Question about Boston Acoustics TVee Model Two TV Speakers
Not enough IR range to use remote
My remote does not work at more than five feet distance from the TVEE by Boston Acoustics.  Is there a fix for this problem?
  • 4 more comments
  • araknd Dec 25, 2008
    Same problem with a brand new out of the box unit. This is unacceptable.
  • Ckent4000 Dec 25, 2008
    Same problem remote only works if within 4ft of TVee. It's going back if problem can not be corrected soon.
  • bmonie Jan 03, 2009
    I tried Nytevizion's suggestion, above, and it's miraculous!  Now I love my TVee soundbar!  It works from as much as 25 feet away!  Awesome.  Thank you so much for a great fix!
  • twozrnot2 Jan 27, 2009
    Is it difficult to remove the cloth cover and how did you pry the IR filter off? Do not want to ruin the unit. Thanks.
    Had to pull the unit down and found out the cover removes easily. Removed the IR Filter and the remote works fine from anywhere in the room. Excellent Solution!!!
  • Anonymous Apr 24, 2009
    is it possible to put the grill back or does it stay off?
    Problem Solver:
  • 6 Answers
Get yourself a very thin and small screwdriver. The type that comes in the eyeglass repair kits. Remove the cloth/plastic grill from the front of the sound bar. Locate the IR sensor in the center of the bar. Pry the dark red filter off the IR sensor and leave it off.
Problem solved, greatly increases range. I have read that there is a clear replacement cover you can buy but whats the point?
Posted on Jan 02, 2009
  • shineoncrazy Dec 13, 2010
    Awesome tip, I have been on the phone with Boston Acoustics arguing for replacement/substitution of my out of stock soundbar. Then I found this and problem fixed in 5 minutes. Interesting that this was first posted two years ago and they are still selling the product with this range limiting 'filter'. Also interesting that the supervisors at BA told me that this was not a known problem.
  • Valgrom Jul 23, 2012
    I guess this solution must be for anything other than a model 30 because I have a Tvee Model 30 and when I tried to do this I noticed that the "filter cover" of the IR sensor is recessed into the unit. In other words there are no "edges" on which to put anything in to pry the cover off. I can't take a close enough picture to show this, but if you look at the sensor on any model 30 you'll know what I mean. Any other suggestions?
I can't get my soundbar to sync with my samsung tv remote. When I tried to pair the mute button it didn't work. The mute on my remote control now increases the volume!
Posted on Mar 11, 2011
I was about to pack the unit up return it when I found the suggestion to pry the IR sensor cover off with a tiny screw driver. This sounds damaging, but it wasn't. There is a little bit of glue around the perimeter, but I applied some consistent light pressure and it popped off. I am now sitting comfortably 15' away on my reclining leather couch.
Posted on Dec 28, 2009
Boston Acoustics TVEE 26 factory reset
Reprogram the remote to function with a different brand of equipment that you do not have. The remote can't affect the receiver if it is not talking to it.
Feb 23, 2014 | Boston Acoustics TVee Model 26
Cannot get sound out of TVee 10
Try pressing the function select button to change inputs.
Dec 28, 2012 | Boston Acoustics TVee Home Theater...
Programming time warner remote to boston tvee volume
I had just about given up on programming my Time Warner universal remote with my Boston Soundbar until a mental lightbulb came on. This is a two step process. Step 1: Program your Time Warner remote (I have CLIKR-5, instructions available for other models at timewarner.com) Using Pre-Programmed 3-digit Code method -Turn on soundbar - Press device button (I chose AUX) and OK/Select simultaneously until device button stays lit. - Point remote control toward the soundbar and enter code (447 for Boston Acoustics) - Press the device button again to store the code. The TW instructions say you should now be able to turn the device off to verify that it works, but this is not true for the soundbar. Hang in there with me. Step 2: Program your remote from the Boston Soundbar. - Press the power button and the volume up button simultaneously until the indicator light flashes orange. Here's where the instructions provided with the soundbar fail to explain how to do this. Each button is individually programmed into the TW remote. What you have done so far is enable the remote to accept the programming. - Volume Up: press the volume up button on the soundbar while it is flashing, the light should become steadily orange. - While holding the remote steady about a foot away from the soundbar, slowly press the volume up button on the TW remote four times. The orange light should flicker each time you do, turning green when completed. - Volume Down, Mute, Power: repeat the steps for Volume Up, except press the button on the soundbar you wish program to the TW remote while the soundbar is flashing orange. It should become steady before you press the corresponding button on the TW remote. Good luck, I hope this helps. -Deidre.
Dec 05, 2012 | Boston Acoustics TVee Model 25 Sound Bar...
Tvee model 25 wont shut off light goes red and after 3 seconds flips back on
The TVee 25 will turn itself on whenever there is an input. If there is no audio input it will shut itself off or you can manually shut it off. Or, you can select an input that has nothing connected to it.
Sep 24, 2012 | Boston Acoustics TVee Model Two TV...
Red status light will not go off or change on Boston A TVee model 2 soundbar.
I am also having the same problem. It was working fine until we moved. Plugged it in at the new house and nothing but a red light. Sub is green though.
Jul 10, 2012 | Boston Acoustics TVee Model Two TV...
Boston tvee doesn't work
check cable power and check cable connection
Jan 15, 2011 | Boston Acoustics TVee Model Two TV...
Boston Acoustics TVee Soundbar loses the cable remote training.
get rid of that moxi before it starts on fire.
have charter send out a scientfic atlanta hd dvr, with an hdmi port on it as well. the functionality and reliablity of these boxes greatly exceed moxi. moxi is a power sucking, fire hazard, problem waiting to happen. the only thing it has that is good is the guide format. but you may feel that graphics on a tv guide outweigh the funcitonality of the device. the big square in the front of the moxi was supposed to be a dvd burner, the box has no hdmi, and has a modem in it that is disabled. so its got a bunch of junk on it that isnt and cant be used. if you dont clean the vents on the back of the box monthly it will surely fail.
senior catv tech/supervisor
ALL OF US INSTALLERS DESPISE PAUL ALLEN FOR INVENTING THAT PEICE OF ****.
Jan 01, 2010 | Boston Acoustics BA735 Computer Speakers
Need the Boston tvee sound bar repaired. Making popping and cracking noise when power is on.
Haven't fixed it yet. Going to find a electronics repair shop locally and have them repair it.
Thanks.
Apr 11, 2009 | Boston Acoustics TVee Model Two TV...
Suround sound dvd
Get a Boston Acoustics Tvee Soundbar System.
Dec 06, 2007 | Boston Acoustics TVee Model Two TV...
Boston Acoustics TVee Model Two TV Speakers Logo
1,212 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
