Question about Kenwood XD-A8 CD Shelf System
XD-A8 CD player
The CD player on my system operates normally for 3-5 minutes upon insertion of a CD, then it stops and skips to the next CD or stops playing the CD it's on. It doesn't shut down, the CD player just stops working. Any thoughts?
    President:
  • 3,130 Answers
This sounds like it could need just a simple cleaning with a lens cleaner disc, or could be a bad spindle motor or spindle servo circuit, or the laser is getting weak, and last but not least It very well could be a damaged or dirty slider rail or motor assembly. In my opinion, the only one that is worth the money to try, would be the cleaning. Good Luck PS Please do not forget to rate this thread.
Posted on Dec 09, 2006
How can I get sound out of my kenwood stereo system?
Ask the previous owner to demonstrate how it works
Sep 21, 2014 | Kenwood XD-A8 CD Shelf System
Audio Books
There are several brands and publishers of audio books and you didn't identify yours. In most cases professionally produced audio books are separated into several 3-6 minute tracks. your CD player should just skip to the next using the button with the single arrow pointing to the vertical line. >l
When listening to audio books, If I'm using a cd player that doesn't retain the last track when shut off I make a mental note of the track number.
Hope this helps
Dec 14, 2013 | Coby CX-CD329 Personal CD Player
Cd music is skipping on bose 321 system and one channel of dvd audio will stop playing. Disk player has also started making loud vibration noise after loading dvd or cd. This didn't used to happen. On CD...
The Bose® 3·2·1 GSX Series III DVD home entertainment system puts you at the center of exciting home theater with just two visible Gemstone® speaker arrays and a hideaway Acoustimass® module. Setup is simple because, unlike traditional five-speaker surround systems, there are no center or rear speakers. An elegant media center features a progressive scan DVD/CD player with an HDMI output and AM/FM tuner. You'll enjoy vivid detail in your movies and sports with video resolution up to 1080p over HDMI.
Apr 04, 2010 | Bose 3 2 1 GSX System
3 disc Phillips cd player sometimes skips. It is
At some time in its life, the laser that reads the CD starts to get too weak to operate reliably. That's probably what's happening here. Unlike mechanical parts that can be inspected for wear, electronic parts tend to work fine one day, then the next, poof. The laser assembly is replaceable if you can locate the part and find someone to install it. An electronic service shop could give an estimate for repair. If you can provide the full model number, I'll see if I can find the part number.
Mar 08, 2010 | Teac AD-600 3-Disc CD Changer
CMT-ED1 cd player works intermittently/partially
Greetings, I have owned this system since around 1999/2000, my CD function started to mal-function a year or so later. It would sometimes play, but more often than not, it would wobble and make strange clicking type noises. I gave up trying to figure the problem out because of the frustration, and didnt want to spring big bucks to take it in the shop to fix professionaly. However...only yesterday, based upon some advice I read online somewhere, I think I solved the problem and I will pass along what I did.
1 I first took some rubbing alcolhol and useing a model paint brush, I dipped the brush into the bottle and applyed it on the laser lense (do this spareingly, do not flood) this cleaned the lense of dust and grime)
2 It played a CD for the first time in 10 years. BUT...it started to do it's old tricks when I tryed to skip to the next song.
3 I noticed a small button on the right, front side on top of the unit. I think this button serves as a sort of safety stop. I then lifted up the glass lid, and held down the button with my finger. I noticed the lense of the laser go DOWN into the body of the unit. When I released the button, it came back UP.
4 I placed a CD into the player, placed the stabiliser on the top of the CD as normal, AND HELD THE BUTTON DOWN with my finger, LEAVEING THE GLASS TOP UP. It PLAYED. I recorded a Flatt
Apr 04, 2009 | Sony CMT-ED1 Shelf System
A8 2004 Navigation system not active
NAV unit uses a DVD disc. If its a copy, it may or may not work. I suggest you remove the NAV disc, unplug the NAV unit from power for 4-5 minutes, reconnect the NAV and try inserting the disc again to see if it reads. If it still does not read, another NAV disc needs to be inserted to verify its not a "bad" NAV DVD disc issue. If it still cannot read the second disc, the NAV unit is bad. The handbook feature needs the disc inserted in the slot 1 of the CD changer unit.
Feb 23, 2009 | 2004 Audi A8
Computer will no longer read. play or even acknowledge dvds or cd
Try this:
How to fix the CD player
1. Go to System/Library/Caches and trash the folder com.apple.kernelcaches
2. Go back to System/Library and trash the file Extensions.kextcache
3. Restart.
If that doesn't work, try trashing this file:
~Home/Library/Preferences/CD Info.cidb
That is the way its done
Dec 17, 2008 | Computers & Internet
RS 2653
I had a rca system similar to this little different. It's a problem you'll find in any cd player after awhile. You'll need to replace the laser. It's quite easy google for some instructions to replace a cd laser. Look around for a laser that can read cd's and cd r and cd rw and you'll be ok. The disassembling might be a bit tuff but it's worth it. I had to replace my hifi laser and after i did sound was incredible again no skipping. Make sure when opening your system you power it on and unplug it to make sure all charge is gone wait 30 minutes or so before you go and operate.
Feb 10, 2008 | RCA 100-Watt Stereo System With 5-CD...
Player only plays first 3 tracks on CD and then stops
the emitting diode is not shiffting right..it might need some cleaning of its track..open it and check it out. good luck
Apr 05, 2007 | JVC XL-FZ258BK 5-Disc CD Changer
Kenwood XD-A8 CD Shelf System Logo
142 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
