Distorted Color and geometry of Picture
I have a PT-47WX49 rear projection Panasonic TV that is 4.5 years old. When I powered it up yesterday, the picture came on with a nonuniform distorted appearance. In general, the picture appears to be misaligned with a blue shadow on the entire picture. In addition, there is a blue semicircular area at the bottom of the picture with a red semicircular shadow above the blue area. It is impossible to align the blue and red using the convergence functions as different parts of the picture are out of alignment in differing amounts. Finally the geometry of the picture appears to be distorted in the blue and red semi-circular areas at the bottom of the picture. My Sony TV screen has these distorted images and some green color surrounding them. Some letters on screen have double images.
  • moises08 Nov 15, 2008
    My comment got posted into this similar comment. I didn't post this one. My TV is a Sony brand.
  • 13,433 Answers
Sounds like a convergence IC problem, you will need to replace them'
Heres a quide
see the before and after pictures to verify your problem
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Nov 15, 2008
    President:
  • 2,712 Answers
You will most likely have to replace the convergence IC's and maybe a few surrounding resistors. The IC's will be found attached to huge heat sinks on the convergence board. However, if you have no prior experience repairing TV's, I would recommend calling the repairman, as there are voltage in the TV that can KILL if you are not careful.
Try to manually adjust the convergence settings through the remote first. Should it still not work, then you will most likely have to replace the IC's. Replace both at the same time. They are not too expensive. However, do have the resistors that run parallel to the IC's checked first. Sometimes that could be the issue, and not the IC's themselves. It would be impossible to say what exactly is wrong without conducting a manual testing, and hence I suggest calling a repairman.
You can find replacement IC's here.
Posted on Nov 18, 2008
  • Swilin Sampson
    Swilin Sampson Nov 18, 2008
    BTW, what is your TV model number?
    Sergeant:
  • 306 Answers
Mainly the Distortion is the sign of bad Convergence ICs and also possibly the resistors that power them. so better to check the resistors right next to the ICs and replace both conversion ICs. this might solve ur prob..
    Genius:
  • 1,913 Answers
Press power button for 10seconds then it resets.
then also check your menu for disaply resolution.
I have a panasonic 47 inch cinemavision for 3 years now. there is a slight blue color distorsion when viewing. What can i do. I've tried fixing it with the remote control without luck
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 03, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-51G50CU
HEY !!
ITS A CIRCUIT BOARD PROBLEM ... IC MAY HAVE BLOWN OFF ...
Jan 01, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic rear-projection tv with no picture
sounds like a high voltage problem (flyback transformer) best thing to do is have a tech look into it, can be dangerous. Julio milleniumtvsvc@gmail.com
Jul 16, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Picture suddenly distorted, green and violet lines
It is convergence out ICs failure problem and you need to replace two ICs in convergence board/ section in TV.
If you are not familiar with TV repair then call qualified TV tech to fix it.
Apr 15, 2009 | Panasonic PT-47WX49 47" Rear Projection...
replace stk 392-110 ( or stk 392-150 same number) , check resistor 2.2 ohms for open or burn beside STK IC's
Apr 13, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic Rear Projection TV
its either the color wheel or light engine they can both cause this symptom. I would inspect the color wheel see if its brken or at the very least got a good connection as thats alot cheaper than a light engine.
Mar 03, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic rear projection TV 47 in PT 47WX49
Camaroguy: This exact problem happened to us about 8 months ago. A board had to be replaced at a cost of $500. Yesterday, the convergence has gone on the set. You get a blue and yellow shadow on the picture. From what I have been reading, this has happened on a few TVs and it will cost another $500 or so. We refuse to pour more money down the drain so we just went out and bought a new plasma (RCA) for half what it cost us for the Panasonic 4 years ago. We have never had a problem with RCA in the past (two tvs for 20 years a piece).
Mar 22, 2007 | Panasonic PT-47WX49 47" Rear Projection...
I've posted this solution several times but here goes. Try setting up the convergence through the menu by accessing the convergence setup menu. If this fails to work you have a bad digital convergence box and need a tech to replace it. About $60 to $100 fix.
Nov 03, 2005 | Panasonic PT-47WX49 47" Rear Projection...
Televison & Video Logo
274 people viewed this question
Top Televison & Video Experts
Electro Med Services...
