Question about Frigidaire Kitchen Ranges
Burners or oven do not work,all displays and oven light work.new unit.FEF366
  • 240 Answers
Sounds like you have a power problem. Need to be sure the pigtail is wired correctly to the unit, and that you have 220V coming in. Without 220-240V coming in, neither of these systems will work properly. If you dont not know how to check this, call a certified electrician to check. Most of the time when you have problems with both systems (the top and oven are completly independent of each other) its usually a wiring issue, throw circut breaker, or miswiring some where.
Posted on Nov 15, 2008
Cfes388jfs5 range/oven: ranges work, warming drawer works, light works, LCD display is not on, oven doesn't work... when i press bake i hear a click? any ideas? would a bad thermal breaker cause the LCD...
Email me at jubileebethel76@gmail.com send me a picture just to help me get my brain around it and a phone number and I will be able to help you out more efficently
May 21, 2014 | Frigidaire FEF366 Electric Kitchen Range
The gas in the oven goes on then off
follow this instruction. God bless you
    • 1
      Unplug your unit and turn off the gas supply at the saddle valve near the unit.
    • 2
      Lift up the hood of the oven. If you have sealed burners, the lid will not lift up. Locate the ignitors near the burners of the unit. Clean any gunk away from the ignitor using a toothbrush. Test the unit.
    • Sponsored Links
    • 3
      Pull the burner dials off the front of the unit if the ignitors won't work.
    • 4
      Remove the screws at the ends of the front cover, where the gas supply knobs are located, using a screwdriver, and remove the cover from the oven.
    • 5
      Slide the wires off the burner valve switches and pull them off the burner valve by sliding the switch forward. The switch will have wires attached to it. Loosen the screws holding down the wires of the burner valve. Pull out the wires carefully. Place the wires in a new switch. Slide the new switch onto the burner valve. Replace the knob, and turn on the gas supply and power. Ignite the burner.
    • 6
      Follow the switch wires into the oven if the new switch doesn't work. Locate the module box, which is usually 2 inches by 3 inches. Slide the wires out of the module terminal by pulling on the wire connectors. Remove the screws from the old module and pull the module out. Insert the wires into the new module, using the same wire orientation as before. Reassemble the oven. Turn on the electricity and gas, and turn on the burner.
Read more: http://www.ehow.com/how_7925141_repair-electronic-ignition-gas-stove.html#ixzz2ZPuc5nad
Jul 18, 2013 | Ovens
CONTROL PANEL FOR OVEN NOT WORKING AT ALL
Hi - I understand that the burners work, however I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another question, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. Then a beep will sound and LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Does the clock display "Sd" or "dddd"? If so, the clock is in sales demo mode. Press and hold the "BAKE TIME" button for 6 seconds to exit sales demo mode. If this does not prove to be successful, contact a professional to have EOC diagnosed, confirm that there isn't a wiring failure or a faulty element.
Oct 17, 2012 | Frigidaire FEF366 Electric Kitchen Range
HOW DO I LIGHT OVEN PILOT?
Hi and welcome to FixYa, I am Kelly
Your model number was missing digits so I used this manual:
GRP17WEWWW
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=981380002.PDF
and if your unit is older this one:
http://genet.geappliances.com/DocSearch/Dispatcher?REQUEST=ShowPDF&FileName=49-8514.PDF
Automatic Ignition
The oven burner is lighted by electric ignition. To light the burner, press the pad for the desired electrical function and press the INCREASE or DECREASE pad until the desired temperature is displayed. The burner should ignite within 60 seconds. After the oven reaches the selected temperature, the oven burner cycles off completely, then on with a full flame to keep the oven temperature controlled.
GE contact data:
If you don't understand something or need more help, call:
GE Answer Center®
800.626.2000
24 hours a day, 7 days a week
Both the new and OLD units use a glow bar for lighting the burner. Most likely your Glow Bar has failed: GE PN: WB2X9154
The Glow Bar is item 316 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=214914&diagram_id=20725728#d20725728
If you net search the WB ge part number you can save lots of money!!!!
http://www.amazon.com/WB2X9154-Gas-Range-Oven-Igniter/dp/B004H3XQPM
If the glow bar is glowing and you still do not get ignition respond here and we can go through troubleshooting.
Thanks for choosing FixYa,
Kelly
Apr 23, 2011 | GE JGRP17 Gas Single Oven
My burners work on the stove but the clock, and over buttons will not come on, so I'm unable to turn on the oven. I have a Frigidaire model FEF366EMC
Check for a blown thermal fuse protector. Located on the back wall of the oven behind a sheet metal cover. Disconnect power and you can ohm it out.
Jun 27, 2010 | Frigidaire FEF366 Electric Kitchen Range
Display, oven not working
Same exact thing happened to me.. the Control Module is defective - may be a power surge problem. was quoted $300 for the part plus labor.. is there a cheap way to fix it myself I wonder?
Jan 12, 2009 | Frigidaire FEF366 Electric Kitchen Range
Frigidaire oven not working in bake setting
Hi Thanks For The Question. I Would Check The Bake Element. Replace The Bake Element .Thanks The Appliance Doc
Oct 06, 2008 | Frigidaire FEF366 Electric Kitchen Range
F3 error light
Hi thanks for the question. the f 3 code says the oven sensor is open. that's the part located in the oven. top left in oven .cut the power to stove . replace the oven sensor thanks the appliance doc
Sep 06, 2008 | Frigidaire FEF366 Electric Kitchen Range
Kitchen Ranges Logo
74 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
