Question about Gateway Computers & Internet
I own a Gateway 3610GZ. The lcd panel will not turn on. I can hear the music when it boots-up, but no picture. When I do get the picture it will blink off and on. Most of the time it will not come on! I tryed the toggle fn-f4 to no avail! Help!! Where do I send this for repair?
  • vivsumnr123 Nov 17, 2008
    Thanks for the tip!
    Genius:
  • 1,913 Answers
When u powwer up Press F8 key then go to enable vga mode set resolution to 800*600 or 1024 *768
thats all. dear
Posted on Nov 15, 2008
  • Gateway Master
  • 4,806 Answers
Check the connection from the pc to the monitor, try to re-install the video drivers if possible, if the problem still persists, it will no doubt be the inverter or inverter coil which is faulty, any good PC repair shop should be able to fix the problem for you at a reasonable price.
Be advised that you may end up buying a new monitor
My toshiba laptops lights come on when i push the power button, but the screen remains black. why wont my computers screen come on
do you hear a beep when you turn on the computer???, does it seam to power on???, it could be a defective inverter (part that produce the back light of the LCD panel), try plugging an external monitor to see if you have a picture, if so than the LCD panel is defective (LCD it self or INVERTER) if not than it could be the computer it self that wont BOOT, try removing all components (DVD drive, battery, mouse, etc...) see if it turns on...
Good Luck!
Mar 16, 2011 | Computers & Internet
The screen boots up with the commands and then it
The picture board on your monitor is faulty or bad, since it goes black after booting, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself. in order not to complicate issues.
Take care.
Apr 21, 2010 | Gateway 19" Widescreen Flat Panel TFT LCD...
What kind of optical drive uses the gateway 3610gzits sata or ide
Look on this page: Gateway 3610GZ. It's not on the specifications page, as you would expect, but if you go to Components > DVD drives > Main View it says Enhanced IDE (ATAPI) I would double check before buying a new one, though. Just take the drive out. There are usually only 1 or 2 screws holding it in on the bottom, and the drive should slide out the side.
Dec 23, 2009 | Gateway 3610GZ PC Notebook
New laptop lcd display not working
check the panel to make sure the panels are the same model number there are more then one part number for gateway lcds for your model and if your laptop uses the xga screen and your not replacing with the correct panel then you will get the problem you are seeing now.even thought the inverter and back light are the same the panel are very differant.
Feb 18, 2009 | Gateway MT6451 Notebook
Gateway FPD1760TFT LCD monitor
Problem
1. turn on computer
2. monitor receives signal, it looks like its working
3. it goes through some steps and then the monitor says "no signal" and kind of stays in limbo with fans running, etc.
Solution
One possibility is that computer is looking for drivers for you video card. It could be hung up looking in the wrong places. Remove all peripheral hard drives and memory sticks. Try again.
Jan 12, 2009 | Gateway FPD1760 17" LCD Monitor
Gateway shd 3010 LCD goes black
I have the same problem now!!! Did you ever find a solution?
Jan 02, 2009 | Gateway SHD-3010 30 in. HD-Ready LCD...
Asking support for getting drivers to 610 Gateway desktop computer
If its just the drivers u need, go to www.support.gateway.com and download it from under your model no.
Oct 23, 2008 | Gateway FPD 1810 18.1" Flat Panel LCD...
Computers & Internet Logo
15 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
