Question about Garmin nuvi 350 GPS Receiver
Garmin 350 won't turn off
Can't turn off garmin 350, power on/off button is stuck. And can't depress it 1/2 way to access other functions like volume.
  • Garmin Master
  • 2,130 Answers
Please se the aricle I wrote on this subject
http://www.fixya.com/support/r1036147-garmin_nuvi_350_360_370_660_off_power
- Jim
Posted on Nov 15, 2008
I unplugged cable to computer during first update This is a garmin zumo 340
Try doing a Hard Reset
  • hard reset zumo 340 en 350 - YouTube www.youtube.com/watch?v=tWUDsiXu9QI
    • BY MRGPSNL
    • 6 MIN
    • 10K VIEWS
    2014-03-20 · Met een hard reset breng je je toestel terug naar de fabrieksinstellingen en is je apparaat weer ... hard reset zumo 340 en 350 ... Garmin Zumo ...
  • zumo 340LM ' Garmin buy.garmin.com > Shop > Automotive > Motorcycles Garmin Connect lets you search, plan and share your rides. Get Started /en-GB/GB/accessoriesAndMapsUrls/010-01043-06.ep. Customer Service. Product Support;
  • Hard reset Garmin Zumo 220, 550, 660 - YouTube www.youtube.com/watch?v=g9h9QtWWedk
    • BY MRGPSNL
    • 4 MIN
    • 25K VIEWS
    2014-03-20 · Met een hard reset breng je je toestel terug naar de fabrieksinstellingen en is je apparaat weer 'als nieuw ... Hard reset Garmin Zumo ...
  • Garmin zumo 660 665: How to Reset Video - GPS City www.gpscity.ca/videos/play/Q0td7d4BH9A How-to video for the Garmin zumo 660 665: How to Reset Video explaining its functions and installation.
  • http://www.bing.com/search?q=garmin+zumo+340+reset&qs=n&form=QBRE&pq=garmin+zumo+340+reset&sc=0-21&sp=-1&sk=&cvid=3C4EE77095704DEC935AD44372BE0B4D
    May 11, 2016 | GPS
    My WP-350 is stuck and wont turn on/off
    I'm having the same problem with my Creative WP-350 Wireless headphone; the blue light stays lit. I've tried charging the device fully and pressing the + (volume increase) and the multi function buttons with no success. There has to be someone out here that can provide the solution. I wrote to the Creative tech folks too, awaiting for a reply
    Jul 07, 2013 | Creative WP-350 Headset
    Garmin nivi 200 won,t turn on
    The mini-USB jack needs to be either resoldered or replaced. When the jack is loose, you will not be able to charge the internal battery. The jack becomes loose from overuse. The jack needs more mechanical support to the pronted circuit board. I have fixed this problem many times.
    - Jim
    Aug 01, 2009 | Garmin Nuvi 350 Car GPS Receiver
    It just stopped talking. No voice directions, on
    Hit the menu buttom, go to settings, then go to volume and see if it is muted. Sounds like the mute or volume down button got inadvertantly hit and turned down or muted. If this does not work, turn the unit over and look under the fold up antenna for a reset button. Depress this button until the unit restarts and should reset the unit back to factory default settings and get you on your way. Good luck!!! If these don't help you, call the garmin support number at :1-800-800-1020. Hope this helps!
    Aug 01, 2009 | Garmin nuvi 885T GPS Receiver
    Mitsubishi WS65611 no remote function & panel buttons not working
    This TV is known for the buttons going bad. You can remove the speaker grille to gain access to the wires for the panel. You may have to pull off the font access panel to get to the connector. There will be two of them, one for the input, other for the control panel buttons. If the buttons are bad, unhooking them will make the TV work fine with remote. I believe the connector is labeled ZR and is not the one with the thicker black wires (shieled video wires). Unhooking is my fix for this problem as replacing the buttons seems to be only a temporary fix.
    Dec 04, 2008 | Mitsubishi WS-65611 65" Rear Projection...
    Garmin 360 keypad stuck
    operator error - search doens't work with Topo maps, only city navigator. changed map and worked.
    Aug 20, 2008 | Garmin nuvi 350 GPS Receiver
    Garmin Nuvi stopped working and won't restart
    Got a Garmin Nuvi 260. Same problem. I read the booklet. There's a reset button on the bottom. Disconnect from power. Push the reset button. Connect back to power. Now it works. The reset button is tiny and looks more like just text on the bottom sticker than it does a button. But push it anyway.
    Aug 06, 2008 | Garmin nuvi 350 GPS Receiver
    Stuck power on button.
    There are three ways to turn on your Nuvi
    1. Press the Power On Switch
    2.Connect it to a USB port on a Computer via the USB cable 3.Plug it into the Accessory Outlet or Cigarette Lighter receptacle in your vehicle
    There is a good possibility that the Power On Switch has been depressed so far that it might in fact cause the unit to short out when powered up via either option 2 or 3 in which case it could cause Major Damage to your computer as well as your Nuvi In Option #3 you may just blow a fuse in your vehicle but toast the Nuvi. The Safe Route and the one which I would highly recommend is Return it to Garmin for Repair.
    Nov 29, 2007 | Garmin nuvi 350 GPS Receiver
    Garmin nuvi 350 GPS Receiver Logo
    1,017 people viewed this question
    Top Garmin GPS Experts
    SHARCNET-USA
    SHARCNET-USA
    TO Lady
    Are you a Garmin GPS Expert? Answer questions, earn points and help others
