Question about Panasonic CQ-VD7003U Car DVD Player
My screen comes out but wont motorize upward...
My deck plays all inputs just fine but the screen wont go up....it comes out and slides horizontally but wont go up vertically, i tried givin it a little help and even that didnt work. Please help me out!!!
  • 3 Answers
I know this will be hard, but if it displays stuff, go to the menu and under user setting try changing the tilt.
Posted on Dec 08, 2007
Denon tape deck ddr m30 will not play cassette, but fast forwards and rewinds fine, it just wont play!
There may be a separate motor for the play function and either it or a drive belt has failed.
Jun 17, 2016 | Denon Audio Players & Recorders
Electricity going to my threadmil but the walking part wont move
1) You need LUBE inmediately the deck belt, probably you have a deck worn, to due the lack of maintenance properly. The machine shut down, to protect the electronic system, for enough friction between deck belt vs deck.
2) LUBE the rollers bearings too.
3) Measure the input voltage motor, if there are the motor need repair.
4) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty.
see the block d.
God bless you
Jul 09, 2012 | Exercise & Fitness
I have a proform 320x treadmill and it was working fine but now the belt wont move but the console is still working fine
lube the deck belt inmediately. proceed in according with the instruction manual maintenace You have some deck belt worn.2) test the drive belt for replace if necessary 3) test the input voltage motor, if there are the motor need repair 4) test the output voltage from motor board, for input voltage motor, if there are NOT, the board is faulty.
sincerely. God bless you
Apr 28, 2012 | Exercise & Fitness
Iv had an n64 before so i think i have a good idea of how to set it up. i've managed to tune my tv in to find where abouts it is but there's only a black screen.i can turn the n64 off an the tv screen goes...
Adjust the vertical or horizontal hold controls. This is helpful even if regular TV stations come in fine. If your TV has an automatic fine tuning control (called AFC or AFT), turn it OFF. Use the manual fine tuning dial to adjust the picture. If turning OFF the AFC/AFT causes your TV to display in black and white, then leave the AFC/AFT ON. Slide the Power Switch on the Control Deck to the ON position. While the control deck remains ON, turn the TV off for 10 second then back on again. This resets your AFC/AFT so that it will tune in the signal from the control deck.
Move your control deck farther away from your TV. If the control deck is too close to the TV, the control deck may cause some interference.
Jan 19, 2011 | Nintendo 64 Console
I dont understand how to plug the gamecube into the televison or the dvd player?
Quick Tip! If your system is connected using AV cables or the Component Video cable and you cannot see the game on your screen, it is likely all you need to find is the input select on your TV or VCR. Link here for help.
If this is your first time connecting your system, we strongly suggest you verify your hookup before continuing with the blank screen troubleshooting.
Are you using any accessories that didn't come with your system? Unlicensed products are not fully compatible and may not work correctly.
With the power ON, open the Disc Cover, remove the Game Disc, close the Disc Cover and turn the power OFF and then ON. If the Main Menu appears, your disc may be damaged or dirty.
Check your system connections and ensure they are all firm and correct:
Stereo AV cable
Remove the plugs and reinsert them with a slight twisting motion. Make sure that you are plugging the yellow cable into the video input. Also ensure that your audio cables (red and/or white) are plugged into the audio input jacks on your TV or VCR.
Component Video Cable
Remove the plugs and reinsert them with a slight twisting motion. Make sure that you are plugging the green plug into the green input (labeled Y), the blue plug in the input (labeled Pb or Cb) and the red plug into the red input (labeled Pr or Cr). Ensure that your audio plugs (red and white from the Stereo AV cable) are plugged into the audio input jacks associated with the component input jacks and that the yellow plug is hanging, and not plugged in.
Check to see if the game you are playing is set to progressive scan mode. If it is, try changing it to interlace mode. To do this, load the game disc into the system and hold down the B Button of the controller while turning on the system.
RF Switch/Modulator
Try switching both the TV and modulator to either channel 3 or 4. Also, try disconnecting the antenna from the RF Switch.
Common Solution: For RF connections, we find that video problems occur most often when an unlicensed RF switch and modulator set are used. Make sure your RF switch and modulator set are two different pieces and the name "Nintendo" is molded onto the RF switch and modulator. If your RF modulator is one piece or is black and it says "for use with Nintendo" it is an unlicensed product. Unlicensed products are not fully compatible with our systems and may not work correctly.
Adjust the vertical or horizontal hold controls. This is helpful even if regular TV stations come in fine. If your TV has an automatic fine tuning control (called AFC or AFT), turn it OFF. Use the manual fine tuning dial to adjust the picture. If turning OFF the AFC/AFT causes your TV to display in black and white, then leave the AFC/AFT ON. Slide the Power Switch on the Control Deck to the ON position, while the Control Deck remains ON, turn the TV off for 10 second then back on again. This resets your AFC/AFT so that it will tune in the signal from the Control Deck.
Move your Control Deck farther away from your TV. If the Control Deck is too close to the TV, the Control Deck may cause some interference.
If you're using the AV cables or Component Video Cables, verify that your TV or VCR is on the correct the input select.
If your TV has a closed captioning option, make sure that it's turned off.
Check the game manual to see if the game has any special features that might appear as a problem.
There may be a problem in one of your hookup cables and not your system. Try purchasing a new connection cable (where to buy). You can also try borrowing the cable from a friend to see if it solves your problem before purchasing a new item.
If these steps do not resolve the symptoms you are experiencing with your system, check out our convenient repair options.
Nov 27, 2010 | Nintendo GameCube Console
Frozen touch screen
try a hard reset then try again *2767*3855#
Sep 21, 2008 | Samsung SGH-E900 Cellular Phone
Deck A will not play/Deck B OK
Sounds like the CDR deck has an issue. When the disc comes out has it's position changed i.e has it been spun at all? Can you hear any motors moving? Does it work with any type of disc ( cd/cdr/cdrw)?
Feb 14, 2008 | KLH CDR2000 2-Disc CD Recorder
Tape deck won't open
If this is a deck where the tape slides in horizontally, like most car stereo tape players, you may have a broken or slipping belt. The fact that you "haven't used it in a long time" suggests a worn-out belt.
In my car stereo, the belt slips when it's cold and won't play or eject the tape. After a few minutes, the unit "warms up" and the belt starts turning. Then everything is fine.
I think we both need to replace our belts.
Nov 17, 2007 | Audio Players & Recorders
Panasonic CQ-VD7003U Car DVD Player Logo
232 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
