Question about Kenmore Oasis HE 27062 Top Load Washer
Locked Lid, error code "du"
My lid stays in the locked position. How can I manually override the locked lid? I have an error code "du" that will not clear.
  • Kevin Ford Nov 26, 2006
    catriver,
    Thanks...but the error code stays on. It comes on as soon as I plug the machine back in and stays on. Should I unplug and try to check the p-12 harness?
    I got it to work finally. I moved the cables around so something may have been loose. Thanks for your help
    President:
  • 878 Answers
Blat, unplug the washer for 30 seconds and plug it back in. Hit the power key and do the following: press any key except for power, start and stop in this order, press and hold for 3 seconds, release for 3 seconds, press and hold for 3 secnds, release for 3 seconds, press and hold for 3 seconds. The 88 should light up in the display if done right. While the 88's are showing (you have about 5 seconds) press the same key again. You are now in the manual test mode. Now by pressing the 2nd rinse or xtra rinse button, you should be able to lock and unlock the door mechanism. You can check the p-12 harness on the main board to make sure it is seated all the way. This test proceedure has to be done pretty precise or it will fail....Catriver...post back.
Posted on Nov 25, 2006
  • Ron Marek
    Ron Marek Nov 26, 2006
    If the washer is less than a year old, it's under warranty, parts and labor. If you want, you can try to unplug the unit and check the P-12 on the board. Sometimes all it is, is a loose connection. Just reseat it. If that doesn't work, I would call for service. There are 3 screws in the back of the consol that releases the consol. If you need to remove any clothes you can lift the whole top by pusing in on the clips about 4 inches from each side. Catriver..post back.
Having trouble with my whirlpool cabrio . . . showing "DU" . . .
The F30 error code (dU) will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked.
It will try to unlock the door 6 times before displaying the error.
Door Lock Mechanism broken.
Check Door Lock/Switch Assembly for foreign objects
Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
If it is a cabrio:
dU flashes if the following conditions occur:
Excessive force on door lid is preventing lock bolt from retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an unlocked state.
TEST #8 Door Lid Lock
Perform the following checks if washer fails to lock (or unlock).
1. Perform Manual: Door Switch and Manual: Door Lid Lock tests.
2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies.
3. Visually check that the P12 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1.
4. Check the lid lock motor winding and switches by removing P12 from the machine/ motor control and checking the
resistance values....
Component/Resistance Unlocked/Resistance Locked/Contacts Measured/Contacts Measured:
Motor Winding/35 ±5 O/35 ±5 O/P12-2/P12-3/
Lock Switch - Home/0 O/Open Circuit/P12-1/P12-4
Lock Switch - Lock/Open Circuit/0 O/P12-1/P12-7
Lock Switch - Lid/Lid Closed = 0 OLid Open = Open Circuit/Lid Closed = 0 O Lid Open = Open Circuit/P12-1/P12-5
If resistance values are good, go to step 5. If switch measurements do not match the values shown in the table for unlocked (or locked) conditions, a problem
exists in the door lid lock. Replace the door lid lock.
5. If the Manual: Door Switch or Manual: Door Lid Lock in step 1 failed, then the machine/motor control has failed: Unplug washer or disconnect power.
Replace machine/motor control assembly. Perform the Manual: Door Switch and Manual: Door Lid Lock in step 1 to verify repair.
Thanks for using FixYa!
Jan 07, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a du code that will not go off and the door is locked.
Door Unlock Error
If it is a cabrio:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer says du and it wont come on! the door lock keeps clicking like its tring to lock but cant
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
If it is a cabrio:
Sep 16, 2010 | Whirlpool Washing Machines
MODLE NUMBER WTW6400SW HAS CODE DU AND DI COMING UP WHAT IS IT
Door Unlock Error
If it is a cabrio:
Aug 23, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer displaying du code with 3 quick beeps
Door Unlock Error
If it is a cabrio:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Aug 04, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Du f flashes as code on whirlpooll whasher??
Door Unlock Error
If it is a cabrio:
Nov 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code du
Door Unlock Error
If it is a cabrio:
Jul 16, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
DU is flashing and when I press the Pause/Cancel button this does not clear the problem
Door Unlock Error
If it is a cabrio:
Jun 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Du error code on whirlpool cabrio
that code is for the door unlock error. is it possible that you may have tried really hard to open the units lid when it was locked? if so the door lock may have been broken. if not, then try to unplug the unit for a few minutes and try a new cycle.
if the code comes up again then you will have to call for free service as it has a 1 year warranty for parts and labor. yes even if you broke the lid lock!!! dont worry it happens when you get something new and are not sure how it works.
Dec 29, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio HE error code
The problem with this is the lid lock is broken i suggest replacement of the lid lock to solve your problem
Jan 14, 2008 | Washing Machines
Open Questions:
See all Kenmore Oasis HE 27062 Top Load Washer Questions
Kenmore Oasis HE 27062 Top Load Washer Logo
225 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
