Question about Pentax ZX-30 QD 35mm SLR Camera
Can't see out of viewfinder
When I look through the viewfinder, all I see is black. It looks as it would when the lens cap is on, however the power on the camera is on and the lens cap is off. When I look through the viewfinder, the only lights I see are the images that represent the different modes (example, smiley face, flower, mountain). Also, film is properly installed. I have.. -removed the lens, looked through viewfinder (still appears black) and then replace the lens. - made sure that the aperature is set to A, that the lens is in automatic mode. - Also played with putting the lens in Manual mode and setting the aperature at different settings. - Turned camera on and off. - Replaced batteries.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 216 Answers
The mirror motor is probably the problem, you'll usually hear a whirring noise like a motor spinning. It's about a $125 repair, requiring the mirror box to be removed and the mirror driving motor replaced. Pentax originally put a plastic gear on the motor shaft - the replacements have a brass gear.
Posted on Nov 25, 2006
SOURCE:
When I look through viewfinder everything is black
Sorry to ask the obvious.
Does the camera power indicator show that it is on?
Is the lens cap off?
Jun 14, 2015 | Video Cameras
Sony DCR-TRV250E.
was the problem the lense cap, or you do still need assistance?
Mar 28, 2008 | Sony Handycam DCR-TRV19 Mini DV Digital...
Why is there is no image, only a black screen with icons
You could have a setting for looking through the viewfinder only, which turns off the LCD display.
Of course, make sure your lens cap was not left on. Also there is usually a setting for looking at pictures you took. or looking through the lens. If you have no images saved, there will be nothing to see.
Set the camera back to view through lens.
May 11, 2014 | Canon Cameras
When in video recording mode LCD screen and viewfinder are black when the lens cap is off.
It could one of a few problems:
1. The viewfinder is pulled out and "PRIORITY" is set to "FINDER".
Push the viewfinder back in or set "PRIORITY" to "LCD".
2. The LCD monitor's brightness setting is too dark.
Adjust the brightness of the LCD monitor.
3. If the monitor is tilted upward 180 degrees, open the monitor fully.
Download the manual for more info:
JVC GR D290 Manual
Jan 19, 2014 | JVC GR-D290 Mini DV Digital Camcorder
I recently bought a Nikon FG, and when i look through the viewfinder all i see is black. I made sure the lens cap it's on, and its still black! I need to replace the batteries, but will that fix the...
Take the lens off the camera and look inside. you should see a mirror angled at 45 degrees. If you do not see the mirrir, it is probably stuck in the up position and repair is necessary
r
Apr 22, 2011 | Nikon FG 35mm SLR Camera
Black screen will not take photo
May sound silly but, make sure the lens cap is off. If so, then look to see if the automatic iris is opening when you power on the camera, you will know it is open when you can see the glass of the lens. Fresh/fully charged battery/batteries would be something else to try.
Sep 18, 2009 | Konica Minolta DiMAGE Z6 Digital Camera
No view on viewfinder or screen
If the lcd screen is black even with the lens cap off,the ccd base assy. needs replacing.
May 28, 2008 | JVC GR-D20EK Camcorder
My Canon 300D SLR will turn on, and led display comes up saying battery is full and yet when you go to take a photo you cant see anything but black through the lens.
Obvious Questions, but you didn't supply the information.....:
1. Is the lens cap off?
2. Are you looking through the viewfinder? You will *NOT* be able to use the LCD screen as a viewfinder.
Otherwise, there is always a light path through the lens to the viewfinder, so....
1. Have you tried a different lens?
2. Have you checked the mirror is down?
May 26, 2008 | Canon Cameras
JVC Digital Video Camera GR-DVL107E
Assuming you don't see any video through the viewfinder, it could be that the CCD has died on that camcorder. It happens, though not frequently.
If the video though the viewfinder is clear, there might be some sensor on the lens ring to indicate a lens cap, or an automatic lens cap not properly disengaging when put in record mode.
Jan 20, 2008 | Video Cameras
Pentax ZX-30 QD 35mm SLR Camera Logo
473 people viewed this question
Top Pentax Photography Experts
Bill Eager
Geoff Hone
Are you a Pentax Photography Expert? Answer questions, earn points and help others
