Question about Linksys (WRT54GC) Router
Problem securing my wireless router WRT54GC
I have a dell inspiron 1300. After hours ands hours trying to get my PC to pick up my wireless router, I realised that the only way it seems to work is if I disable the security settings on the router. Obviously this is not ideal and I have disabled the broadcast for now. The security settings on my PC don;t match any of the options on the router..I fiddled around with different options but I cannot talk to the router once any security settings are on. If I got to the Network properties, Association tab on the lap top, the options in the Network Authentication field are : Open, Shared, WPA, WPA-PSK, WPA2, and WPA2-PSK. Data Encryption option The options on the router are WEP for open and Shared, ASAE & TKIP for the others.
For the router, the Wireless Security options are Disabled (Which is what I am forced to use at the mo!), WEP, WPA Personal, WPA2 personal, WPA2 Mixed Mode.
Can anyone tell me if it is possible to set up WPA between the lap top and the router??? Thanks a mil..Val
  • valmrk01 Nov 19, 2008
    I'm using windows xp
  • brig239 May 11, 2010
    which system are you using on laptop
    Genius:
  • 1,913 Answers
Ya enable advanced security.
then add mec addresse of lan card which u want to give u access internet.
u know about mec addeses.
if not then reply me at kish.khatri@yahoo.co.in
thanks
Posted on Nov 15, 2008
2 Suggested Answers
anandg27
  • 1272 Answers
SOURCE: I have a Netgear wireless router DG834G and i am
Please follow the steps on a computer connected to the router so as to check the network key:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.0.1 else try http://www.routerlogin.com
3. Login to the router with the Username as admin and password as password (unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless computer to the routers' wireless network.
In some cases, for security reasons the passphrase might show as asterisks. In this case type a new password and click apply. You will then have to use the same password for all the wireless devices connecting to the network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Sep 13, 2009
Wireless access using the dell true mobile 1300 pc
2 things...
1. test your internet connection by plugging back into the router bypassing the router.....
2. Have you set up the router?
Jan 14, 2010 | Dell Inspiron 1000 Notebook
I have lost the internal wireless card and cannot load even a external wireless like linksys what is the problem Dell Inspiron 1300
Try restarting the wireless zero configuration service. Start > Run > type cmd then enter. In the command prompt type in
net start wzcsvc
Nov 13, 2009 | Dell Inspiron 1300 Notebook
My WRT54GC won't let me into the control panel. I've looked up the solutions for hours, and i can't get it to work. I'm using a MBP and a HP Pavillion dv6000, and it's the same with both of them. If i...
If you connect the router (WRT54GC) to your broadband modem does it then allow wireless action? Your router has an Internet address. It is 192.168.1.1, in all probability. Check your manual to be sure. Access to the control panel is through this address. You must log in to the router then set up the Wireless, the SSID (the name you give your network) and any security you set up. I prefer the WEP-PSK[TKIP] as it's easiest. Other things with the router, settings and such, pretty much are set automatically, so once security is set you should be good to go. Good luck !!!
Nov 11, 2009 | Linksys WRT54GC Compact Wireless-G...
Can not connect to internet using wireless ,dell inspiron 1300 with winxp
run system restore first. try to restore to the point where the wireless was still working. if fails then uninstall then reinstall the wireless driver. if fails try to reseat the wlan card.
Oct 13, 2009 | Dell Inspiron 1300 Notebook
Wont connect to belkin 54g with wpa security applied
Please try using Wireless 'G' mode only in the router. Also, try using 'TKIP' and not TKIP+AES for encryption.
Please rate this solution, if it works for you.
Jun 01, 2009 | Dell Inspiron 6400 Notebook
I nee the drivers for the audio in my laptop(dell inspiron 1300)
Michelita,
Hi! I would like to thank you for this chance at solving a problems. The first problem seems like an easy fix. As for the second one, I would definitely need more information about the router (IE. make and model).
Issue #1
Please download the driver from here. Run the setup and be sure to follow any instructions during setup.
Issue #2
Pending more information.
Take care,
Alexander Kogl aka Chimpster
A Family Thing Consulting
www.afamilything.org
Jan 21, 2009 | Dell Inspiron 1300 Notebook
Need wireless and audio driver for dell inspiron 1300
Can download the drivers from
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INSPIRON1300/B130&os=WW1&osl=en&catid=&impid=
Dec 30, 2008 | Dell Inspiron 1300 Notebook
Inspiron 6000 has trouble picking up wireless signal
Some wireless cards are better than others at picking up weaker signals.
The problem with any wireless transmissions is that radio signals cannot pass through metallic surfaces.
You should position your wireless router away from metallic surfaces/walls and position your laptop so it can receive the radio signals without it passing through any metallic walls. If possible place the wireless router higher than at desk level.
Dec 26, 2008 | Dell Inspiron 6000 Notebook
Dell Laptop Inspiron 1300 WPA error
Assuming that your router is properly set up for WPA then also ensure that your OS is update for WPA changes http://support.microsoft.com/kb/893357
Dec 25, 2008 | Dell Inspiron 1300 Notebook
Wireless router
well..the wireless will pick up any signal..if you want one inside your place, you'll need a signal converter(wireless router) and a cable or dsl(phone com) internet service providor.
May 28, 2008 | Dell Inspiron 1501 Notebook
Open Questions:
Linksys (WRT54GC) Router Logo
215 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
