Question about Lightning Audio Bolt B2.150.2 Car Audio Amplifier
Amp runs but then will just turn off and red light comes on
My lightning audio amp will run fine for a few minutes but then just shut off and the green light will turn off and red one goes on. If i take out the fuse and put it back in it will start working for a minutes again then turn off. Sometimes it will work for a while but in the end it always ends up turning off. Any ideas?
You need to get a fan for it because it does not come wit one and when you get the fan you have to hook it up from the inside by taking the torture tested/bolt sign off and look for a small white pug to attach it to
Posted on May 26, 2009
Bmw 325ci cooling fan not running
have you checked the fuse and also the relay.
Aug 23, 2017 | 2001 BMW 325
Amp not switching on again after switched off for 10 minutes
It sounds like amp's short circuit protection is kicking in. you more than likely have a couple of blown speakers. This drives output to close to 0 Ohms and its shutting down. If it;s not that , the problem is internal and you would have an out put Transistor or a capacitor about to fry.
suppose you could go in and go over solder joints, but don't hold your breath. Next time dont turn it up so loud
Sep 08, 2017 | Lightning Audio Strike S2.600.2 Car Audio...
I have a lightning audio amp a B4.320.4 and Protect Lght stays on
the amp probably got to hot and had a thermal shut down witch will have to be fixed by a professional.
Mar 06, 2010 | Lightning Audio Car Audio & Video
My amp wont even turn on or red light or nothing so what do i do
check ground cable, check fuse on amp, and check the fuse under the hood, on the positive cable should be about 12' from the battery, if all is well and theres no light, check the blue wire coming from your deck use a tester,if bad you can run one of your fuse box ,place a 12volt switch and hook it to the amp you should be good to go
Jul 09, 2009 | Lightning Audio B4.250.2 Car Amp
you may have fried the amp pre outs in the head deck, try the amps on another stereo
Jun 01, 2009 | Lightning Audio Bolt B2.150.2 Car Audio...
Amplifier keeps running overcurrent
sounds to me like you are overheating the amp, try down tuning the peak level of the amp, and also if there is anything around the amp clear it away, check if the fan is turning on, you may need to replace it,
May 20, 2009 | Sony XM-2150GSX Car Audio Amplifier
Jh202 amp works for a few minutes stops for a few minutes any ideas
Sounds like the amp is going into Protection Mode. Does yours have green LED light then RED LED on it? The green is power and the red is Protection. You will need to either change the OHMS wiring or Put A Fan on it to Keep it Cool Inside.
May 11, 2009 | MTX JackHammer JH202 Car Audio Amplifier
Amp won't turn on
disconnect audio inputs and outputs and see if one of those are causing it , if it still does it with all audio inputs and outputs disconnected then there is a problem with the power amp
Oct 08, 2008 | Lightning Audio B2.300.2 Car Audio...
Amp problem
Are you sure that the terminal isn't shorted to the case of the amp?
If it's not, the amp probably has a shorted output transistor.
If you want to repair it yourself, read through the following page. It explains the basics. Let me know if you have any questions.
Basic car amp repair primer
May 15, 2008 | Lightning Audio b2.250.1 Car Audio...
Overhaul light (red) stays on!
This is not a ovehaul light. It is called the protect indicator. It kicks in when the amp detects a fault on it's output. Disconnect the speaker / sub. Power up the amp and see if the light goes out. If it does you Sub is toast and needs to be replaced. If it stays on then the amp is done.
Jun 22, 2007 | Lightning Audio LA1.300.2 Car Audio...
Lightning Audio Bolt B2.150.2 Car Audio Amplifier Logo
196 people viewed this question
Top Lightning Audio Car Audio & Video Experts
80stech
Richard Lukszys
Richard Lukszys
jason
Are you a Lightning Audio Car Audio and Video Expert? Answer questions, earn points and help others
