Question about Samsung LE32R74BDX 32 in. HD-Ready LCD Television
LCD TVs the black regions of the screen recently chnanged to dark brown. Help?
  • Gasman663 Nov 18, 2008
    The TV is a Samsung LE26R47BD A [R] (details as shown on the label on the TV). I couldn't select a LE26 from the drop down list when posting this so I opted for the closest match and chose the LE32 model. Other that the black areas being a reddish brown the TV picture is fine.
  • Randy Sheppard May 11, 2010
    This does not sound like it will be easy. But I need you to check the model number. Samsung can not pull up a LE32R74BDX.
  • 146 Answers
I have seen a close version of this problem. "The black area's are red". The panel driver pcb was bad. If you take off the back cover, you will find a smaller pcb at the top of the set right in the middle. This is the panel driver pcb. Repalce this board. I can not get a part number for you. For some reson the model number of LE26R47 still doesn't come up in the Samsung web site.
Posted on Nov 18, 2008
Dark screen on samsung lnt4669fx lcd tv, what could be the problem?
As you suspect, it might be of T'Con board fault. Check all the flat cables connected to T'Con to panel should be checked first for any loose contacts. Re-seat them once. If you wish to know more, check this site. It has illustrations of screen shots, for Samsung LCD TVs, with a faulty T'Con board. Can compare these images with your TVs.
Jan 24, 2013 | Samsung LNT4669 TV
Hi i have and 1999 lumina ltz i recently got robbed for my radio and they ripped my wires so now i have a boss 626ca car radio that needs to be installed.. my problem is that the colors dont match up can...
Constant 12V+ - Orange Switched 12V+ - Yellow Ground - Black/White Illumination - Gray/Black Dimmer - Brown/White Antenna Trigger - Pink Left Front (+) - Tan Left Front (-) - Gray Right Front (+) - Light Green Right Front (-) - Dark Green Left Rear (+) - Brown Left Rear (-) - Yellow Right Rear (+) - Dark Blue Right Rear (-) - Light Blue
May 30, 2011 | Car Audio & Video
Vizio 52 Red dots
It sounds like you have a defective LCD panel. This is more common with the plasma TVs. Are you sure it's an LCD?
Aug 01, 2009 | Televison & Video
Wierd color issue
hello! it would be good if you will inform the company wherein you had puirchase that gadget right away. there might be some technical problem with it. companies always provide a warranty, you consult it to them right away..thanks! feel free to contact me for more inquiry.
Apr 10, 2009 | Acer X193W LCD Monitor
White corners SONY KDL52XBR6
This is called a dark shading error. All the LCD consumer sets have some visible degree of this effect. Some will be a little less or more than others even from the same batch in the assembly run. This has to do with the optical design quality of how the back-plane lamps illuminate the screen. The design and assembly tollerance of this area is very critical.
Normally, LCD screens don't show their best picture in a darkened room. The very black regions of the picture content may look a little washed out. LCD screens are best watched in a room that is lit, but not very bright. You have to consider that there is a powerful set of lights behind the polarized panel of the LCD display, and there will always be some breakthrough of light.
If you want a TV that is more like a CRT in its characteristics a Plasma would have been a good choice. The trade-off with the Plasma is that it does not have the picture sharpness of the LCD. A Plasma set is best watched in a darkened room.
If you have an LCD computer monitor, take a look at it in a dark room with a black screen. You will most likely see the dark shading errors. Only the very expensive production studio type LCD monitors have less of this error than the consumer sets, and they are not absolutely perfect.
Jerry G.
Nov 19, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Blue Screen
no those tvs came with a black otuer screen that have rough ridges . If your screen is blue, someone may have replaced it with a dark colored plastic. You can get replacement screens at the following link, They are exspensive though.
Jul 12, 2008 | Mitsubishi VS-50605 50" Rear Projection...
My Sharp LCD 26" TV shows most black and shadow colours as vivid blue, I have tried resetting the colour to factory reset but that didn't seem to help at all. It occurs on all channels and on 3...
the problem with LCD tvs are that they have back lamps that shine thru the LCD sceen. the job of the screen is to block the light of the different colors to make the picture. the problem is that the very thin screen can not block all the light. if the set has a back lamp setting turn down the back lamps and adjust the brightness control it should help a little. you my notice that the blacks and dark sceens look better when the room is fully lit and look much worse in a darken room.
May 27, 2008 | Sharp Televison & Video
Black/Dark Colors Fuzzy w/Red Pixel Outline
Sorry, I haven't been on here for a while.
I haven't found the cause. I find that leaving it switched on overnight cures it.
Feb 18, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Sony dvd player Model DVPNS78H
Sounds like the TV you are using does not support NTSC, the US TV standard. Try connecting the DVD player to some other TVs - something not more than a few years old would be a good bet, and a large screen plasma/LCD ideal as most of these are "multi-system" and handle PAL and NTSC automatically.
If the problem was the region coding you would be getting a message on the screen, something like "Cannot play due to area limitations".
Jan 14, 2008 | Televison & Video
Need help with wiring a pioneer deh-5
You do not have the entire Pioneer model number listed, so I cannot provide you with the wiring info for it.
Bu here is the wiring info for your jeep.
Constant 12V+ Pink/Yellow  Switched 12V+ Red/White  Ground Black  Illumination Orange/Brown  Dimmer Black/Light Blue  Antenna Right Front  Front Speakers 6 1/2" Doors Left Front (+) Dark Green  Left Front (-) Brown/Red  Right Front (+) Purple  Right Front (-) Dark Blue/Red  Rear Speakers 5 1/4" Roof Mount Left Rear (+) Brown/Yellow  Left Rear (-) Brown/Light Blue  Right Rear (+) Dark Blue/White  Right Rear (-) Dark Blue/Orange **from
Best of Luck.
Oct 31, 2007 | Alpine CDM-7874 CD Player
Samsung LE32R74BDX 32 in. HD-Ready LCD Television Logo
79 people viewed this question
Jerry Greenberg
Jerry Greenberg
