Question about Kenmore 64254 / 64252 / 64259 Top Freezer Refrigerator
Refrigerator knocking noise
Kitchen Aid refrigerator (10 yr old) makes a knocking noise when the compressor starts: it only lasts a second. Everything seems to be working otherwise. I liken the noise to 2 bowling balls knocking each other.
  • 903 Answers
The motor could be on the way out. Put your hand (carefully) on the motor (back of the refridgerator), if it is too hot to touch then the motor is burning out and will need to be replaced.
Posted on Nov 15, 2008
Noisy compressor
Is the compressor running when you hear this noise or is it noisy when it is trying to start. If the noise you are talking about is the click it may just have a bad relay on the compressor. If it is a loud humming noise when the compressor is trying to start then the compressor is locked up and needs to be replaced. Compressor comes with a 5 yr warranty and relay has a 1 yr warranty.
Nov 16, 2007 | Maytag MFD2560HES Bottom Freezer French...
How do I fix a knock coming from the bottom of my Refrigerator?
the compressor is mounted in 4 rubber grommets and held in place by a pin
these rubber grommets break down and allow the compressor excess movement on starting and stopping
it is just a suggestion to check the mounts for condition
Jul 16, 2016 | Fisher and Paykel Refrigerators
The knocking noise is coming from inside the compressor unit,it lasts for aboat 5 to 10 seconds,sometimes a full minute.fridge is 5 years old.had this problem for the last year.
Does it do it on start up of the compressor? Sounds like the springs that hold the rotor inside the compressor are getting weak and letting the rotor touch the side of the compressor..... till it comes up to speed and levels out.... There is nothing that you can do except replace the compressor.... I would call the dealer or who ever you purchased it from and check if the compressor is still under Warranty.... If may last a long time but it could lock up tommorow too you never know...... Hope this sheds some light on the problem...
Feb 05, 2011 | KitchenAid (KSRD22FKST) Side by Side...
Whirlpool fridge incessant buzzing
The knocking noise when cuts off , is a compressor internal motor support spring , broken . This does not mean the compressor is bad , only noisy for the rest of the compressor life , but should be covered under the 5 yr warranty . The gurgling sound is the refrigerant being pumped thru the system . The buzzing could be from the compressor also . My suggestion , would be to call a factory warranty company , to see if they can replace the compressor under warranty .
Sep 07, 2009 | Refrigerators
My new frigidaire refrigerator model# FRT18S6AWX is unusually noisey . It makes gurgleing sound and it last for 10 seconds . it does this throughout the day once every half hour. We reported it and were...
hi, this is not normal at all. this is a manufacturing flaw the resides in the compressor build. there is way to much pressure being produced threw the lines. the compressor regulator seems to be flawed in its design. i would recommend purchasing a aftermarket compressor Assembly for this unit. the noise itself is a dead give away for flawed compression in the core Assembly.
Mar 11, 2009 | Frigidaire FRS26R4A Side by Side...
Kitchen aid side by side 2003 KSC... freezer not freezing
sounds to me like a bad compressor....might want to have that looked at by a pro.
Sep 30, 2008 | KitchenAid KSCS25FKSS Side by Side...
Kenmore 64254 / 64252 / 64259 Top Freezer Refrigerator Logo
1,676 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
