Question about Soyo DYLT032D 32 in. LCD Television
SOYO LCD TV Model DLYT032D
Power light flickers and no picture. I found the power board is a Model # FSP230-5M01. Went to FSP's site and couldn't find it.
You answered one posting awhile back and said to check the fuse. Is their a fuse in the power module your talking about? If so were about is it?
Thanks in advance for your help.
Frank
714.746.1701
mailto: f_desantis@yahoo.com
    Problem Solver:
  • 7 Answers
DO NOT SPECT TO FIND A NORMAL FUSE. THESE ONE IS LIKE BROWN COLOR AND ROUND. IT HAS THE CAPACITANCE ON THE TOP OF THE PLASTIC. IT IS NEXT TO THE POWER CORD CONNECTOR. (1.5 AMP.S / 250 VOLTS)
Posted on Jun 01, 2010
Samsung 32" LCD TV
Sounds like Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Aug 01, 2016 | Samsung Televison & Video
LCD TV screen has flickering lights like snow, what to do to get rid of them?
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit.Contact any service technician.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts. Abnormal DC voltage output from the power supply regulator board can cause this problem.
It will be best to replace the power supply regulator board as card basis.
Aug 04, 2014 | Samsung Televison & Video
My Maxent mx-50x3 has a intermitten problem, when I turn it on, it does not have a picture, 5 minutes later it will flicker than a couple minutes more it has a picture while flickering, another ten minutes...
i had the similar problem. i'm not a tech but like to take stuff apart to find the problem. on my tv i took the back completely off. do not touch the boards. if you follow the power supply from the plug up two boards i found a small white adjustment screw. it was just up and to the right slightly from the plug. with a small screw driver i turned it slightly to the right and the flickering and delayed picture went away. couldn't tell you why it worked but it did. hope this helps, saved us $800 to buy a new tv.
Aug 20, 2011 | Maxent MX-50X3 50 in. HD-Ready Plasma...
My Soyo Govideo LCD Television stop working, the red power light will not stay on.?? Its a 42 in LCD TV
Power LED light indication blinkings or completely dead?Yes,than the power supply board is the causes.That the board,where the power a/c cord plug in to it.Take the aparts,replaced the power supply board,will sold this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 20, 2010 | Soyo Onyx SYTPT4227AB 42 in. LCD TV
I have a protron PLTV 3250 I was watching Tv and the TV went out.
no it is your power supply it may have primary power but if you look closely you will see several puffed up capacitors these blow because of the fet near by let go and is not avail you can get a new supply for about 60 bucks from ramplus.com get the fsp number off the supply ex fsp-194
Sep 18, 2009 | Protron PLTV3250 32 in. LCD Television
My Soyo DYLT032 has power but no picture or sound
I HAVE FOUND 2 2200uf CAPS ON THE POWER SUPPLY BOARD THAT ARE PUFFED UP. CHANGING THEM USUALLY SOLVES THE PROBLEM. THERE'S ALSO A RESET BUTTON ON THE MAIN BOARD YOU MAY NEED TO RESET AFTER CHANGING THE CAPS.
May 30, 2009 | Soyo DYLT032C 32 in. LCD Television
Long story short:
Had the same problem with my Soyo.
Thought it was the power supply board problem that everyone else was reporting.
ordered one.  Plugged it in.  Did not work.
Inspected the Main/Logic board and found what looked like a black button that could be depressed.  It is located to the right of main processor on the board.  You can't really miss it.
With the TV plugged in, I pressed the suspect button.  The TV made a buzzing/clicking noise for a few moments and the stuck blue illuminated power button faded away.
Curious by this, I pressed the power button and low and behold the TV comes to life!
Looks like I found a "reset" button which seems to have fixed my problem.
Thanks Soyo for not bothering to mention that such a button exists.
I hope the rest of you have the same good luck.  In the event you are still in need of a power supply board, email me.  I have a spare now it seems.  ;)
Dec 28, 2008 | Soyo DYLT032C 32 in. LCD Television
Problems with Soyo DYLT032C 32 in. LCD Television. The TV will not turn on, I have un-plugged it and plugged it back in, in hopes it would re-set the tv. Do you have any suggestions?
Long story short:
Dec 10, 2008 | Soyo DYLT032C 32 in. LCD Television
Soyo model mtprtp3208nb
Replace all bad capacitors(end raised up) on power suply's main board. That'll fix it. fixed mine :)
Nov 02, 2008 | Soyo DYLT032D 32 in. LCD Television
Soyo 32
Oh my God. I just finished talking to the rep mentioned below. She was nasty. I've been waiting since July cause they don't even have the part in stock since then. I will almost quote this person: "Okay Mam, I don't have to listen to your complaints, your only option here is to keep waiting and I really don't know when the part is going to be back in stock or even if it is going to be in stock again. There is nothing else we can do for you". So what do you think. I paid for a one-year lasting tv and a quote for repair. I was even willing to pay for the part and the excessive shipping charge to get it, but they don't have it. I can't believe there is nothing we can do about this.
This is the "so gentle" lady's information. One thing I know, I will never buy a Soyo again, and will persuade anyone wanting to buy one against it.
Janet Mendoza RMA Department SOYO, Inc, (A publicly traded company: OTCBB: SOYO) 1420 S. Vintage Ave, Ontario, CA 91761 Tel: cb_transparent_l.gifus.gifspace.gifspace.gifarrow.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gif(909) 292-2513cb_transparent_r.gif Fax: (909) 292-2545Email: rma@soyogroup.com
May 19, 2008 | Soyo DYLT032D 32 in. LCD Television
Soyo DYLT032D 32 in. LCD Television Logo
499 people viewed this question
Top Soyo Televison & Video Experts
ted dux
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
