WITHOUT FIX SOMETHING ACTUALLY. AND NOW THE MESSAGE CLEAR PAPER JAM IS ALLWAYS ON THE SCREEN. AND THE PROBLEM IS THAT I TOOK IT TO A SPECIALIST AND WHEN I TOLD HIM THE TROUTH HE TOLD ME HE CAN NOT FIX IT.(BECAUSE I OPEN IT FIRST) .........PLEASE HELP ME................. YOURS SINCERELY LAZAROS
Get rid of it I'm having trouble to even get it to work!! And its only a month old!! Get rid of it.
Posted on Mar 11, 2007
My paper keeps getting jammed. It makes a loud grinding noise and even after I clear the paper jam it repeats it all over again. Is there some way I could see if theres something stuck inside my printer...
Lift the Flat Bed Scanner and Turn the Printer Upside down and Gently Shake it!!!!!
You May get something falling out of the Printer which might have been stuck there!
Good Luck!!!!!
Jun 12, 2011 | Lexmark X7170 All-In-One InkJet Printer
Scanner not feeding on lexmark x7170. paper feeds halfway in them reports error/clear paper jam in scanner document feeder.
I have the same all-in-one printer and have just recently, the unit is a few years old, started having the same problem. I found that that if I make double sure the pages are evenly stacked and very carefully placed in the feeder tray, the problem is less common. It doesn't work everytime but ar least I get my faxes through on the first attempt 75% of the time.
Nov 10, 2010 | Lexmark X7170 All-In-One InkJet Printer
Paper keeps getting jammed in back of my printer lexmark x7170
Check the paper path and see if a small piece of paper is lodged somewhere along the track. Blow it out with a can of Dust Off. Or use a paper clip to dislodge any paper found in the paper path.
Sep 14, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
My hp 3940 had a jam. I removed the paper now it
Hello there
i know you have cleared the jam but i would go back and really look closley at the paper path and the internals a small piece off of a paper can cause this to claim it has a jam also if you turn off the printer and use canned air to blow out the whole insides this will help too also clean offf any lenses with a eyeglass cleaner ok ?
best regards mike
Aug 06, 2009 | HP DeskJet 3940 InkJet Photo Printer
Paper jam in lexmark all in one x7170
It insists there is a Cartridge problem on the Printer............ In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Move the Catridge Carrier which holds the Catridge Back and Forth for abt 20 Times as fast as u can.............
Turn On the Printer........
Good Luck...........
Apr 05, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Printerhpdeskjetd1360 shows paper jam with no paper in printer
You will be able to find information about clearing a paper jam here. Hope this helps. Please remember to rate this information.
Thanks
Nov 16, 2008 | HP DeskJet 3650 InkJet Printer
Both power light and paper jam light on
clear the paper jam. take out the paper(if any) from back of the printer. Clear all prints in que and try to print
Aug 13, 2008 | HP DeskJet 970cxi InkJet Printer
Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer Logo
54 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
