Question about RCA RS2656 Shelf System
Hooking up an ipod to the stereo
I have the cord to hook into the front of the stereo into the headphone jack and into the ipod, but no sound comes out
  • Anonymous Dec 06, 2008
    YEAH MINE NOT WORKING EITHER
  • 22 Answers
Hi
cord from ipod should connect into amplifier input socket.....the headphone on front of most stereos is an output socket....thats like trying to go in thru the out door ...if you get me,
your stereo might not have a separate input.....they are usually on rear of stereo amplifier in older units
Posted on Nov 15, 2008
SOURCE:
How can I hook an iPod touch to a coby dvd968?
It has a USB port that you may be able to us with your iPod's sync cable (I'm not familiar with this Coby model) but you can always hook an iPod to any stereo or home theater using a mini jack to RCA stereo audio cable, just plug one end into the headphone jack on the iPod and the red/white cables go into an audio input in back (or front) of stereo or home theater. Good Luck.
Dec 25, 2010 | Coby DVD968 Theater System
Tip
How do i connect my iPod to a Pioneer Car Stereo
<p>It is advisable to listen to your iPod through headphones while driving in the car. Not only is it dangerous to completely cancel the sounds of the road as it is often illegal in many cities across the country. There is an alternative, however. In just a few steps you can use your iPod to your car stereo speakers and use the car to listen to your music, podcasts and audiobooks. No brand car stereo makes it easier to connect these beautiful than Pioneer. <br /> <p><br /> <p>1. Connect one end of the mini-jack on your iPod headphone jack. Once done, set your iPod or on your dashboard or your car seat so that it will not tip over while driving. <br /> <p><br /> <p>2. Find your sound system's auxiliary input Pioneer. It is often located in front of the front panel stereo, but can also open the front or back of the unit completely. If the extra connector on the back of the stereo itself, then you remove the panel. When it comes to this, see the instructions that came with your sound system is provided for further guidance. <br /> <p><br /> <p>3. Connect the other end of the cable mini-jack for stereo aux port. This will allow your iPod to the audio signal through the cable to the stereo and the stereo signal will pass to the car speakers. Most often, when something is plugged into the stereo aux jack will work in stereo. In some models a setting to select the additional connection. Whatever the case, now you can sit and enjoy your iPod for that long car ride. <br />
on Aug 09, 2011 | Apple iPod touch
Hey yeah ummm when my like stereo is off I can connect a cord with my ipod and play it... But since the stereo is technically "off" I can not control the volume on it unless it's the volume control on my...
SEEMS LIKE YOU ARE TRYING TO PLUG INTO THE HEADPHONES JACK AT THE FRONT ! NO GOOD . YOU NEED TO HAVE STEREO ON. AND USE AUX. TO DO THIS pLUG IN YOUR MP3 PLAYER WITH 3.5 STEREO JACK OTHER END BACK OF STEREO INTO AUX. RED AND WHITE RCA PLUGS.
THIS LEAD COSTS LESS THAN $7.00 AND THE SOUND IS VERY LOUD THEN. !
I DID IT MYSELF AND AM HAPPY WITH IT .
May 19, 2010 | Panasonic SC-AK320 Shelf System
Is there a way to hook up an ipod to this stereo so it will play the ipod music through the stereo? Can I purchase a docking station that will hook up to this stereo?
Just get an adapter for to connect from the Ipod headphone jack to a standard RCA cable pair. Jack into AUX or whatever available input you have.
Dec 05, 2009 | RCA RS2652 Shelf System
NO sound comes out of the headphone jack or the bottom plug in
All you need is a new headphone jack as yours may be messed up, or it may need to be checked as the cord may have came loose and just needs to be reconnected. They are pretty cheap to replace so it will not cost alot to fix.
Mar 17, 2009 | Apple iPod MA446LL/A MP3 Player
IPod Won't Play In Stereo
Dear , your headphone jack needs to be replaced..This is a very common failure in Classic models..However your ipod should work normal Stereo on the dock ..Take care.
Sep 10, 2017 | Apple Audio Players & Recorders
Need to hook up headphones to an RCA F19436 19" TV
The headphones have to be attached to a specifically identified headphone connector that switches off internal speakers.
Jun 05, 2017 | RCA F19436 19" TV
Can i hook a surround sound to my zune
It is usually as simple as getting a 3.5mm stereo headphone jack to RCA adapter, like this one:
http://www.radioshack.com/product/index.jsp?productId=3359117 (this will work just fine, even though it says 'ipod')
Or they have "Zune Ready" adapter kits, like this one:
http://www.radioshack.com/product/index.jsp?productId=3004031
Once you have the cable, you stick the headphone plug (3.5 mm stereo mini-phono) into the headphone jack on your Zune, then you insert the red and white RCA jacks into an open input on your surround receiver... most have an auxilliary input jack set on the front of the unit. All you need to do at this point is select the "aux input" for the source on the surround receiver, start your Zune, and make sure the volume on the Zune is somewhere in the 50 - 75% range, and you should be good to go.
Dec 08, 2008 | JVC THD-50 System
Can't get ipod to play on Panasonic SA HT-940 System
I have a panasonic home theatre and my ipod connects in the front of the system. The cable is basically a headphone cable with the same JACK at either end. In short the system is the headphone but you don't put it in your ears!!. You can pick these cables up from virtually any electrical retailer for less than the price of a pint!
Oct 22, 2008 | Panasonic Home Theater System System
Hook up IPOD
I am not sure if the model you have supports iPod control, but if it has an input jack in the front, you can use a cable from the headphone jack into the Aux jack in the front of the stereo and when there is a cable inserted into the jack you will be able to select Aux with the source button.
The other option is to get a kit installed at your car stereo place that will allow you to connect it via 3rd party hardware.
Cheers
May 30, 2008 | JVC KD-SX840 CD Player
RCA RS2656 Shelf System Logo
897 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
