Question about Sanyo DS27910 27" TV
Picture is too wide, how can I adjust the width?
I took the back off but couldn't find a pot labled width or height like tvs used to have.
  • 700 Answers
Can't you set/adjust that on menu settings? If not, and no adjustable knob inside for width adjustment. You are now dealing its adjustment with MCU, or its eeprom ic. Check its required power supply it should be within spec. Better to have an schematic if you deals within its electronics parts.
Posted on Apr 20, 2009
Picture adjustment on a samsung ue40f8000
Hi
You cannot choose individual width and height but in Tools > Picture Size you will find Auto Wide, 16:9, Wide Zoom, Zoom and 4:3
Hope this helps
Nov 07, 2013 | Samsung Cameras
Screen Adjust
You can't. There are no adjustments for height and width. Not all programs were shot on 16 x 9 wide screen resolution so it will leave the screen with black spaces . around the edges. Nothing wrong with the TV, and nothing you can do other than the zoom buttons you use now.
Aug 09, 2017 | Sanyo DP19648 19 in. LCD TV
The picture on my television changed into a slim band in the middle of the screen about a 1/2 wide running from the bottom to the top, I tried to adjust the width with the trim pot on the back but it does...
RCA EXPERT HERE
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 19, 2011 | RCA RTD317 Theater System
PICTURE TO BIG AT THE SCREEN.CAN NOT SEE THE PICTERS MARGIN AT THE SCREEN.HOW TO ADJUST(REDUCING PICTURE SIZE ON SCREEN)?
1) Power your wide-screen TV on and turn to a channel that is displayed with bars on the side. You need to leave this channel on to ensure you have properly adjusted your wide-screen TV.
2)
Find in your TVs settings where you can "stretch" the picture. Refer to your wide-screen TVs owner's manual for specific instructions. Some TVs may not refer to this adjustment as "stretch." You will be able to find all the information your looking for in the owners manual.
3) Adjust settings back to normal if you want to watch a program shown in 16:9 format. Keeping the screen "stretched" will cause programs shown in 16:9 format appear zoomed in, making the picture look really different.
Aug 14, 2010 | Televison & Video
Edges of picture being cut off. Is there something we can do to adjust it?
Have you tried changing the aspect ratio? On your remote there should be a button labled aspect. Otherwise you'll need to access the service menu and change the vertical height and horizontal width.
Jul 16, 2010 | Hitachi 57F710 TV
Which tags are use to adjust image in css as it remains same even we have to make small or big or whatever?
Its very simple. You have to use width and height attribute of <img> tag to adjust the image size in css.
for example
img.b46860 {/* scalable em size class 468px/60px banners */ width: 29.25em; /* replaces 468px width */ height: 3.8em; /* replaces 60px height */ }
Regards, polysandy
Jun 07, 2010 | Computers & Internet
I have 40 inch vizo tv where the picture height and width is off. how do i correct this problem. example of what referring about ie the head of the person may be missing and the bottom portion you cannot...
Do a reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Feb 01, 2018 | Televison & Video
Upgraded eMAC G4 to OS 10 and have display problem
You SHOULD be able to control the monitor adjustments in os 10. In the Displays section of the System Preferences, look for the "geometry" tab. Under this tab you should be able to control width and height so your display fills the entire screen.
If you still can't find it, try adjusting the resolution and refresh rates. Also use the "detect displays" button.
Jul 15, 2009 | Apple Computers & Internet
Lg flatron 775ft screen size problem
Hi Edit123,
U can chane output width and height from buttons given on LCD panel manually
Sep 19, 2008 | LG Flatron L1750S 17" LCD Monitor
HOrizontal width problem
With older sets i found dust as the main culprit in simmular situations.check for any  adjustment pot on the circiut controlling the screen width[normaly 3 pots close together open back of set to reveal electronic's]. be very carefull not being electrified as the set must be in operation while doing the adjustment.even turning the pot forward and back and then to the original position sometimes solve the problem.
Oct 17, 2007 | Televison & Video
Sanyo DS27910 27" TV Logo
329 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
