Question about Fuji FinePix Z10fd Digital Camera
Z10 - autofocus broken
I've got a cute little Z10, but the autofocus is broken - just tries real hard and makes everything more blurry.
Help!
DoI need to trash it (please no) or can it be saved? I've tried resettingit, switching it off, changing the settings. Occasionally it will worka bit, either when I first open the camera or after zooming fully outand in again, but it's not a happy bunny.
Louise
    Novelist:
  • 208 Answers
LOUISE,
SORRY NO ONE HAS ANSWERED THIS. I JUST FOUND IT. OK, REPAIR IS OUT OF THE QUESTION. REASON? THEY WOULD CHARGE YOU MORE THAN THE COST OF THE CAMERA. YES, AFRAID SO. THAT'S USUALLY THE CASE WITH REPAIR. IT'S NOT WORTH IT, UNLESS THE CAMERA IS REALLY EXPENSIVE! BEST BET, LIMP ALONG, IF IT WILL WORK AT ALL UNTIL IT JUST DIES A SLOW DEATH AND THEN REPLACE IT WITH MAYBE A LITTLE BETTER CAMERA. I THINK YOU WILL HAVE BETTER LUCK, IF YOU SPEND JUST ALITTLE MORE ON A CAMERA. SORRY I COULDN'T PROVIDE A MAJIC CURE, BUT THERE JUST ISN'T MUCH FIXING TO THESE WHEN THEY DIE. IF I CAN HELP, REPLY TO ARCLIGHT1217.
Posted on Dec 18, 2008
Nikon F65 won't auto-focus or take shots
You're on the right track with oxidation. Try cleaning the contacts in the body and on the lens with contact cleaner, and let it dry. Remove the battery, and clean the contacts inside the camera.
Mar 09, 2017 | Nikon F65 35mm SLR Camera
The auto focus does not work properly with this lens on either my Nikon D5000 or D7000. I have tried all possible combinations of AF settings. Typicaly, when I use single point to focus, the subject I...
Hi, It wouldn't autofocus on the D5000 as the body doesn't have an auto focus motor in the body and since that lens is AF, not AF-S, it won't autofocus. It should autofocus on the D7000 though, how far away are you from the object you're trying to photograph?
Aug 28, 2011 | Tamron SP AF 17-50mm f/2.8 XR Di II LD...
My camera is taking blurry pictures and its blurry when u look at the screen
Have you checked the autofocus? You may need to clean the front sensor. Hold shutter down half way to see if camera will autofocus, try this in several modes. Hold shutter half way down and look at screen, picture should come into focus. Make sure you do not have "Macro" selected
Mar 02, 2010 | Cameras
Pictures blurry
typically if camera is not set to autofocus, pictures come out blurry. make sure to put autofocus on. when u put autofocus on, u usually need to press button twice to take picture.( 1st to set autofucus, 2nd time to take picture) hope this helps ur issue.
Aug 14, 2008 | Cameras
Unable to Use Card
My Z6 does the same thing every now and then.
The only way I can get the message to stop (and that annoying warning chime) is to pop the card in and out real fast with the camera turned on.
It seems as though these Konicas are REALLY picky with the cards, and this is a well known issue. Also, make sure the little "lock" tab is in the "unlock" position.
You can also try taking the batteries out, and holding the on/off button for 1 minute. That resets it back to factory defaults, and clears out any "bugs". Sometimes it helps.
Sometimes using a card reader and manually formatting the card works too.
Apr 06, 2008 | Konica Minolta DiMAGE Z10 Digital Camera
The fish on my fisher price ocean aquarium have stopped turning. I've changed the batteries and everything but that works, help!
I think there is a belt or gear in there that might have broken. I am familiar wih that cute little "aquarium" that shines a light up through the liquid.
Mar 04, 2008 | Audio Players & Recorders
Nikon D50 autofocus
Same happened to mine ,Its almost as though the motor has dis-engaged.I SOLVED MINE BY FORCING THE FOCUS RING WITH AUTOFOCUS ENGAGED THIS SEEMS TO HAVE RE ENGAGED THE MOTOR .HOWEVER BE CAREFUL I HAD LITTLE TO LOSE MINE WAS STILL UNDER WARRANTY WHEN I DID THIS.Its perfect since.
Jan 12, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Fuji FinePix Z10fd Digital Camera Logo
66 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
