Question about Sanyo DS25390 TV
SanyoDS25390 Tv good picture buzzing noise
Tv works great good picture expect now has this buzzing noise and goes away when you mute it????
    President:
  • 3,130 Answers
What are you using as a source? If its a cable/satallite box, double check that first. If its a video input or a scart input, swap out the cables. If it still there you could have an input problem or a filter capacitor going bad. Does the hum get louder with sound? If it does it is an input source and or cables. Good luck Ps please dont forget to rate this thread.
Posted on Nov 25, 2006
I have a loud buzzing noise on my Toshiba DLP 46" projection TV. It is not the fan, it works fine. In fact the TV works great and has a good picture. The buzzing used to go away after awhile. Now it...
In some cases the buzz is external. The vibration of the unit may just cause a tray, flat surface, or other surrounding attachments to rattle and buzz. Look for anything that may be loose or laying on or about the TV.
Dec 09, 2014 | Toshiba 46HM94 46" DLP Projection TV 46" -...
Have just bought an LG37LD450. Buzzing noise coming from the components at the back of the TV. Annoying. Otherwise TV perfect. Definitely not sound problems because buzzing noise still there when on Mute....
Had this problem as well. Ran through a laundry list of possible solutions. Finally found that the key is to increase the backlight (Access via [Menu] [Picture] ) to 100% and the noise goes away. If this is bad for the life of the backlight, just pray the backlight burns out inside year 1 while the warranty is still valid!
Oct 20, 2010 | LG 37LD450 37 in. TV
Hi, I Purchased an LG 50PK350 plasma tv and I am experiencing an extremely loud, annoying buzzing sound even with the amp switched off & the sound muted. The buzzing is not constant ... the brighter...
I have this tv aswell, and yes I will confirm that it does buzz quite alot, but all plasma tvs do, it is to do with how it renders images, the buzzing can be made worse by it being close to a wall and it reflecting back. I found that my tv stand some how amplified the buzzing when i got mine. I dont think its something you can escape.
Mine i notice also when scrolling around menus seems to have lines that follow your selection....not to pleased about that
Oct 18, 2010 | Televison & Video
Loud buzzing noise on vizio tv
It sound like you may have sound processor problem which is part of the main board, I would also look at the 12vdc from power supply to make sure it is clean DC.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=l37hdtv10a
http://en.wikipedia.org/wiki/Capacitor_plague
Dec 22, 2009 | Vizio L37 Television
Noise coming from power supply
When we turn our TV the humming and buzzing begins! We cn mute it and it goes away and then it when we turn the sound back on the sound is back! How can we fix this?
Sep 18, 2008 | Polaroid FLM-323B Television
19 in blue screen only sound works great
blue screen is the noise mute screen. however the audio is not getting muted and hence the buzzing....meaning the tuner on the TV is not getting locked on to the station/frequency
1. check your antenna if you are using one. Autotune
OR
2. Reconnect coax from the cable box to Tv and autotune.
OR
3.Use the Video out from the cable box and connect it to one of the video inputs on the TV. Switch your Tv to that component. Use the cable box to change channels (Best case scenerio)
Feb 28, 2008 | Westinghouse SK-26H240S Television
One speaker buzz when cold
It works fine for a couple of minutes the starts to hum. If you turn up the volume it masks the noise but is till audible, also the video switching cuts out. after examining the components I have seen some heat discoloration in the power suply area and believe it to be power for the video board. disconecting the ribbon cable form the video board the hum goes away, and so does any video wich does'nt matter for me because my monitor1.gif does all the HD video1.gif switching. hope this may help with some noise problems.
Jan 23, 2008 | Harman Kardon AVR 225 Receiver
Buzzing noise, sound but no picture
It sounds as if the lamp needs to be replaced. The buzzing sound you hear is the ballast attemting to fire the lamp.
Oct 20, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Televison & Video Logo
169 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
