Question about Homedics PS-200 Iron with Auto Shut-off
Home touch 300 no steam coming out
My steamer irn stopped giving steam out
  • Anonymous Dec 11, 2008
    My wife has been having the same problems with the steamer since day one, for some reason the steamer stop working just minutes after starting and my wife has to reset the red button over and over again. Just **** her off. Any one knows a serious answer? It is a good product if it only worked as advertised.
  • sonnie611 Mar 20, 2009
    the water is leaking at the base of the steamer and no steam comes out anymore.
If you are using tap water - there may be minerals clogging the machine. try dumping all the water out and rinsing the machine then add distilled water. That was the issue I had...
Posted on Jul 08, 2009
Hold the hose straight up fully extended for several seconds--it says to do this in the manual--and works great
Posted on Dec 31, 2008
  • htchlppr Dec 18, 2010
    I have had the steamer for two years. It worked well duting the first year, there after I had problems. When you use it, you have to hold the tube up and high, to a point that we had to place our garments on a coat rack. Second. You must only use distilled water, if not, rust will form in the core. Third, do not expect the unit to last more than two years. I took mine appart and found it to be built with sub-standard parts. The heating unit is made of TIN, like your soup cans. It will crack in a timely manner. Im now on a quest for a better machine.
Take the unit apart, make sure to wash out everything including the hose as well as the unit itself. Spray water in the opposite way it comes out to fill up the bladder from the hose. This will loosen any type film that has accumulated. We did this and it fixed the device. Not only that but what came out looked like food particles and other filament. We have only used the device once, so i assume we got a used product even though we bought it new from Costco. This should fix your problem.
Posted on Mar 16, 2010
Home Touch clothes Steamer! Won't turn on..
Steam is a tried and true sanitize. And unlike some abrasive cleaners, steam is both penetrating and gentle at the same time. It effectively sanitizes because it can reach high temperatures (above the boiling point of water) in pressurized atmospheres. And, by effectively re hydrating and breaking the bonds of muck and dirt, it's highly effective at spot-cleaning and deodorizing without all that rough treatment. And irons, of course, use steam to work the wrinkles out of fabrics when dryers don't cut it.
Sep 16, 2017 | Irons
How can I get my steamer to work again? Orange light comes on but nothing else
Make sure you didn't knock off a wire to the heating element when you had it open. Also put a couple of cups of whitevinnegar in it and leave it for an hour or two. This will dissolve the scale build up. If it doesn't get hot thenthe element is probably burned out. There is a limit switch held against the tank too. It can stop the heating element if it goes bad.
May 29, 2014 | Rowenta IS9100 1550W Precision Valet...
Conair steamer green light comes on but low water beeps. water full.
How To Use The Conair® Deluxe Fabric Steamer
www.conair.com/how-to-use-the-conair-reg-deluxe-f...
Conair CorporationThe Conair® Deluxe Fabric Steamer (model # GS11DR) conveniently rolls to any spot in your ... This unit comes with a rotating hanger. ... The switch will light to indicate when power is on. ... Note: If the low water indicator lamp becomes illuminated but the water tank is not empty, follow the instructions for decalcification.
[PDF]Instruction Booklet - ExtremeSteam® Upright ... - Conair
www.conair.com/.../gs95_13pa140688_ib_final.pdf
Conair CorporationMar 1, 2013 - ... water only. 8. Plug the steamer unit into a standard 120V AC power outlet. 9. ... Push button on T-nozzle - light will go on and steam will start.
Customer Reviews: Conair Extreme Steam Fabric Steamer ...
Aug 16, 2013 | Irons
My steamer steams and then shuts off and it takes another two minutes to steam again....what is wrong?
the power light stays on but steam only comes out for 30 second.and it takes few minutes to steam again.
Oct 21, 2012 | Rowenta Commercial Garment Steamer - White
MANUAL FOR PS 350 HOME TOUCH GARMENT STEAMER
First-time ever used. Water filter installed. WON'T STOP BEEPING AND START STEAMING.
Mar 03, 2012 | Irons
OMNI STEAMER GENIUS 2000 STEAM IRON HAS STOPPED
check the connection. Most probable the heater connections are rusted due to water seepage or melted due to overheating.. If you can dismantle and check the connection.
Jun 09, 2010 | Irons
Need a User Manual
my home touch ps200 has the reset button that wont reset ?
Oct 10, 2009 | Irons
How to use a steamer.
  1. Plug in the steamer.
    • The steamer usually comes with a smallish padded square with a strap that slips over your hand. (If you so not have one of these, cut out a square from some stiff cardboard, pad it using cotton batting, and cover it with a heavy, smooth, waterproof or water-resistant material.)
  2. Make sure it is steaming nicely before you use it. You check by pulling the little trigger on the handle, and seeing how much steam issues when you release it. You actually want to use this while steaming as well, in order to release more steam when needed.
  3. Hang the garment, and slip the padded square over one hand.
  4. Place the hand with the square on the underside of the garment, and use it to keep the fabric smooth while you steam it.
  5. Use the steamer by holding the nozzle close to the garment, and pulling both it and the padded square in downwards strokes.
Sep 18, 2009 | Rowenta Commercial Garment Steamer - White
Would you return this PS200 steamer?
If the steamer starts making a "gurgling" noise, like its running out of steam, hold the hose straight up for several seconds. It says to do this in the manual and gets the steam flowing again--works great!
Jun 13, 2008 | Homedics PS-200 Iron with Auto Shut-off
Homedics PS-200 Iron with Auto Shut-off Logo
9,729 people viewed this question
Top Homedics Irons Experts
Are you a Homedics Iron Expert? Answer questions, earn points and help others
