Question about Kitchen Ranges
I need to fit a fan element to a Beko DVC-62 Oven.Is it an easy job and is there anything I need to be aware of.
    President:
  • 1,462 Answers
Very easy job but disconnect from mains before starting.
remove raer panel inside oven and remove rear panel on outside of oven. element is just held in by two nuts on element base plate posts and one self-tapper inside oven
Posted on Nov 16, 2008
What does error code F12 mean
The oven fan element has failed, you need to fit a new one.
Remove inner rear panel of oven and you will see the round element at rear.Unscew screw(s) that secure element, disconnect leads, and fit new element.
Refit element cover.
Job done..
Make sure you have power off to oven before you start.
Jul 09, 2016 | Ovens
Tip
How to diagnose, fit and change a Belling fan oven element
If your fan oven is not heating up properly the Fan Oven Element for your Cooker is usual culprit. Fitting an oven element is generally very easy, as demonstrated by The Apart4u video on How to change repair and replace your fan oven element:this fan oven element can usually be changed without taking the appliance out of situ. Belling Elements
on Aug 25, 2010 | Belling XOU492 Electric Double Oven
I ve got beko electric cooker model DC543 and the oven doesn't work
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. For all you Beko elements
    If this helped you why not get me a beer?
Paul is from the Naturally he would appreciate beer How to Repair Home...
Jan 15, 2011 | Ovens
Have beko D533W electric cooker oven not heating up fan still working
Generally speaking, if the fan is working o/k, then it is usually the fan oven element that has failed.
This is usually located at the rear of the oven compartment behind a removeable cover.
Nov 14, 2010 | Ovens
Beko dvc 62 ,all electrics tripped out ,put cooker
The element has blown. It will cost you around
May 16, 2010 | Ovens
Beko dvc62 main fan oven stopped working, doesn,t get hot but fan still works, it tripped circuit breaker and hasn,t worked since, peter
Jan 14, 2010 | Ovens
Beko oven door - permanently detached?!
Hi - in the end I found the cheapest local oven repairers and they ended up having to do a bodge job ... they admitted that Beko was a bad brand with lots of design problems, this being just one of them. By disconnecting and opening up the back he managed to get one of the hinges back on (with my help!), but for the other he had to resort to using bigger screws coming in from the front. Recently, after less than 18 months of use, the oven and one of the hotplates stopped working on the same night. I gave the whole thing up as a bad bet and ordered a more expensive Indesit I'm now completely happy with. I think with ovens you get what you pay for. I would never touch another Beko ANYTHING with a barge pole!
Jul 28, 2009 | Ovens
No fan or heat
Hello..... have you (a) checked that you have power going to the oven...(b)...With the power to the oven switched off open the terminal block (where the cable from your socket enters the oven) check that all connections are secure....(c) remove the rear panel of the oven and check that the safety stat is ok.......(usually small square white or gray unit wit two wires running to it found on rear of main oven...it is usually fixed to a bracket or directly fixed to the cabinet...test for continuity with a multimeter if open circuit ..that is no meter reading relpace it
regards Sir Galahad
Jun 28, 2009 | Belling XOU492 Electric Double Oven
Beko s512 oven wont heat up light not on hob works ok ,,electric oven
you probabbly have some burnt out elements or switches gone bad use a meter and check for current coming to your element when you have it on if no current its a switch if there is current then its an element problem
Mar 15, 2009 | Ovens
Beko double oven electric cooker - bottom oven (fan assisted) doesnt come on, rest of cooker works fine
Oct 03, 2008 | Kitchen Ranges
Kitchen Ranges Logo
117 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
