Technika LCD19id - No power to internal fuseMy LCD 19id-107 tv turned itself off and will not come back on. I have power to the 3 pin power connector at the rear of the tv. However i have no power to the internal fuse or main tv on/off switch. (It may be me but the fuse appears to be on the Neutral connection, following a continuity check. ??) Does the power go straight to the swith/fuse or through components first. Any help appreciated, as typically just out of warranty, Thanks Steve..
  • 1 more comment
  • Anonymous Nov 25, 2008
    just bumping up
  • wandsoft Dec 07, 2008
    I have the same problem. Technika LCD19ID-107 switched itself off, and will not turn back on.
    If you feed power in, nothing happens. But as you remove the power, the tiny red light on the front flickers, showing that power has been trying to get through.
    Anyone help?
  • Anonymous Dec 21, 2008
    i have the same problem with this TV, on removing the back i removed the on/off board & found that it had blown a capacitor,this looks like it could be the problem
I have a Technika 22 inc hd flatscreen that will not power up. you can here the dvd running if you load a dvd but the television side wont power up.I have tried to find the internal fuse but have had no luck.Anyone help?
Posted on Dec 14, 2008
Wont come on
I am assuming that you checked the power cable to the wall and the back of the TV. Most TVs have a three pin CEE22 type connector at the back for the power inlet. Sometimes this can work itself loose and come out a little disconnecting the power. Try wiggling it in until is home. You may have done that already, if that did not help it is more than likely the power supply or a fuse in the power supply is blown. Generally fuse is not accessible without taking the back cover off. Usually it is on the power supply board. Hope this helps.
Apr 18, 2014 | Sharp LC-32SB24U 32 in. LCD TV
Technika lcd 32
Probable power supply failure.
Jan 13, 2014 | Televison & Video
I have a samsung LN-S3238D lcd tv. the unit is approx 3 - 4 yrs old. last night when watching tv the tv shut off by itself and will not turn back on. normally when the tv is shut off, the red led light is...
Hi replace the fuse in the wire connecting the mains plug. It's generally located within the 3 pin plug.
If you are lucky it maybe just a fuse blown out.
Thanks
Jul 06, 2017 | Samsung LN-S3238D 32 in. LCD HDTV
Technika flat screen - model No LCD19ID-107. WHEN
There is a Diode and probably a Resistor blown on the power supply board... Check out the fix on my website:
http://normsweb.com/tektips/technika.shtml
I hope this helps you.
May 18, 2010 | Televison & Video
Need a code number for a lcd 19id-107 technika 19 in lcd tv
www.remotecodelist.com
www.tvcodes.com
www.remote-codes.com
One of these websites will have your code. I didn't know what brand and model remote you where using.
Sep 05, 2009 | Televison & Video
Childlock on tv without remote
unplug it for and hour or two and plug it back in
usually this will reset the tv's settings and the child lock will be turned off.
Oct 22, 2008 | Televison & Video
Hannspree tv
This is a very difficult question to answer without knowing more info, but here goes:
Check the power cable, there should be only place to plug it into. This may be one of several styles depending on your model, usually a 3 prong female (just like your PC's power cable) connector, or a single pin female connector (looks male but has a hole in the center) will connect to the back of the monitor.
If you get power, but no image: VGA connections will use a large blue connector with 15 round pins, 3 rows of 5. DVI will be a large white connector with slotted pins, with varying amounts of pins depending on the type of cable (analog, digital, or both). HDMI will be a small connector that resembles a large USB connector. You may also be using a composite or component cable, which will be color coded to the ports on the monitor.
All styles of connectors will physically only connect to the corresponding port. Check all connections and make sure they are all secure and connected to the correct locations on the monitor. Doing this should resolve your issue.
May 12, 2008 | Hannspree HW191D LCD Monitor
Technika LCD191d-107 LCD TV
You may want to check the solid state fuse on the power suppy or which can be called the inverter. The fuse will blow and finding a fuse can be hard.
Thanks
C Dill
Aug 28, 2007 | Sampo PME-50X7 50 in. HD-Ready Plasma...
Dell ultrasharp 15 inch flat panel lcd has no power and does not turn on at all
Disconnect the monitor from the computer, then turn it on. You should see three bands of color (red, green, and blue), which is the self-test feature of the monitor. If you can see all three colors, the monitor itself is probably OK, and it will mean that you need to check the connector on the monitor cable, the connector on the back of the videocard in the back of the computer, or reseat the videocard itself. One of the connectors could be damaged, or you could have a bent, broken, or missing pin within the connector. If a pin is bent and touching the shell of the connector, it can send the video signal to ground, making the monitor appear to be dead. BE VERY CAREFUL if you try to straighten the pin; they are fragile, and if you break the pin off completely, you will have even more problems to deal with... If one or two of the color bands are not visible, the LCD monitor is defective, and you'll have to decide whether it is cheaper to repair it, or simply to replace it... If you still can't locate the problem after checking the system as I've described, get another monitor to test the computer with. If the second monitor works properly, you most likely have a problem with the Dell LCD; if the problem still exists after switching monitors, then you most likely have a problem with the computer, and NOT with the Dell monitor...
Apr 01, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Televison & Video Logo
1,244 people viewed this question
Top Televison & Video Experts
