Question about Radio Communications
Motorola Talkabout T5700 and Audiovox GMRS 1582CH headphones
I can't find any ear-pieces or head phones in any of the stores that will work with my Motorola Talkabout T5700 and Audiovox GMRS 1582CH radios. Is it necessary to buy proprietary headphones for these radios?
    Brigadier General:
  • 6,966 Answers
Unfortunately yes. More often than not the pin/wiring arrangements are different, if not the physical sizes and dimensions, not to mention electrical characteristics such as impedance, common ground, ptt and VOX feature. If it is just an earpiece or headphones that is required, then any such accessory would do and it would be a matter of replacing the plug and/or rewiring the connection points.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 16, 2008
  • flywithmike Oct 21, 2010
    I have the same audiovox radios. After sometime I did find the headset boom microphone. Part number gmrbhst7 You can find it at www.audiovox.com Price 15.00 plus 6.00 to ship.
Motorola Talkabout T5700 Two Way radio one not working
The battery may be dead. If it was indicating it was charging for 48 hours and still did not work, you can be pretty sure it will not charge again.
Oct 02, 2012 | Motorola Talkabout T5700 AA (22 Channels)...
T5700 and T9500 con speak between them?
Directions for programming the T5700 can be found starting on page 18 here http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf
Directions for programming the T9500 can be found on page 1 under the heading MENU OPTIONS here http://www.giantintl.com/ContentManage/manuals/Moto/T9500%20FINAL%20-%20English%20only%20all%20rights%20reserved%20and%20call%20center%20email%2004-24-07.pdf
These two radios have many similar features, but some which differ. For best results leave all the special features such as Qt filter, call alert, and interference eliminator codes, turned off or set to zero until you get the radios to function in a basic mode on just the same channel as one another. Then once you've found what works, you can experiment adding special features, if desired.
Best regards.
Jun 18, 2012 | Motorola Talkabout T5700 (22 Channels)...
I lost one of the hand sets - is it pssible to
The TalkAbout line of radios operate on the same 14 FRS/GMRS frequencies. If you purchase another model TalkAbout they can talk with one another. Here is a link to the Motorola TalkAbout Store http://www.store.motorola.com/mot/en/US/adirect/motorola?cmd=catDisplayStyle&catKey=601700
Best regards.
Apr 09, 2010 | Motorola TalkAbout T5530 2-Way Radio
How to get a Talkabout T5720 to communicate with a
The frequency range and operatngmode of the two radios are compatible. To get the Radius operating on a GMRS channel you'll need a Motorola programming cable and software, OR a trip to a Motorola dealer for frequency programming. Considering the cost involved, the 2-watt output of the Radius, and the 1-watt output of the Talkabout, you would be better off performance and cost wise buying a pair of 5-watt GMRS portables.
BillB
Jan 11, 2010 | Motorola Talkabout T5720 (7 Channels)...
Cant pick up on cb radio
No, T5700 radios operate on UHF FM frequencies in the 450-470 MHz range. CBs will not communicate with them.
Jan 31, 2009 | Motorola Talkabout T5700 AA (22 Channels)...
Motorola Talkabout T5700 and Audiovox GMRS 1582CH don't talk
Most radios of this series would have Interference Eliminator Codes. The codes eliminate other incoming transmission not with the same code (number). There could be similar radios working on the same channel/frequency, but if they do not have the same code then neither one would hear each other. This does not make a channel "private", rather it limits what one can hear on that channel to another radio with an identical setting of the code. In some Motorola models, pressing the Menu button until the small numbers/code flashes would enable them to be changed. To change, press the + or - keys. Pressing the MON key or setting the code to Zero would enable the radio to receive and sound off all incoming signals with or without the code.
Nov 15, 2008 | Radio Communications
Missing recharging cord
Hello Krisso,
Your best bet is likely going to be contacting Motorola directly. Their parts department may have the charger available. Their product support number is 1-800-353-2729.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 09, 2008 | Motorola Talkabout T5700 AA (22 Channels)...
Need to add to model
Every Motorola line TALK ABOUT can work between them.
Feb 28, 2008 | Motorola Talkabout T5700 AA (22 Channels)...
Motorola T5700 Talkabout Series
It would seem that this is a problem with the contact/switch of your Motorola T5700. When a headset, ear piece or external speaker is plugged in, an internal switch transfers the connection from the speaker to the external. This is better illustrated in the image below.
Initially, you can try an electronic contact cleaner. If that doesn't work, you may have to open the unit and manually scrape off any corrosion from the contacts/terminals or slightly bent it to improve contact.
Hope this be of some help/idea. Pls post back how things turn up or should you need addition al information.
Nov 02, 2007 | Motorola Walkie Talkie 2-Way Radio
Motorola t5700 talkabout
Could you please be more specific with your problem, e mail me pls or chat me neto-rola@hotmail.com Neto
Aug 27, 2006 | Motorola Talkabout T5700 AA (22 Channels)...
Radio Communications Logo
229 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
